[Solved] How Do I Remove the Driver Side Lumbar Support Handle???
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Feb 5, 2025.
  1. Feb 5, 2025 at 11:24 AM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    I'm in the process of removing the driver seat cushion from its frame. I got the right side cover and two bolts out but I'm having problems removing the lumbar support handle from the left side plastic cover. I didn't see any screws holding it to the shaft, so I tried prying the handle off the shaft from inside the plastic cover but I'm afraid of breaking something.
    So how does one remove the round handle from its shaft?
  2. Feb 5, 2025 at 1:53 PM
    skeezix
    Colorado
    1998 Limited
  3. Feb 5, 2025 at 6:10 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Lumbar support? What's that?
  4. Feb 7, 2025 at 2:08 PM
    skeezix
    Colorado
    1998 Limited
    The knob I described raises and lowers the back edge of the seat. I thought that was the support for your lumbar. (Lumbar is the lower part of your back.)
    There's a small lever on the right side of the seat back that, when you move it up and down, moves sumthin' in the lower part of the seat back. I think I was mistaken by using "lumbar support" in my initial post.
