[Solved] Front Axle Replacement Parts After Hitting a Pothole
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Nov 14, 2017.
  1. Nov 14, 2017 at 2:21 PM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    I recently hit a pothole in a dirt road at about 30 mph with the passenger side wheel. It was one helluva hit. I looked at both axles and noticed a small amount of run-out on them but the run-out on the passenger side was more than that on the driver side. I may need to replace the axle. The PN is 43430-04020 and the cost is around $400. What other parts should I replace when I do the job (wheel bearing, differential seals, hub seal)??
  2. Nov 14, 2017 at 3:29 PM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    By "run-out" I'm assuming you're seeing grease from the CV Boots? are they torn at all? Have you had any symptoms of a bad axle, clicking during slow turns, vibrations etc?
  3. Nov 14, 2017 at 3:34 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I'm pretty sure he does NOT mean grease leaking from the CV boots and is probably talking about seeing wobble or imperfection in the rotation of the wheel, similar to warped rotors.
  4. Nov 14, 2017 at 3:59 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Could you describe what you mean by "run-out"?
  5. Nov 16, 2017 at 9:36 AM
    skeezix
    Colorado
    1998 Limited
    Sure. When I rotate the driver side tire and look at the axle shaft, the end going into the wheel simply turns and there is no wobble. But when I rotate the passenger side tire I can see about 1/10 to 1/8 inch (hard to measure and my eyeball is not calibrated) of wobble.
    On the way back from the pothole I didn't notice anything at all. The truck rode perfectly. But now it seems that there is a tiny bit of out-of-balance when driving at 35-40 mph around town. I don't want to spend $450 for a new axle assembly unless I'm sure that the 1/8 inch wobble is too much.
  6. Nov 16, 2017 at 10:05 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    *If* your axle (CV axle) is bent, you've got a LOT of other things to replace too.
    The axle is not what takes the load on impacts, that's your suspension's job - shocks, control arms, spindle, ball joints. If you bent your axle from an inpact, you'd know by the way it drives.
    The only way to tell of your axles are bent is to take them off. IMO closing one eye and looking at it while you spin the tire on the truck is a terrible way to check. There are a lot of other things in that system that can move and make it LOOK like it's out of round.
    I'm betting that's not the problem, though. I'd first check that your wheels are still balanced and go from there. You may have just lost a weight or two.
    Then, get it aligned. If you can't get it aligned within spec, you've got bent stuff, but your axle probably isn't what's causing the wobble you're experiencing.
    I could easily be wrong, but a bent axle is not the first thing I'd jump to with your symptoms.
  7. Nov 16, 2017 at 3:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is good, sound advice^^^^^
    My money is on a missing wheel weight.
  8. Nov 16, 2017 at 8:51 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Bent rim?
  9. Nov 16, 2017 at 8:58 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'd get an alignment before I do anything.
    Pretty easy to knock these trucks out of alignment, and that could very well cause some sort of vibration.
  10. Nov 18, 2017 at 9:12 AM
    skeezix
    Colorado
    1998 Limited
    I am lifting the passenger wheel off of the ground when I check for axle wobble.
    I don't think a bent rim would cause the axle shaft to wobble since I see the wobble with the wheel removed. What's happening is the center of the axle is moving around as I turn the hub. On the driver's side I cannot see any movement of the axle's center point when I turn the driver side hub.
    No weights are missing from the passenger wheel.
    >>There are a lot of other things in that system that can move and make it LOOK like it's out of round.<<
    I'm not sure what else I should look for. I do remember when I checked the axle ends in the past that they were rock-solid and the center points did not move when I turned the axles by hand.
