Solved: Jerky/bucking acceleration, now: barely acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by License2Ill, Nov 3, 2018.
  1. Nov 3, 2018 at 12:24 PM
    License2Ill
    License2Ill [OP] Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Edit: I updated the symptoms here:
    So I'm having a pretty bazaar issue. In only 4th & 5th gear going up a significant incline above 53mph. I get a jerky cyclic acceleration. Like the whole truck is dry heaving ( or appears that I'm doing so in the driver's seat). No burnt clutch or belt smell or any sign of so.
    Info: Supercharged w/ stock 2.38 steel pulley no fuel mods 75k on SC'r. 1.8K lbs over stock vehicle weight. 3.4L w/ 5 spd manual tranny. 75k on motor, tranny & all the way to the exhaust tip. 25k on Lce procomp clutch & #38 flywheel. 118K on truck.
    Stock AFR readings appear normal. As do TPS readings. No boost gauge to monitor boost. Battery has a bad cell, one’s on order/ Voltage appears good. No codes. Scangauge ii as the monitor.
    A little back story. SC nose seal was leaking slightly. Maybe ¼ ounce at the most weeped out…
    Replaced the seal, degreased the entire engine three times. And it's no longer leaking.
    It started weeping sometime during a 1k mile road trip. Is it possible I saturated the belt? Or/ and glazed my SC and/or crankshaft pulley?
    I'm going to start by replacing the SC'r belt, switch out the SC pulley and crankshaft pulley. Try replicating the issue. If no fix, then I'll move on to getting a boost gauge. Then onto swapping a low mileage used throttle body. The onto the alternator.
    Anybody got any other wise ideas? Knock sensors? Etc?
    @1997tacomav6
    This sound like belt/pulley slip to you?
  2. Nov 3, 2018 at 3:50 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    It could be something with the injectors and/or fuel lines...
  3. Nov 3, 2018 at 3:51 PM
    PennSilverTaco
    Charlie
    Also, it sounds like your engine was rebuilt at about 43,000 miles...? Why, if you don't mind me asking?
  4. Nov 3, 2018 at 3:53 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    That bucking you’re describing sounds like a fueling problem.
  5. Nov 3, 2018 at 4:40 PM
    Glamisman
    Glamisman Well-Known Member
    i am with ^^^. Check the filter then check the pressure.
  6. Nov 3, 2018 at 8:06 PM
    License2Ill
    Ian
    Thanks Guys.
    Um. Swapped the engine and transmission into the double cab @ 95k with the donor @ 54k. No rebuild. Donor was my original truck. Bought the donor back from insurance to not hassle with the 5spd swap. Iyi, double cabs never came in the 5spd configuration on the 1st gen.
    Filter(oem-inline) has less than 10k miles on it. Pump is original @ 118k.
    Here's the thing. AFR shows normal. AFR should lean out, no? I can romp the skinny pedal in 3rd all day long. And it doesn't show me any herky-jerk from what I've experienced. Ive also tested on a full tank vs a tank with two gallons in it. 1st, 2nd & third, no issues.
    I do have an extra tank pump, but I'm not looking forward to that job..
    Thanks for the replies.
  7. Nov 3, 2018 at 9:40 PM
    PennSilverTaco
    Charlie
    That last part I knew...
    Sounds like a classic "The way the manufacturer should have built it" build!
  8. Nov 3, 2018 at 10:04 PM
    02hilux
    Planet: EARTH
    What's your actual afr, other then saying stock?
    During normal driving
    During issue
  9. Nov 4, 2018 at 12:54 AM
    Glamisman
    you are going to need to see fuel trims both short and long term. A few percent either way from zero is acceptable, anything more and there is a problem.
    12TRDTacoma likes this.
  10. Nov 4, 2018 at 8:36 AM
    License2Ill
    Ian
    And in third gear I can see 12.1-1 without the issue appearing.
  11. Nov 4, 2018 at 8:37 AM
    License2Ill
    Ian
    Good shit. Okay I'll program them into the SGii.
  12. Nov 4, 2018 at 8:55 AM
    02hilux
    Planet: EARTH
    Lol
    Your afr under boost (assuming sc is boosting, since there's no guage) seemed fine unless you're experiencing a boost spike which can cause the issue. Tho boost spike is more commonly found on turbo charge setup. But what i don't get is, without a fuel management or enrichment system, how are you able to get 12s in 3rd gear? You should be leaning out under pressure, not running rich.
  13. Nov 4, 2018 at 10:12 AM
    License2Ill
    Ian
    I'm at 5500'. I'm lucky if I get 2# of boost from the SC'R under WOT. I'm never in WOT. SC is strictly for getting my fat ass up a hill & merging onto the highway. The issue arises at medium throttle input (40+/-%) & upper-middle RPM's (3-3.2k).
    I just programmed LTFT 1/2 & STFT 1/2 into the SG. I'll report back the findings mid week.
  14. Nov 4, 2018 at 11:34 AM
    License2Ill
    Ian
    And about seeing AFR in the 12's. Not sure. That's the reading from the stock sensor and the SG giving me the reading. The stock isn't a true wideband. And the SG can show me only between 17 to 12 iifc.
    I've only seen lean conditions a few milliseconds after I engine break.
    I'll look into if I need a specific xGauge code for my ISO OBD AFR instead of the stock code.
  15. Nov 4, 2018 at 11:58 AM
    02hilux
    Planet: EARTH
    Yep, need a stand alone
  16. Nov 4, 2018 at 6:21 PM
    Glamisman
    watch the fuel trims at idle then rev it to 2k and hold and see if they adjust. What you are looking for is does the front o2 sensor fuel trims go rich, a positive number, then start to back off towards a zero reading. Rev and hold at 3k and repeat. No knowing how enrichment under boost is adjusted, I am assuming that positive pressure(boost) on the fuel pressure regulator enriches. If the fuel trims are double digit negative at idle and way positive at 2 to 3k I would suspect the Mass Airflow Sensor.
    After rereading your initial post are you sure that the supercharger is working and not just a big intake restriction?
    12TRDTacoma and License2Ill[OP] like this.
  17. Nov 4, 2018 at 7:03 PM
    CoastieTX
    CoastieTX Well-Known Member
    PNW
    Original owner 1998 Tacoma TRD; 3.4 V6 with 5 MT
    My truck (stock, no supercharger) was doing the same thing. A hill I drove up every day in 4th was suddenly causing my truck to buck and jerk if my speed and RPMs dropped a little. New spark plugs and wires and I was good to go, the difference was dramatic.
    cruiserguy and License2Ill[OP] like this.
  18. Nov 4, 2018 at 8:13 PM
    License2Ill
    Ian
    Thank you. Very easy to understand.
    MAF is the newest part on my truck. And a "Denso" eBay buy. Tested LTFT, earlier. Doesn't look good @ +9%. Swapped to a spare MAP. Reset ECU. Will monitor.
    Supercharger worked fine at SL before the MAP replacement two months ago.
  19. Nov 4, 2018 at 8:17 PM
    License2Ill
    Ian
    Thanks for that.
  20. Nov 4, 2018 at 9:17 PM
    ectrd
    ectrd Well-Known Member
    '04DC
    4 tires, a steering wheel & a seat
    I see your in AZ as you know SC's dont handle heat well , just throwing it out there
