[SOLVED] Howling noise between 35-45
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBella, Jan 14, 2016.
  1. Mar 13, 2017 at 7:42 AM
    #341
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    Thank you for these. Ran the truck through some stuff this weekend, then heard the howl and got a sinking feeling. Got to a spot with service and read this thread. Taped it up that night and problem solved.
  2. Mar 13, 2017 at 7:49 AM
    #342
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Experiment with various hole sizes / freq to cancel out the harmonic howl from the rear.
  3. Mar 13, 2017 at 7:52 AM
    #343
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    Nothing from the rear, yet, but might as well wrap those up, too. How did this not get caught from factory?
  4. Mar 13, 2017 at 7:55 AM
    #344
    2016Tacoman
    J
    I have heard it maybe a couple of times in a year with the correct cross wind. If it still does it at 300k I might look at it, no deal breaker really. Just tell people its the blower kicking in.
    TheCookieMonster likes this.
  5. Mar 13, 2017 at 9:38 AM
    #345
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    My 17 has the wind howl , I'm going to order and install the plugs myself.
    shakerhood likes this.
  6. Mar 13, 2017 at 9:59 AM
    #346
    kluge9
    kluge9 Well-Known Member
    Andy
    19 DCSB OR MT
    Just went out and checked. My 17 OR had the plugs installed when I bought it 2 weeks ago. One less thing to worry about.
  7. Mar 13, 2017 at 6:04 PM
    #347
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    Will the dealership give plugs for free?
    EDIT: Manager wanted me to come in for them to check it out and wasn't aware of the TSB. I ordered off of Amazon.
  8. Mar 13, 2017 at 7:24 PM
    #348
    Taco351
    Taco351 Well-Known Member
    Robert
    NLR/Sherwood
    2017 Tacoma Double Cab 4X4 TRD Off-Road White
    K&N air filter/LED lights/Magna Flow Muffler/TOYO AT2 Tires and lots of fun stuff.
    Mine would not!. Not only that, they would only order the parts after they VERIFIED the condition. My stealership doesn't even stock these eventhough this applies to every 16-17 Tacoma. Not only that, they want like $68 for them. I bought mine at Lowe's for about $1 a piece. Well worth the time and $6 to stay away from the dealer.
  9. Apr 19, 2017 at 6:28 AM
    #349
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Hey guys, how do I determine I have a LCA whistle and not the differential howl, my truck is a 4x4 6 Speed Manual Access Cab.
  10. Apr 19, 2017 at 6:30 AM
    #350
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    At what speed are you getting the howl?
  11. Apr 19, 2017 at 6:38 AM
    #351
    specter208
    California
    I can hear a faint noise from 30 mph and up.
  12. Apr 19, 2017 at 6:41 AM
    #352
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    And it doesn't stop? FYI, I've only had the LCA howl and that was from 35-45, then I capped some of the holes and it then went to 60-65. I taped them all and it stopped. I recommend putting some black duct tape over the holes, then drive at the same speeds.
    shakerhood and specter208 like this.
  13. Apr 19, 2017 at 6:43 AM
    #353
    specter208
    California
    I taped the recommended holes as in the TSB but could indeed still hear a faint whistle at highway speeds. I'll try taping all the holes as you suggest.
  14. Apr 19, 2017 at 6:53 AM
    #354
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    When you get to the speed you get the howl, slightly vary the gas pedal from slight coast to 0 acceleration to slight acceleration. If the howl comes and goes I'd suspect the diff.
  15. Apr 19, 2017 at 6:56 AM
    #355
    Canufixit
    New England
    Nice job on the find fix guys! One comment - when covering the holes be sure it will not trap water.
  16. Apr 19, 2017 at 7:24 AM
    #356
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    I'll check mine, but isn't the wheel side lower than the rest of it? Should I poke a hole in the tape? I think I'll just get some LCA armor to move the air away from the holes :)
  17. Apr 19, 2017 at 7:47 AM
    #357
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My truck came with the Lower A Arms plugged from the Factory, only 3 should be plugged so moisture can drain out of the other holes. I can mainly hear my rear diff noise when going downhill and kinda featherthe throttle.
  18. Apr 19, 2017 at 8:14 AM
    #358
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Can you take a pic of the factory solution? Just curious to see what it looks like compared to my "Lowes" solution :D
  19. Apr 19, 2017 at 8:18 AM
    #359
    shakerhood
    Southern Ohio
    I will do that at some point over the next few days, its pouring rain today and not sure if i Will get a chance tomorrow but l will do it.
    smitty99[QUOTED] likes this.
  20. Apr 19, 2017 at 8:24 AM
    #360
    smitty99
    Scottsdale
    Come on mother trucker. Get your lazy ass up off the couch, put on your rubber slicker and your bright yellow galoshes looking like the Gorton's Fishsticks Guy then go out there, crawl under that truck and snap a photo. I always deliver when you ask for it!!!!
    :laugh::rain:
