(solved)Changed valve cover gasket, now I get exhaust in cab with heat on at idle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WPDAWG11, Dec 8, 2017.
  1. Jan 15, 2018 at 10:05 AM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Honestly I thinking coincidence myself, at this point. And I do need to get some soapy water and follow the exhaust back, its just been so damn cold.
    I dont think that's it anything like that, but I do need to pull it just to look at it.
    Im pumped we made it to the NC, with these recruiting classes coming in I have no doubt we will be in the hunt for the title many years to come.
    True, one absolute symptom I've found is the fumes dont come in when re-circulation is turned on, which makes sense.
    All lines are good and secure Ill have to check the back of the hood. Ill def keep folks updated, hope I figure it out before AC is needed!
  2. Feb 3, 2018 at 10:04 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Ok I'm gonna keep this thread updated bc I hate when I'm reading a helpful thread and it just drops off.
    So my truck just died one day. Jumped it and found out battery/alternator were done. Fix it and the truck is running but idling rough, like bigly. Check coil packs and there all out of whack from the one we tested at the autoparts store. Replace all four and the spark plugs and the truck is running like a champ but still has the exhaust leak. Start it up yesterday and it just feels weird and finally throws a code! P0456, more specifically it says it's a solenoid on the egr valve. But the code is well encompassing. Now I have direction but don't really know till I do some research.
    Still don't get how replacing the valve cover gasket got me here lol
    Vereor_Nox likes this.
  3. Feb 3, 2018 at 10:36 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    This still sounds like vacuum related. Did you test the vacuum with a gauge?
  4. Feb 3, 2018 at 12:25 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I man going to tomorrow. My buddy down in unionville has a lift!
  5. Feb 4, 2018 at 9:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is wrong. You do not have an EGR Valve on your truck.
    This is what the service manual says:
    P0456 EVAP small leak
    Detection Conditions:
    Leak detection pump creates negative pressure (vacuum) in EVAP system and EVAP system pressure measured. 0.02 inch leak criterion measured at start and at end of leak check. If stabilized pressure higher than second 0.02 inch leak criterion, ECM determines that EVAP system has small leakage.
    Trouble Areas:
    • Fuel cap (loose)
    • Leakage from EVAP line (Canister - Fuel tank)
    • Leakage from EVAP line (Purge VSV - Canister)
    • Canister pump module
    • Leakage from fuel tank
    • Leakage from canister
  6. Feb 5, 2018 at 6:59 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Correct, it has that pump that pushes the air out. The autozone computer did say EGR but the part doesn't exist obviously.
    Soooooooooo I feel like a jackass, but when I did this it was dark outside, really cold, and I was a bit drunk. Not an excuse! Had a prof diesel mechanic along side helping, and was really careful where I put the bolts, but not careful enough. I missed a bolt on the back of the valve cover. For some reason an 8mm bolt fit in there for the fix, yet the rest of the bolts are 10mm?? Gonna get the correct hardware here soon. Its important not to do this type of stuff sloppily, is take away here. This is unrelated to my other issue with all 4 of the coil packs being bad, still not sure how that is even possible, but I digress. Thread /
  7. Feb 5, 2018 at 7:11 AM
    scocar
    scocar Patron of the Farts
    1. Your truck is 12 years old. Random shit will wear out all the time now.
    2. Drinking and wrenching are never a good pair.
    3. Glad you figured it out. I thought you were going to pass out from CO poisoning while driving with fogged windows on a cold night.
  8. Feb 5, 2018 at 7:16 AM
    Canufixit
    New England
    Congrats!
  9. Feb 5, 2018 at 7:35 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    1. True
    2. Idk as long as you aren't getting hammered, a few cold ones can really smooth out a job. But its a slippery slope for sure
    3. hahahaha Def was messing with me on super cold days when I had to run the heater. Glad its figured out!
  10. Feb 14, 2018 at 6:50 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    So I put a new OEM gas cap on her and have not had the code back since. Keeping my fingers crossed!!
  11. Feb 14, 2018 at 9:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  12. Feb 14, 2018 at 9:05 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Congrats! :cool:
