Solved: Needed help - 30k spark plug change and truck will not start - 2014 V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UBYBC, Jun 12, 2016.
  1. Jun 12, 2016 at 7:26 PM
    #41
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    4.0L is on 30k mile rotation, where as 2.7L is 100k
  2. Jun 12, 2016 at 7:39 PM
    #42
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I've seen that movie. The TrueStart batteries the dealers sell have all failed way too early for me. Could have been a bad batch, but I'll never buy another one.
  3. Jun 12, 2016 at 7:54 PM
    #43
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    I ended up buying a Sam's Club model after AutoZone sold me a half sized battery. I was at the grocery store with a full cart of food in AZ during summer. Turned the key and nothing. A couple of days before that I just had a inspection at the local Toyota dealer and battery readout was in the green.
  4. Jun 12, 2016 at 8:15 PM
    #44
    UBYBC
    UBYBC [OP] Well-Known Member
    2014 Tacoma TRD OR
  5. Jun 13, 2016 at 1:55 AM
    #45
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Not for nothing but dielectric grease seems like a bandaid for not making sure your electrical connections are solid. If you have arcing across the plug wires they need replacing anyways. Dirt isn't conductive and water shouldn't collect there so why bother with the stuff.
    12TRDTacoma likes this.
  6. Jun 13, 2016 at 3:14 AM
    #46
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Did you look at the video above? It's very informative. Looks like OP had grease on the connection part. BTW, if the battery is 12V+ at rest and then 5.5V when cranking...best way to test your battery is get another car next to it... and use jumper cables and try to start another car with your battery. Your battery should be disconnected from your car. So if your battery starts the other car... you got a short somewhere and it's gonna kill that battery and something else.
    If your battery didn't start the other car... take the other car's battery and see if you can start your truck with it...if it reads 5.5V again...you got a short on your truck. If you want to be really safe... take an ohm meter and measure the resistance and see if it makes any sense...if you by chance have another Tacoma in the neighborhood that you can measure the resistance and compare...also give you some more information.
  7. Jun 13, 2016 at 3:23 AM
    #47
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I had a Ford battery go bad at 9 months. Fortunately I had boat with me and used one from boat. Unfortunately it was a Sunday and I had to get one that fit properly so I could not wait for dealer to open on Monday. Battery on my 2009 Prerunner took dump at less than 3 years.
  8. Jun 13, 2016 at 3:52 AM
    #48
    3coma
    rob
    I understand how it works, my point is if you have cracked boots or wires they need replacing anyways.
  9. Jun 13, 2016 at 10:15 AM
    #49
    Ndrorder
    Ndrorder Member
    Cliff
    New Mexico
    B. Red TRD Sport
    None --- yet!
    I use di-electric grease to lubricate the plug/boot. It makes the next removal easier. Not all greases are di-electric so I'd rather not risk an inadvertent short. YMMV.
  10. Jun 13, 2016 at 10:23 AM
    #50
    UBYBC
    2014 Tacoma TRD OR
    Installed a new battery and the truck started up like it should.
    I went to Batteries Plus down the street and ordered an X2 AGM. They gave me a Duracell to use for the week while the new X2 ships from Wisconsin.
    Went by the dealer and they said they will replace the battery for free but I have to leave/wait (4-6 hours) on the truck/battery to go through a system check. There was a line out the door so I opted to not spend my whole day waiting on them. I may go back later this week and at least try to get a free one I can keep as a spare. I'm thinking they will balk when they see I have 12V power leads running off the positive terminal to a pop n lock, led dome light in the camper shell and a small stereo amp.
    I did get grease on the connection of a couple plugs and it may have caused the OEM battery to crap out. IDK.
    Either way I'm on the road and thank all you guys for educating me and supporting my issue. I'll update the OP as solved.
    TRlPPlN, TacomaMike37 and scottalot like this.
  11. Jun 13, 2016 at 10:31 AM
    #51
    stump jumper
    Bill
    Texas
    grease on your plugs had NOTHING to do with the OEM battery crapping out.
  12. Jun 13, 2016 at 10:36 AM
    #52
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have done hundreds of spark plug wire/ spark plug replacements on various makes and models using brand new parts (obviously). I don't waste my time with that shit. If the wires are going to arc, that tells me that either A. The wires are cheap, and their boots don't insulate worth a damn or B. The overall engine spark plug location design is garbage.
    Never have I used, and after watching that video, I still am not going to. You don't tear the boot upon removal, you tear the wire terminal inside because it grips the plug too tight. Either way, most often it is repairable. If you don't want the boot to stick for next time you remove simply twist the boot at its baseleft and right to make sure it is free. If it is a cheap ass set of wires the terminal inside will tear anyways.
  13. Jun 13, 2016 at 10:42 AM
    #53
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Only time I've ever used dielectric grease is actually on the metal threads of outdoor porch light bulbs, which were blowing out after a very short life. I thought it might be due to high humidity. Only applied a very thin coat, and bulb life was greatly increased. After reading the discussion and watching the video here, I assume threading the bulb "cut" thru the grease I applied. Have NOT had a problem with bulb life since, and have been doing this for at least 5 years.
  14. Jul 28, 2016 at 7:37 AM
    #54
    UBYBC
    2014 Tacoma TRD OR
    Sorry for the delayed update but I finally got through the dealership process. Good news!
    First visit the service rep said he needed the truck all day for a full diagnostic. He spoke to me like I was wasting his time. I wasn't prepared for this so I opted to return today 15 mins prior to the service shop opening and be first in line.
    A new service tech said "No" to replacing the battery because "you already bought a new one". I stayed calm and was polite and said I had my tools onboard and could simply go out to his driveway and swap my new battery with old one, let the truck sit there and start the conversation over.
    He looked me in the eye for a moment and then said he would talk to his manager. A couple more minutes went by (no manager got involved) and then he said he would put a new battery the the truck bed for me to take home. He became really friendly and actually was a really nice guy from then on.
    Since I already have an X2 installed, I guess this new battery will make a good spare or help me recoup cost towards the X2.
    Sucks that they tried to turn me away at first. Should not be that way. But they did make good on it. Really just depends on who you get and how you act at the service desk. Thanks again for all the help fellas.
    scottalot likes this.
  15. Jul 29, 2016 at 6:53 PM
    #55
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I don't mean to hi-jack (and maybe a new thread is in order) but this whole dialectric grease thing has me going...I've used the stuff for years on automotive and atv electrical connections and never had any issues. Is it that big of a deal? Like my atv I use it to "waterproof" the connections for lights, etc. On my vehicles, I always shoot a dab into the plug wire boot before putting them on. Somebody somewhere told me it was a good idea to do it and I always have. Now I gotta rethink this.
  16. Jul 29, 2016 at 7:03 PM
    #56
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I've never had any issues with dielectric grease, although the times I use it sparingly.
  17. Aug 26, 2016 at 12:28 PM
    #57
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    I'm confused. I have a 2014 DCLB and my owners manual doesn't state anything about changing the plugs at 30k. I've checked several times.
  18. Aug 26, 2016 at 12:29 PM
    #58
    4x4cajun
    Fredericksburg, VA
    2014 Limited 4x4
    I have a 2014 DCLB and mine says the same.
  19. Aug 26, 2016 at 12:41 PM
    #59
    shakerhood
    Southern Ohio
    Read the Manual closer, the V6 gets plug changes every 30K and the 4 goes 100K.
  20. Aug 26, 2016 at 12:59 PM
    #60
    4x4cajun
    Fredericksburg, VA
    2014 Limited 4x4
    Ok all, So only having had this truck for a short time and just finishing up my last free oil change, I did go back and compare books that came with my truck. The "WARRANTY & MAINTENANCE GUIDE" vs the "Toyota Manual" that came with the truck are not the same when it comes to these recommendations. In fact the "WARRANTY & MAINTENANCE GUIDE"...DOES state the V6 4.0L gets spark plug changes at 30k; see page 41.
