[Solved] Camelback Toyota Shock Absorber PN Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, May 29, 2018.
  1. May 29, 2018 at 10:16 AM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    I tried to order rear shock absorbers from Camelback for my 1998 Limited and had a problem. Camelback lists separate part numbers for the right (48531-A9020) and the left (48541-A9010) rear shocks, so I called Camelback direct. During the discussion I asked for the manufacturer of the shock absorbers and I was told it was "Mark". When I mentioned "Bilstein" the lady said she recognized the name but the information she had told her the shock absorber was made by "Mark".
    What I want are true Bilstein 4600 shock absorbers. The only part number I can find from my records of past purchases is B46-2286, same PN for the right and the left. Can somebody please help me figure this out?
  2. May 29, 2018 at 10:24 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I dont think the rear shocks matter you cant really mix them up. I would just go 4600 in the rear
    Only reason i can see why there is 2 part numbers is maybe the left one is a litte stiffer to help with the added weight on that side
  3. May 29, 2018 at 12:17 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Not sure on the 98 but on 02-04 the left and rear are two different lengths, so 2 different part#s. I believe the driver side is just a tad longer.
    Like sper said, order the 4600s online, skip the dealer.
  4. May 29, 2018 at 1:55 PM
    skeezix
    Colorado
    1998 Limited
