[solved] Brake line flare nuts stuck; cut hard line out, replaced with new
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 7, 2015.
  1. Dec 9, 2015 at 3:49 PM
    #41
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I ordered two new pairs of large vise-grips. Gonna attack the bastards this weekend I hope.
  2. Dec 9, 2015 at 3:51 PM
    #42
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Crom[OP] likes this.
  3. Dec 9, 2015 at 4:03 PM
    #43
    WVBearhunter
    WVBearhunter Member
    Get you a can of Kano Kroil. Best penetrating oil you will find.
  4. Dec 9, 2015 at 4:06 PM
    #44
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    have u tried tightening the nut? i have worked on many rusty toyotas if it looks like it is goint to brake i tighten it u little justso u fell it move,and then loosen.It has worked well for me.GOOD LUCK :popcorn:
    SnowroxKT and Crom[OP] like this.
  5. Dec 9, 2015 at 4:06 PM
    #45
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I'm not looking forward to dealing with this as I have to install my rear extended brake lines. Good luck Crom, post up your results.
  6. Dec 9, 2015 at 4:17 PM
    #46
    Crom
    Nick
    San Diego, CA
    Millions
    Yup it sucks. After doing a lot of research on the subject, especially with the Tacoma, it seems clear to me that the factory assembled them with too much torque and with some moisture in the joint and some time they freeze together.
    Once I get things apart, I'm gonna lightly grease the threads of the flare nut before reassembling. I know from experience, that for everything I've greased, no matter what I can get it apart in the future.
    Yes. I tried that too. Thanks. :fingerscrossed: for Saturday.
  7. Dec 9, 2015 at 4:20 PM
    #47
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    For future reference, always use flare nut wrenches. More contact area, prevents this issue.
  8. Dec 9, 2015 at 4:21 PM
    #48
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    As stated in the OP, he did.
  9. Dec 9, 2015 at 4:22 PM
    #49
    Crom
    Nick
    San Diego, CA
    Millions
    Yep. Might want to add "quality" to the flare nut wrench recommendation. Because it was a flare nut wrench that rounded the shoulders of the nut in the first place.
    And thanks @PerfectTekniq :thumbsup:
    Drainbung and SjTacoSharks like this.
  10. Dec 9, 2015 at 4:25 PM
    #50
    SjTacoSharks
    SjTacoSharks Well-Known Member
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    I had this same problem on my 09. Ended up rounded off the nuts on the axle and said fuck it. Took it to a shop to just finish it all was around $150. Far better than having to replace the entire brake lines haha
  11. Dec 9, 2015 at 4:27 PM
    #51
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    For sale, Snap on flare nut wrenches. Two sets, 3/8"-1/2", and 10mm-15mm. Open end are speed grind. Anyone want to make an offer and I will dig them out of the basement toolbox. They are like brand new.
  12. Dec 9, 2015 at 4:36 PM
    #52
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    i did mine for less. With a regular 10mm open end box wrench. I think operator error! :boink:
  13. Dec 9, 2015 at 4:37 PM
    #53
    SjTacoSharks
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    you have a 2011 with less miles thats seen more pavement than a honda civic
    gordi[QUOTED] likes this.
  14. Dec 9, 2015 at 4:45 PM
    #54
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    As previously mentioned Operator Error, It must be embarrassing having a shop fix your incompetence.
  15. Dec 9, 2015 at 4:47 PM
    #55
    drupp
    drupp Well-Known Member
    Pennsylvania
    '06 Access Cab TRD Off-Road
    I ran into the same issue a while back and used Kano Aerokroil and I think vice grips. I used it liberally and let it sit for a day, then used it again when I broke them free. It really is very good stuff.
  16. Dec 9, 2015 at 4:48 PM
    #56
    SjTacoSharks
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    hhaaaaaaaaaaaaaa I could have done it myself except I had 2 days to put on my entire lift by myself as I was heading back to WA for an internship
    gordi likes this.
  17. Dec 9, 2015 at 7:20 PM
    #57
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    Have you ever asked someone for help? You incompetent fool. :thumbsup:
    SjTacoSharks likes this.
  18. Dec 9, 2015 at 10:17 PM
    #58
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    get some air in a can. heat up the female side hot as you can. turn air in a can upside down and hit the male nut for at least 10 seconds. this will freeze it. remove male nut side...good luck...old school mechanics trick
  19. Dec 9, 2015 at 10:45 PM
    #59
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Another tool that was recommended to me:
    VISE-Grip VIS4LW
    The distinct shape helps to grab better. Fortunately my Craftsman flare nut wrench has been good to me, but I did use the VISE-Grip for other purposes and it's a really good tool. I'm not promising much given the level of difficulty you are having, but it's a more 'proper' tool than channel locks. It's a fairly teeny tool which makes me doubt it will work for you given the force you are needing to exert.
    ...and if this comes down to righty-tighty, lefty-loosey... well, at least you have a chance to make your thread famous ;)
  20. Dec 10, 2015 at 4:46 AM
    #60
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Bummer. As much junk as I've worked on, here in the heart of the Salt-belt, never had this issue. Flare nut wrenches and regular wrenches all that was used... along with penetrating oil.
    Vice grip em and torque on em
