Solved(Maybe) HALP! Ugly Engine Noise.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FrisbetheButchr, Mar 24, 2023.
  1. Mar 24, 2023 at 3:00 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    my 18 is at 46k keep us posted please.
    Good luck also!
  2. Mar 24, 2023 at 3:08 PM
    FrisbetheButchr
    FrisbetheButchr [OP] Well-Known Member
    Austin
    Indiana
    2018 TRD Off Road Cement
    My guess is it's one of the pulleys gone bad. I have an appointment tmrw morning. Hoping for something external to be the culprit.
    thomasburk and 513Mugsy[QUOTED] like this.
  3. Mar 24, 2023 at 3:09 PM
    FrisbetheButchr
    Austin
    Indiana
    Will do! We're about one year under that 6yr/60k mile warranty. It starts from the first recorded service date I read earlier.
  4. Mar 24, 2023 at 3:18 PM
    InThePlains
    InThePlains Well-Known Member
    An easy thing to check is to remove the serp belt and run it for a short period of time. If the noise has gone, then you can pretty sure it's one of the accessory drives: water pump, alternator, AC compressor/clutch, etc.
    LeakyAC likes this.
  5. Mar 24, 2023 at 3:34 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Again…don’t start that engine unless you are sure it’s not internal.
    But hey your choice. And it won’t be those giving the advice on here to keep starting it to check shit that are going to be the ones without a vehicle or stuck with the bill if it is something major. Better safe than sorry.
    cryptolime likes this.
  6. Mar 24, 2023 at 3:48 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Since we’re Al just pissing in the wind, My guess is AC clutch / compressor. The compressor will still cycle with the heater / defrost on as an anti humidity thing.
    Jeffch and wilcam47 like this.
  7. Mar 24, 2023 at 4:39 PM
    FrisbetheButchr
    Austin
    Indiana
    Im not starting this thing till it's ready to go in tmrw morning. It such a fine line between being a simple belt replacement to ..oh shit! Your injection lifter is fucked! Lol
  8. Mar 24, 2023 at 4:54 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    with the engine off try spinning the clutch fan.
    Next guess would be belt tensioner or idler pulley
    Final guess would be a/c clutch
    zoo truck and shakerhood like this.
  9. Mar 24, 2023 at 5:17 PM
    21TacoSR
    21TacoSR Active Member
    2021 Tacoma SR V6 4x4
    Dealer would say “it’s a truck!” Or “normal characteristic.”
    All jokes aside sounds like a pulley for sure.
  10. Mar 25, 2023 at 9:30 AM
    FrisbetheButchr
    Austin
    Indiana
    Update:
    Dropped it off with local Toyota. They said it's my water pump that's failed and is leaking onto the belt. Of course they dont have the part for three days but it's $230 for the pump added onto the labor and other garage , total is around $1k....
    Looks like I have to fight a warranty claim as the pump should be included in the power train warranty.
  11. Mar 25, 2023 at 9:38 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Should not be a fight at all, it's pretty clear cut that it's covered. This is from the 2018 Tacoma Warranty and Maintenance Guide regarding what is covered under the powertrain warranty:
    Engine:
    Cylinder block and head and all internal parts, timing gears and gaskets, timing chain/belt and cover, flywheel, valve covers, oil pan, oil pump, engine mounts, turbocharger housing and all internal parts, supercharger housing and all internal parts, engine control computer, water pump, fuel pump, seals and gaskets.
  12. Mar 25, 2023 at 10:19 AM
    FrisbetheButchr
    Austin
    Indiana
    I mentioned that. They are going get with me on Monday when the service manager is in who "Used to work in warranty".
    Steves104x4, Jeffch and auskip07 like this.
  13. Mar 25, 2023 at 10:29 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Amazing the guy wouldnt check to make sure what the warranty covers.
  14. Mar 25, 2023 at 10:45 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Hope it goes well for you!
    Steves104x4 likes this.
  15. Mar 25, 2023 at 10:49 AM
    #35
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Or a tensioner
  16. Mar 25, 2023 at 10:52 AM
    #36
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think you’re gonna dodge a bullet. Good luck!
  17. Mar 25, 2023 at 11:00 AM
    #37
    Bikerscum
    Bikerscum Well-Known Member
    2023 TRD Prem. OR 4 dr. short bed, Adv. Tech, LED headlights, Mag grey
    In that second video that idler pulley is clearly stopping & starting a few times.... like it starts to seize then breaks free.
    I have zero doubt the dealer would replace the pump for 1k then say we should replace that idler "while we're in there".
  18. Mar 25, 2023 at 3:05 PM
    #38
    FrisbetheButchr
    Austin
    Indiana
    I'm not sure on that. I guess if the sound is still there they may dig in a little more but they were able to recreate the metallic sound. The guy said he wanted to take care of the third brake light TSB. Not really my top priority.
  19. Mar 25, 2023 at 6:26 PM
    #39
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Sometimes you literally have to scream and throw a hissy fit, it worked for me once. :anonymous:
    Good luck!! Don't accept no as an answer!
    Junkhead and wilcam47 like this.
  20. Mar 25, 2023 at 6:39 PM
    #40
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I would ask him to show you evidence its the water pump. Then I would confirm its covered under warranty.
    wilcam47 likes this.
