Solved(Maybe) HALP! Ugly Engine Noise.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FrisbetheButchr, Mar 24, 2023.
  1. Mar 24, 2023 at 1:24 PM
    FrisbetheButchr
    FrisbetheButchr [OP] Well-Known Member
    Austin
    Indiana
    2018 TRD Off Road Cement
    2018 TRD Off Road - 54,500 miles.
    This started a couple mornings ago. It was just a small rattle at idle till it warmed up and then it seemed to go away but today it's been continuous when accelerating. It will stop once back at idle, sometimes , but once you give it gas it's starts up. I spritz some lube onto the belt thinking it was just that but it came right back. I'm wondering if it's my HPFP or maybe a pulley, the belt seems to be okay. I felt around for anything loose or jammed but didn't see much. I think I narrowed it down to around the belt or on top of the engine. Hell, It may even be just that a mouse left a gift for me.
    I'm about to call the dealership ( So its on paper with Toyota and hopefully within the drivetrain warranty) but I'd imagine it wont be going in this weekend.
    https://youtube.com/shorts/wmipZPump3g?feature=share
    https://youtube.com/shorts/Z5JPj8IqUVw?feature=share
  2. Mar 24, 2023 at 1:27 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Oh my poor ears…that sounds horrible. Keep us posted on what it is.
    98_3RZ_NIC and wilcam47 like this.
  3. Mar 24, 2023 at 2:04 PM
    FrisbetheButchr
    Austin
    Indiana
    That second video just hurts my soul.
  4. Mar 24, 2023 at 2:06 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Ooooooufffff! hopefully falls under warranty because sounds expensive lol It Igor not be but sure it does sounds expensive.
  5. Mar 24, 2023 at 2:09 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    My guess would be a pulley bearing going TU. Question is which one!
  6. Mar 24, 2023 at 2:11 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Since you’re waiting. Pull the air box and tube, clean MAFS if needed, check and clean throttle body, check for vacuums that might have gotten lose??
  7. Mar 24, 2023 at 2:11 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Just a wild shot here but timing chain…??? there are plastic guides inside to keep the chain from flexing at speed. I saw something about this and the noise sounds familiar…also didn’t do it at idle just when rpms went up as the guide was not there and the chain starts to whiplash.
    I will check my history and see if I can’t find it. The noise in your vid is very similar and same characteristics.
  8. Mar 24, 2023 at 2:14 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I wouldn’t run the engine anymore. Have it towed to a repair shop so you don’t do any additional potential damage
  9. Mar 24, 2023 at 2:15 PM
    Wenty
    Wenty Well-Known Member
    Minnesota
    2023 Tacoma Sport 4x4 V6
    Clutch on the fan ????
  10. Mar 24, 2023 at 2:18 PM
    Buck Henry
    Amen to that! The next time this engine is started should be by your mechanic.
    PTSDTherapy likes this.
  11. Mar 24, 2023 at 2:19 PM
    PTSDTherapy
    22 SR5 DCSB
    :fingerscrossed::fingerscrossed:A trusted mechanic at that.
  12. Mar 24, 2023 at 2:23 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Take the belt off and see if it does it...
    Corrugated and jjsinaz like this.
  13. Mar 24, 2023 at 2:35 PM
    PTSDTherapy
    22 SR5 DCSB
    Ummmm no don’t start that truck again.
  14. Mar 24, 2023 at 2:39 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Is that with the ac on?
    Corrugated, auskip07 and Skydvrr like this.
  15. Mar 24, 2023 at 2:45 PM
    FrisbetheButchr
    Austin
    Indiana
    Haven't thought of this one. Probably not something I can see without pulling stuff off id imagine.
  16. Mar 24, 2023 at 2:47 PM
    FrisbetheButchr
    Austin
    Indiana
    Think during this video my heat was on but maybe not...
    On my way home today I tried the AC with and without circulation and the heat with and without circulation and it didn't affect anything.
    Jeffch[QUOTED] likes this.
  17. Mar 24, 2023 at 2:50 PM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Sounds more accessory than internal and hopefully just a belt or pulley related but spit balling maybe fan clutch.
    Corrugated, wilcam47 and Skydvrr like this.
  18. Mar 24, 2023 at 2:53 PM
    PTSDTherapy
    22 SR5 DCSB
    Fan clutch is viscous fluid controlled. If it was fan clutch it either would be fully engaged like at start up ( and highly noticeable) or fully disengaged and then he would have overheating issues. The fluid either moves or it doesn’t.
  19. Mar 24, 2023 at 2:54 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Could be belt tensioner. Take serpentine belt off for a short engine run and see what happens. If it is quiet with belt off, put it back on and use a tube or pipe to your ear and point right at different pulleys and listen to see if you can pinpoint the source.
  20. Mar 24, 2023 at 2:59 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Leaning more towards an idler pulley or alternator pulley bearings are shot.
    Pull the belt off and spin the pulleys. One of them is going to make some noise.
    Corrugated, Jesse H and Irons like this.
