SOLVED!!! Day time Running Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by coryohana, Mar 8, 2017.
  1. Mar 8, 2017 at 1:20 PM
    coryohana
    coryohana [OP] Well-Known Member
    Cory
    Ventura, CA
    2002 Prerunner TRD 3.4 Auto w/locker
    *Magnuson Supercharger *OME suspension with 880 coils *Dakar Leaf Pack *SCS F5 Dark Bronze, wrapped in KO2's *Custom Diamond Back bed cover and rack with custom storage *LED exterior/interior light replacement *SS brake lines *TC LCA Cam Tab gussets *TC UCA
    Hello team! Newbie with a question.
    I believe I have DTL's because my headlights lights are on even with the lights turned off.
    Is there a way to have my headlights not running? I just switched to [headlight] HID's and do not want the lights on the whole time? Thanks in advance for your time and help.
  2. Mar 8, 2017 at 9:44 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Google it, TONS of right ups on many tacoma/4runner forums on how to disable it.
  3. Mar 8, 2017 at 9:51 PM
    muddog67
    muddog67 Well-Known Member
    There are many links just Google how to disable 2004 Toyota Tacoma daytime running lights period here's one link . There's a certain wire you have to cut underneath the steering wheel column . I did the exact same thing with mine and cut the wire.
  4. Mar 8, 2017 at 9:58 PM
    muddog67
  5. Mar 9, 2017 at 12:31 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    04 HAS A FUSE YOU REMOVE IN THE OUTSIDE FUSE/RELAY BOX
  6. Mar 9, 2017 at 8:39 AM
    coryohana
    Cory
    Ventura, CA
    Really don't want to cut any cords. I'd rather just pull out a wire under driver console. I have a TSB PDF for a 2000, does it share the same wiring as a 2002? Also running HID's with ballast, and don't want to effect them or any other light/electrical component in truck.
  7. Mar 9, 2017 at 8:58 AM
    ZiaTaco
    ZiaTaco Well-Known Member
    New Mexico
    04' SR5 TRD Off Road Double Cab
    D
    Do you know which fuse?
  8. Mar 9, 2017 at 8:59 AM
    coryohana
    Cory
    Ventura, CA
    @muddog67 -So I should pull the white green cable/fuse (wire #1)?
    @mechanicjon - do you have a picture of the outside fuse/relay box? And is this the box under the steering wheel? Finally, this is for a 2004, and not my 2002. Do they share the same set up? Thanks.
  9. Mar 9, 2017 at 9:07 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    The Outside fuse/ relay box is under the hood on drivers side on my '02 Tacoma .
  10. Mar 9, 2017 at 9:20 AM
    coryohana
    Cory
    Ventura, CA
    Okay kinda confused, lol. is there a wire I'm supposed to pull out from under driver side steering wheel, or a fuse I should pull out under the hood?
    Also what fuse under the hood? @Keep on Truckin'
    Pics appreciated, can't access my truck right now.
  11. Mar 9, 2017 at 9:25 AM
    Keep on Truckin'
    Jarvis
    Indiana
    I don't have DTL's but the Black fuse box is located behind the battery & the cover is labeled for each fuse & Relay location within the fuse box.
  12. Mar 9, 2017 at 9:39 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    The fuse is a mini fuse labeled DRL
  13. Mar 9, 2017 at 9:43 AM
    coryohana
    Cory
    Ventura, CA
    @mechanicjon - so do I pull the fuse under the hood, or do I remove wire from under steering wheel?
  14. Mar 9, 2017 at 9:44 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    No should just be able to pull fuse out.
  15. Mar 9, 2017 at 9:54 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Really hope it's not PNP HID kit...
  16. Mar 9, 2017 at 9:58 AM
    coryohana
    Cory
    Ventura, CA
    what's a PNP kit? I'm not using stock housing if that's what you mean.
  17. Mar 9, 2017 at 11:32 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Okay good :)
  18. Mar 9, 2017 at 1:29 PM
    coryohana
    Cory
    Ventura, CA
    @mechanicjon - okay pulled the 7.5 Amp fuse label DRL on top of fuse box, under the hood. Lights still running. You sure it's just the one fuse and nothing else?
  19. Mar 9, 2017 at 2:16 PM
    coryohana
    Cory
    Ventura, CA
    Can anyone help please?
  20. Mar 9, 2017 at 2:17 PM
    coryohana
    Cory
    Ventura, CA
    I pulled those fuse no go. Do I have to have the fuse pulled and what wire pulled out from under the steering wheel?
