[SOLVED]Gen 3 Factory Tonneau Cover Release Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EOS, Aug 3, 2017.
  1. Aug 3, 2017 at 12:32 PM
    EOS
    EOS [OP] Well-Known Member
    2017 TRD OR AC
    Anyone else have an issue with releasing the factory tonneau cover?
    I open the tailgate, pull the lever that should release the connection points, but it doesn't. The other 2 release levers work just fine, but the first one does not...
  2. Aug 3, 2017 at 12:38 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    The latches need to be aligned with the striker pins. Do that with the cover closed and find a neutral position after you loosen the latches with a 10mm socket. You'll have to remove the soft plastic cover that hides the hardware too. This is similar to aligning a door striker, but the striker pin isn't the part you're loosening for the tonneau adjustment.
  3. Aug 3, 2017 at 12:41 PM
    EOS
    2017 TRD OR AC
    Ok.. the gearing and hardware that the lever connects to is under a plastic secured by star head screws. Is that where the striker pin can be adjusted?
  4. Aug 3, 2017 at 12:44 PM
    GPsevinSixx
    Ros Angerus
    Striker pin is fixed to the bed rail and not adjustable since it's centered with countersunk bolts.
    The part with the gears and lever is not the part you adjust. It's the latches you adjust that's located on the outer edges of the cover that interface with the striker pins on the bed rails. You should probably let the dealer do it since it's brand new. Sometimes manually shifting the Tonneau can get it to latch better also. It will end up pivoting around the "security" bolt.
  5. Aug 3, 2017 at 12:49 PM
    EOS
    2017 TRD OR AC
    Ahhhh... gotcha! I know what the latches are then.
    Thank you!
  6. Aug 3, 2017 at 12:49 PM
    GPsevinSixx
    Ros Angerus
    Cool. Good luck!
  7. Aug 3, 2017 at 2:06 PM
    EOS
    2017 TRD OR AC
    Adjusted the latches didn't do the trick..
    Opened up the covers that cover the cable from the lever to the latches and found that one end of the cable was disconnected. Connected it back to the green clip and all is good again!
    Thank you for the ideas @GPsevinSixx
    GPsevinSixx likes this.
  8. Aug 3, 2017 at 2:11 PM
    ICU1
    ICU1 Well-Known Member
    I have some cover. No issues for me.
    I'm sure Toyota will say that's normal. I hope you get it fixed
  9. Aug 3, 2017 at 2:22 PM
    GPsevinSixx
    Ros Angerus
    Good, you got it resolved on your own! Saved you the trip and frustration dealing with the middle man.
  10. Aug 4, 2017 at 4:39 PM
    brian01tj
    brian01tj Member
    Brian
    2017 DC OR
    I dont think this is the same issue as the OP but maybe...
    My latches were just fine but the last panel where it meets the tailgate is very loose and easily moves up and down. Its bad enough to where the rubber weather stripping doesnt make a complete seal. Is this just how they come or is there a fix for it?
    THanks
  11. Jul 4, 2018 at 8:37 AM
    raadkins16
    raadkins16 Member
    2018 Cement TRD Sport
    Reviving this thread and question above. Just got my truck and it’s loose on end nearest tailgate. Is this normal ?
  12. Jul 4, 2018 at 9:08 AM
    Blackwolf
    Blackwolf Well-Known Member
    Paul
    Northern VA
    2018 Inferno DCSB TRD Off-Road
    That last panel needs a “double click”. When you close the last panel it will latch the first step and then you need to push down again right above the latch/striker and you will hear it click a second time.
  13. Jul 4, 2018 at 9:16 AM
    Michael252
    Michael252 Well-Known Member
    Near Dallas
    My last panel stays loose too when I close it. To make it tight, I have to look under the cover and push up on the metal semi-circular locking bar to make it click into place.
    (Dealer told me to slam the lid closed...Personally, I don't think slamming anything makes it last longer.)
  14. Jul 4, 2018 at 1:56 PM
    raadkins16
    raadkins16 Member
    Thanks! I finally located that second set of clicks and that helped a ton to make it more secure at the end of the cover. Much appreciated
    Blackwolf[QUOTED] likes this.
  15. Jul 4, 2018 at 3:31 PM
    Blackwolf
    Paul
    Northern VA
    Yeah I wouldn't slam it. Pushing on top after the first click will engage the second part of the latch that you're locking from underneath.
    raadkins16 likes this.
  16. Jul 4, 2018 at 6:40 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    A small push down gets the second click for me.
