[SOLVED] Howling noise between 35-45
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBella, Jan 14, 2016.
  1. Aug 27, 2017 at 5:13 PM
    #381
    20TacomaTRD06
    20TacomaTRD06 Member
    TRD SR5 4X4
    Glad you figured it out and posted afterwards. It's hard to troubleshoot a problem or give advice on a forum because someone always wants to be a troll about it. I tried to give advice a long time ago but of course the advice was not apprieciated by some what's funny is this individual is Now....yeah
    TRACKER54 likes this.
  2. Aug 27, 2017 at 5:23 PM
    #382
    TRACKER54
    TRACKER54 2017 TACO 4X4 OFF ROAD ACCESS CAB BARCELONA RED
    MIKE
    Santa Clarita, California.
    3inch suspension lift kit "TUFF Country", TRD PRO Front grille,Bug deflector/vent shades, Trailer controller, Snug top shell SS (COLOR MATCHED) FRONT WINDOW FOLD DOWN, BLACK OAK 20 inch LED CREE light bar (front bumper), WeatherTech floor mats, MOTO METAL "LINKS" CUSTOM 17 INCH WHEELS, BFGOODRICH 17 INCH KO2 TIRES, HI/LOW/FOG "LUMEN" H11XHL C-G7S CONVERSION KIT LED LIGHTS. FOX 2.5 FS RESERVOIR REAR SHOCKS-DSC, HYPERTECH SPEEDODOMETER CALIBRATOR, WHITE KNUCKLE SEMI-GLOSS BLACK POWDER COAT/DOM TUBE ROCK SLIDERS 15 DEGREE ANGLED UP. PIAA BACK-UP LIGHTS.TMJ FRONT ROCK CRAWLER BUMPER, 10,000 LBS SMITTYBILT SYNTHETIC ROPE WINCH, WITH WIRELESS REMOTE CONTROL,MOUNTED INSIDE (UNDER THE LICENSE PLATE). SIDE BUMPER ROCK LED LIGHTS. ANYTIME REVIEW CAMERA - SWITCHED TO INSTRUMENT PANEL.
    I am not sure if you are talking about me or the Shakerhood ?
  3. Aug 27, 2017 at 7:58 PM
    #383
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 17 only has Zerks for the Front Driveshaft also, I think they switched at the end of 16 Model Year.
  4. Aug 27, 2017 at 8:03 PM
    #384
    TRACKER54
    MIKE
    Thank you.
    shakerhood likes this.
  5. Aug 27, 2017 at 8:35 PM
    #385
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    This is what is causing the howl when feathering the throttle or is this something else? If it is just a function of air hitting the frame, I don't see why it's such a big deal.
  6. Aug 27, 2017 at 8:42 PM
    #386
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    No, the howl is from the pinion angle in the rear differential. This is another howl caused by air through the frame holes.
  7. Aug 27, 2017 at 8:43 PM
    #387
    shakerhood
    Southern Ohio
    The A Arms make a Whistling Sound that has been corrected by installing some plugs, the Howling Rear Diff is a totally different issue.
    The Real Moondog likes this.
  8. Aug 27, 2017 at 8:44 PM
    #388
    TRACKER54
    MIKE
    Good evening Kamille, Since you have a 2017 Taco it really dosen't apply. I have a 2017 Off Road and the noise has been alleviated. There seems to be some holes in the lower part of the frame that caused a howling noise-sort of like blowing on a harmonica but with a different sound. You are okay and do not need to be concerened. I hope this helps, Mike.
  9. Aug 27, 2017 at 8:45 PM
    #389
    The Real Moondog
    Moondog
    If only my howl could be fixed by a few plugs.... Like many others, mine came plugged from the factory (February 2017 build date for me).
    shakerhood[QUOTED] likes this.
  10. Aug 27, 2017 at 8:46 PM
    #390
    shakerhood
    Southern Ohio
    Mine was built in March 2017 in Texas and my Lower A Arms came plugged from the Factory too.
  11. Aug 27, 2017 at 9:35 PM
    #391
    trdsupreme
    trdsupreme Well-Known Member
    2017 TRD OR DCLB Silver Sky
    Mine was march 2017 in Mexico; not plugged.
  12. Aug 29, 2017 at 8:54 AM
    #392
    TacoMike281
    TacoMike281 Member
    Dirt road in Aptos
    2017 Tacoma SSM TRD 4X4 OR
    zip
    Mine was May 2017 also in Mexico. Plugged on both sides!
  13. Oct 2, 2017 at 7:31 PM
    #393
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Yes, I checked my 2017 (built May 2017 in San Antonio) and there are only three holes and one is plugged.
  14. Oct 2, 2017 at 7:34 PM
    #394
    shackley
    I wonder then if the 16 ujoints with zirks fit 17s?
  15. Oct 3, 2017 at 2:30 AM
    #395
    44mger
    44mger Active Member
    Had my '17 in for 30k service yesterday. Gave them the TSB, and told them to replace the ones I installed from Lowes with the factory correct plugs. They didn't know what I was talking about, but did what I asked.
  16. Jan 10, 2018 at 8:16 PM
    #396
    corybantictaco
    corybantictaco Member
    The TSB isn't in the dealership system to pop up when they search for bulletins related to 3rd gen tacos. But once you give them the TSB number, they were very accommodating.
  17. Feb 15, 2018 at 8:12 PM
    #397
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    My '18 has this sound but I have yet to go under to see if there are any plugs...are the plugs added from the factory or dealer for '18s at this point?
  18. Feb 15, 2018 at 8:21 PM
    #398
    shakerhood
    Southern Ohio
    The Front A Arm Whistle has been taken care of for some time, my 2017 came with the Lower A Arms Plugged.
  19. Feb 15, 2018 at 8:31 PM
    #399
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    I have an ‘18 and don’t have the whistle from the front end. I’ll try to remember to check mine tomorrow to see if I have the plugs, but I am pretty sure I do. Like shakerhood said I think they all come with them now. Maybe one or two fell out of yours? Or you could be hearing the rear diff howl?
  20. Feb 16, 2018 at 12:01 AM
    #400
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    My truck had 2 plugs in each lower arm from the factory, built Sept 2017 in Baja.
    I think some people have reported 3 plugs in each arm from the factory.
    Strangely enough, on two different days last Fall, both times while traveling eastbound on an uphill grade at approx. 40 mph into a strong headwind on sunny days I heard the howl/whistle or ocarina flute-like sound very loudly for a few seconds. My wife looked over at me and immediately said “what is that?” as she heard it.
    I plugged the additional A-arm holes and drilled smaller 1/8 inch holes into the center of them so that water might possibly drain out. In some years it rains about 270 days or more here.
    I’m not really too concerned about rust in there as I’m sure the arms will be fine for many years, even if rusty, but I sprayed some rust paint up in the holes as best I could prior to plugging them up, just for the heck of it.
    I’ve heard no more howling since placement of the additional plugs.
