Solved: Needed help - 30k spark plug change and truck will not start - 2014 V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UBYBC, Jun 12, 2016.
  1. Jun 12, 2016 at 12:39 PM
    UBYBC
    UBYBC [OP] Well-Known Member
    2014 Tacoma TRD OR
    Solved Update:
    Changed my spark plugs and the truck would not start. Replacing the failing OEM battery was the solution. Maybe it was bad timing as the OEM battery was 2.5 years old. I applied dielectric grease improperly and got some on the spark plug connector. I cleaned the plugs and boots reinstalled them and installed a new battery. I'm back on the road. Thanks TW.
    Original post:
    Changing my spark plugs at 30K miles and I have made a rookie mistake somewhere.
    I changed each plug one at a time using Denso OEM plugs and torqued them each at 15 ft#. I added anti seize and a dab of dielectric grease to each plug and torqued the coils at 7.5ft#
    Reconnected the electrical connectors well and snapped them in place.
    The dash display flickered and I can hear a very faint "groan" like she's not happy.
    No joy turning the key. I get nothing but a few dash lights. I checked the battery voltage and it reads 12.38V.
    Any help or ideas while I go through it all again? I'm pretty bummed as I really went slow and focused on the job.
    Maybe too much dielectric grease?
    I am stumped at this point.
    Thanks for any assists.
  2. Jun 12, 2016 at 12:40 PM
    Bishop84
    Bishop84 Well-Known Member
    Have someone measure the voltage while cranking, sounds like a battery issue and you're just being super cautious.
    12TRDTacoma likes this.
  3. Jun 12, 2016 at 12:51 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    You did the plugs one at a time? My guess would have been you mixed the wires up, but that doesn't sound like the case... I've never use the grease before so I can't comment on that. Good luck man
  4. Jun 12, 2016 at 1:00 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Does the engine turn over? How many times did you try? Did you disconnect the battery while doing the plugs? I doubt you mixed the wires as they are specifics length going to each coil.
  5. Jun 12, 2016 at 1:12 PM
    Lthompson
    Lthompson Well-Known Member
    this is just a thought.. but where did you put the di- electric grease? di electric means it does NOT conduct.. Meaning you DO NOT put it on any connections. It is there to prevent track over and leakage from dirt and contaminants. So you only put a very small amount around the edges of the plug wires, being careful to make sure none gets on the actual connection.....
    UBYBC[OP] likes this.
  6. Jun 12, 2016 at 1:13 PM
    UBYBC
    2014 Tacoma TRD OR
    Battery reads 5.5v when the key is turned then back to 12.4V at rest. I
    did them one at a time and don't think I could have mixed the wires up. They are set lengths.
    I just went through all six and retorqued etc.
    No change. This sux.
  7. Jun 12, 2016 at 1:14 PM
    Lthompson
    so its not turning over at all? make sure your battery connections are tight
  8. Jun 12, 2016 at 1:22 PM
    UBYBC
    2014 Tacoma TRD OR
    Doesn't turn at all. It's an electrical issue seems like.
    @Lthompson I think I may have applied the grease wrong.
    Pulling them out and cleaning them.
    scottalot likes this.
  9. Jun 12, 2016 at 1:25 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Doesn't turn over at all has zero relation to spark plugs.
  10. Jun 12, 2016 at 1:28 PM
    Lthompson
    Yeah I originally thought it was turning over but not starting,, ie no spark. If its not turning at all, you got a battery/electrical issue. Try jumping it
  11. Jun 12, 2016 at 1:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    Battery should not go below 9v at cranking. Prove the problem with a test, a jump or a known good.
    12TRDTacoma, syswalla and koditten like this.
  12. Jun 12, 2016 at 1:33 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Sounds like your battery is dead. Bad plugs/plug wire connections won't prevent cranking. Per above, see if you can jump start it. If automatic, make sure it's in Park.
  13. Jun 12, 2016 at 1:38 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Did you have the key "on" or in accessory while you were swapping plugs by chance? That would explain it if it is a weak battery.
    I killed the battery in my Outback once because I was listening to music while I was replacing carpet.
  14. Jun 12, 2016 at 1:41 PM
    Lthompson
    I had been driving mine around fine and I took it to the dealer one morning for some work, Right after I left, they called and said my truck wouldn't start. The remote wouldn't even unlock the doors. Just all of the sudden after no issues at all.. I was like "are you in the right truck" It was odd.. I went back,, twisted the cable connections on the battery posts.. Turns out they were slightly loose.. Started fine after that. Battery could be bad.. could just have a bad connection.
  15. Jun 12, 2016 at 1:42 PM
    UBYBC
    2014 Tacoma TRD OR
    Battery was disconnected while swapping plugs and it was fine up until this job.
    The
    battery connection is good.
    If I applied the grease wrong would the computer not see a good connection to each plug and not allow it to start?
    It's pouring rain and really hot outside. So please excuse any typos.
    I'm on my iphone.
  16. Jun 12, 2016 at 1:43 PM
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    I agree with others, sounds like a battery problem. Make sure your terminals are tight...
  17. Jun 12, 2016 at 1:49 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    As everyone stated, you can grease the hell out of the sparkplug connection but the computer doesn't read it. It would still crank but not actually start. Stupid idea but had to do it a lot on my jeep. Put truck in neutral if positive it's not the battery then try to start it. My neutral safety switch was a tricky bitch and thought the jeep was in R when it was t engaged all the way so if rock it or put in in Neutral
    syswalla likes this.
  18. Jun 12, 2016 at 1:50 PM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    OP, I'm assuming the engine does not turn over when you turn the key to start it - correct? If so, chances are your battery is discharged or has gone bad. As others have said, try jumping it and see if it starts. If it turns over but does not start clean the areas where you applied the dielectric grease and try again.
    While your battery is only two years old it's not impossible for it to have gone bad. Hot weather is one of the hardest things on a battery. In any case, a battery charger is a handy thing to own and they're not terribly expensive. Might be a good time to invest in one. Use the money you saved doing the plugs yourself.
  19. Jun 12, 2016 at 2:03 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Any chance the engine is locked up? Something fall inside the cylinder head?
  20. Jun 12, 2016 at 2:06 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Dude just try a jump start. Fast easy and cheap to eliminate a likely problem. Stop asking more questions and go try it.
