Solved: Loud Rumbling & Tailpipe Smoke (3rd Gen 2017 Tacoma)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vigilance777, Feb 8, 2021.
  1. Feb 8, 2021 at 12:46 AM
    Vigilance777
    Vigilance777 [OP] Active Member
    Ben
    2017 Grey Tacoma 6'
    My 3rd Gen Tacoma is emitting an extremely loud rumbling while spewing smoke out of the exhaust pipe. Sounds and smells like an enriched muscle car but in a bad way.
    I drove the car to work, left it under a covered parking spot for 12 hours, and then started it back up after work. When I started the car, the rumbling noise was immediately apparent and I smelled oil, which I attribute to the smoke coming out of the exhaust pipe. Idling it for a bit longer does not change anything. I didn't want to idle it too long in case the engine oil system is fucked.
    My Tacoma has only 39k miles, is a 2017 model, never been in an accident, and no mods at all. I am the first and only owner. Normal engine oil, coolant, power steering, and even windshield wiper fluid levels. The car is also out of my Toyota warranty period.
    1) What the hell is going on?
    2) Will Toyota as a company do anything about this shitbox they sold to me? It's out of warranty but this is completely unacceptable, especially at 39k miles. This Tacoma has already had a super early dead battery, fucked up seat belts, a Bluetooth system that only works properly 50% of the time, and now this issue which has rendered the car inoperable.
    Thanks and I look forward to your answers.
    Video of the issue below from tonight. I'll try to take a better video during the day.
    Edit: not so much a shitbox. Catalytic converter on driver side was chopped off.
    BigWhiteTRD and boston23 like this.
  2. Feb 8, 2021 at 1:19 AM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Sounds like your cat got chopped.
    Take a look at your exhaust underneath by the trans.
    There should be a missing catalytic converter.
    Edit: The smoke coming out the exhaust is odd tho, maybe you blew a exhaust gasket of sorts, or they tried to take your cat and got spooked before finishing?
    Either way take a look underneath, something is off.
  3. Feb 8, 2021 at 1:41 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I second the exhaust issue. At least where I live, catalytic converter prices are up and they're getting stolen. Trucks and higher sitting vehicles are especially suceptible. Definitely not something that sounds like Toyota's fault. A 1st gen won't help you.
    Sand_In_My_Taco likes this.
  4. Feb 8, 2021 at 2:02 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Why would your 60k mile warranty be up?
    wrightme43, Chew, 2016Tacoman and 2 others like this.
  5. Feb 8, 2021 at 2:49 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yup.
    Cat chop.
  6. Feb 8, 2021 at 2:53 AM
    RedWings44
    Michigan
    Depends on the first "in service" date. Either way, I don't think that 60k covers exhaust issues (I could be wrong). It definitely won't cover stolen catalytic converters though.
  7. Feb 8, 2021 at 4:09 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Exhaust is fubared. Either by collision/road hazard or by crackhead theft.
    Your poll needs a third option
    O Pull head out of ass
    Chew likes this.
  8. Feb 8, 2021 at 4:33 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    sounds like a straight-piped moped
  9. Feb 8, 2021 at 4:36 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    If the converter was removed there would not be any exhaust coming out the tail pipe.:crazy:
    beergeek, MOC221_, auskip07 and 2 others like this.
  10. Feb 8, 2021 at 4:37 AM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Sub’d to see if it really is just a stolen or partially cut Cat...
    MOC221_ likes this.
  11. Feb 8, 2021 at 4:39 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    Sounds to me like a camshaft position sensor is stuck,causing the engine noise and smoke and smell. possible advancing the ignition timing to much. Can you get a hold of a scan tool to see if there are any pending pcm codes ?
  12. Feb 8, 2021 at 4:49 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Someone cut one cat off and i bet the OP never shows back up
    Chew likes this.
  13. Feb 8, 2021 at 5:09 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Looks like he's already been disposed of
  14. Feb 8, 2021 at 10:32 AM
    Vigilance777
    Ben
    2017 Grey Tacoma 6'
    Hey folks. I checked under the car and the catalytic converter is there and seems totally fine. Just verified that it's not steam coming out of the tailpipe, it's actually a thick white smoke and smells like enriched gasoline. I'm thinking this is either a blown head gasket or some sort of oil issue (?). More pics and videos on the way. Will try to get underbody videos or pictures.
  15. Feb 8, 2021 at 10:34 AM
    Sand_In_My_Taco
    NOR*CAL
    That's super loud for there not to be a hole somewhere
    RedWings44, CrazyAirborne and tonered like this.
  16. Feb 8, 2021 at 10:34 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There are four cats total. Two on each side. The aft ones are often stolen.
    Getting white smoke and raw gas smell not out of your tailpipe would be very weird.
    Sand_In_My_Taco and MOC221_ like this.
  17. Feb 8, 2021 at 10:39 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    did you do anything out of the normal... or you just started up the truck and it was like this.
    tonered likes this.
  18. Feb 8, 2021 at 10:55 AM
    MOC221_
    Frank
    Each bank has two converters..
    tonered likes this.
  19. Feb 8, 2021 at 10:59 AM
    Vigilance777
    Ben
    2017 Grey Tacoma 6'
    Can someone provide a picture or diagram so I know exactly what 4 things to look for under there? The exact catalytic converters on the 3rd gen Tacoma undercarriage?
    And yes, I started it up like normal. No, I didn't do anything different or quirky to the car.
  20. Feb 8, 2021 at 11:03 AM
    CrazyAirborne
    CrazyAirborne Who jumps out of perfectly good airplanes?
    Central Wisconsin
    2017 TRD Sport
    laying underneath, trace the exhaust system starting from the tip towards the engine, see if anything is missing or if you see exhaust coming out of somewhere it shouldnt be. with the noise like that, id say theres gotta be a hole or somethings gone
    MOC221_ and tonered like this.
