**SOLVED*** Need help FAST!!! Truck will not shift out of park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ptwob311, Sep 10, 2015.
  1. Sep 12, 2015 at 11:29 AM
    ptwob311
    ptwob311 [OP] Curios Noob
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    The plot thickens...
    I go start the truck this morning and the ABS and Traction Control warning lights are on.....
    my code reader shows zero codes
    At least it drives.... taking it to the dealership Monday...
  2. Sep 12, 2015 at 12:33 PM
    ptwob311
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    SOLVED!!!!!
    so it turns out that the wiring harness plug that sits on the lower right side of the fuse panel inside the cab... well, it came loose just a touch.
    pushed it back all the way in and BOOM... everything works as fragged.
    I never touched that plug, and i noticed that the retaining clip is broken on it... so I'll just have to watch it in case it wiggles loose.
    THANKS for all the input guys!
    Hopefully this post will help someone else to learn a lesson I've known for years... when electrical issues are at play, CHECK ALL PLUGS AND CONNECTIONS. hahaha
  3. Sep 12, 2015 at 6:22 PM
    spp
    spp OC, Kalifornia
    OC California
    Put some zip ties on it to insure that it will stay where you want it?
    ptwob311[OP] likes this.
  4. Sep 12, 2015 at 7:00 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm glad you got it fixed! Good work.
