SOLVED!!! Day time Running Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by coryohana, Mar 8, 2017.
  1. Mar 18, 2017 at 8:34 PM
    #81
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    One side of the headlights were still plugged in and the one you were testing was unplugged?
  2. Mar 19, 2017 at 1:53 AM
    #82
    Jedi Yota
    Jedi Yota Member
    TRD pre runner
    Built Right Long Travel
    Im not sure what lights are on the same relay or fuse...But I had an Issue with my Gauge lights & STereo lights dimming when I would press the brakes..The dealership couldnt figure it out & told me to deal with it...It turned out, My Rear left Brake light Bulb was out & causing this whole issue
  3. Mar 19, 2017 at 6:51 PM
    #83
    coryohana
    coryohana [OP] Well-Known Member
    Cory
    Ventura, CA
    2002 Prerunner TRD 3.4 Auto w/locker
    *Magnuson Supercharger *OME suspension with 880 coils *Dakar Leaf Pack *SCS F5 Dark Bronze, wrapped in KO2's *Custom Diamond Back bed cover and rack with custom storage *LED exterior/interior light replacement *SS brake lines *TC LCA Cam Tab gussets *TC UCA
    When I did the test. I unplugged the HID's on driver side. My OEM bulb plug only has 3 prongs/inserts, and my measurements correspond with your drawing @mechanicjon
    I will get voltage of my high-beams while truck is on. Also I cannot get measurements of lights off while truck is on and idling. The headlights automatically turn on, even with my lights turned to the off position, when I start my truck.
  4. Mar 19, 2017 at 9:10 PM
    #84
    mechanicjon
    Jon
    Scottsdale Arizona
    They will because of daytime running lights. That's by design. I'm looking for voltage difference between hi, low and DRL
  5. Mar 19, 2017 at 9:20 PM
    #85
    mechanicjon
    Jon
    Scottsdale Arizona
    Ok the white and green wire that runs to your factory head light plug. Key On and engine off measure resistance to ground for that wire. So white and green with one probe the other to a ground source.
    What's the Ohms?
  6. Mar 20, 2017 at 12:40 AM
    #86
    mechanicjon
    Jon
    Scottsdale Arizona
    Also check the DRL fuse for power engine running light switch off and engine running light switch on. Engine running is important. Check both sides of the little test hole in the top of the fuse. Use your meter with one terminal to ground. Test those to little metal dots on each side of the number
  7. Mar 24, 2017 at 3:38 PM
    #87
    coryohana
    Cory
    Ventura, CA
    sorry for the delay. Will be getting measurements soon, dealing with a family emergency but will try to find time this weekend to post measurements, or by next week. Hang in there please!
  8. Mar 24, 2017 at 6:27 PM
    #88
    mechanicjon
    Jon
    Scottsdale Arizona
  9. Mar 24, 2017 at 8:51 PM
    #89
    muddog67
    muddog67 Well-Known Member
  10. Apr 12, 2017 at 3:58 AM
    #90
    muddog67
    Op , did you ever get your daytime running lights figured out?
  11. Apr 15, 2017 at 9:42 PM
    #91
    coryohana
    Cory
    Ventura, CA
    No. been dealing with a family emergency. Close family member is ill, and been taking care of them in their home. Will provide measurements to jon by next weekend, when I fly back to my apt and truck.
    mechanicjon likes this.
  12. Apr 23, 2017 at 7:31 PM
    #92
    coryohana
    Cory
    Ventura, CA
    Hey guys. Still taking care of family. Should be flying back next Friday, and will post readings by end of the weekend. Please stay with me need to figure this out. Thank you!
    trevor2009, muddog67 and mechanicjon like this.
  13. May 9, 2017 at 4:26 PM
    #93
    coryohana
    Cory
    Ventura, CA
    Alright team. I'm back in town. I appreciate your patience as I have been gone for a while.
    I feel like the HID kit has too many issues. So going to remove and replace with regular housing and led bulbs. Still need to kill dtrl though. @mechanicjon
    @muddog67
    Still will run the test as requested in the last few posts. New setup should be here in 7 business days. Then I will post the readings.
  14. May 9, 2017 at 6:20 PM
    #94
    mechanicjon
    Jon
    Scottsdale Arizona
    Welcome back. You get family taken care of?
    muddog67 likes this.
  15. May 10, 2017 at 12:57 PM
    #95
    muddog67
    So what did you come up with?
  16. May 11, 2017 at 8:43 PM
    #96
    coryohana
    Cory
    Ventura, CA
    Family is better, thank you for asking. I sent back the HID Kit and will be installing regular head light housing next Friday with led bulbs. I have regular bulbs as a back up if the led headlight bulbs throw crazy light.
    My turn signals, horn, and hazard stopped today so going to start with fuse checking. I also put in led turn signal bulbs and had hyper flash before fuses blowing. I have "ck" bulbs on order. I guess they might help stop fuses blowing.
    So to wrap up, next Friday I will install and post readings. I want to figure out why we can't shut of dtrl. Thanks!
  17. Jun 1, 2017 at 5:53 PM
    #97
    coryohana
    Cory
    Ventura, CA
    Big shoutout @mechanicjon !!!!
    Thanks to everyone else as well who continued to helped what seemed like a lost cause as well! Finally turned off the DTRL!!! @muddog67
    This is why we have Tacoma World!! THANKS AGAIN @mechanicjon!! I owe you one, let me know whenever you are in the L.A area
  18. Jun 1, 2017 at 6:19 PM
    #98
    muddog67
    thats great news , way to go , so what did you end up having to do ? what was the problem ?
    ThunderOne likes this.
  19. Jun 1, 2017 at 7:28 PM
    #99
    mechanicjon
    Jon
    Scottsdale Arizona
    Ended up being the Light kit. Put back to stock and unhooked white/green wire per TSB. DRL's off!!
    muddog67 and ThunderOne like this.
  20. Jun 1, 2017 at 7:32 PM
    #100
    coryohana
    Cory
    Ventura, CA
    Yep! Long road to get there but we got there! Lol
