SOLVED over heated and now wont start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Killbot707, Nov 5, 2021.
  1. Nov 7, 2021 at 2:57 PM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    Since you found the cause of your dying issue I would just drive it locally and keep an eye on the temperature. There may not be any need to do anything more at this point..
  2. Nov 7, 2021 at 3:00 PM
    tcjacado
    tcjacado Well-Known Member
    Top of the first post... please edit thread title since its solved and you no longer need advice on not starting.
  3. Nov 7, 2021 at 4:51 PM
    Killbot707
    Killbot707 [OP] Member
    95 toyota tacoma
    Thanks ill do that. I appreciate the help and everyones replies.
  4. Nov 7, 2021 at 4:53 PM
    Killbot707
    95 toyota tacoma
    Yes i just changed the fluid and put new radiator in. I have not bled it yet.
  5. Nov 7, 2021 at 4:53 PM
    ArizonaBrian
    Please post a follow up ..I don't like cliffhangers :)
    Killbot707[OP] likes this.
  6. Nov 7, 2021 at 4:56 PM
    Killbot707
    95 toyota tacoma
    I know some of you wont like this but if i discover that the head gasket is "slightly" damaged. Would it be wise to use some sort of liquid head gasket sealer. Since hg replace is so expensive that i would most likely be finding a new engine and would just like to get as much out of this one as possible without putting a ton of money into it?
  7. Nov 7, 2021 at 4:57 PM
    Killbot707
    95 toyota tacoma
    Will do
  8. Nov 7, 2021 at 5:12 PM
    ArizonaBrian
    I personally wouldn't do it on a vehicle I intend to keep or restore at some point but if it's a matter of junking it or driving it I wouldn't have a problem doing it. In my experience you can expect to get less than a year out of the liquid head gasket fixes before they fail again. It's temporary at best. At least it was for me.
  9. Nov 7, 2021 at 6:44 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    On my 1986 Toyota pickup, my head gasket failed at around 180,000, I replaced it myself and put a new timing chain at the same time, my old truck now has 350,000 miles and is still going strong. I personally would never use those temporary fixes especially with a vehicle I intended on keeping!
  10. Nov 7, 2021 at 8:30 PM
    elw00d
    elw00d Member
    01 Tacoma 3.4 V6
    I think you’re stressing too much. No CEL.. it’s running… keep an eye on temp, coolant and oil and drive on :cool:
  11. Nov 8, 2021 at 1:34 AM
    Killbot707
    95 toyota tacoma
    Thank you bro! I very much agree. Just drove it around town for a good hour. She's running like nothing ever happened, still got the power even pushing the 35s i got on her and she never even went above 7/16s on the temp gauge!. I just thought for sure i couldnt have been this lucky. And then the MAF sensor just happening to fail at the same time . Squashed my hopes from the get go.
    So at this time im gonna take your advise and drive on. No overheating no smoking no milky no sweet stinky... one this is for certain tho Never will i risk pushing a hot engine to keep driving AAA i need a membership pronto.
    Thank every one for your comments and responses im very greatful to receive your guys/ladies wisdom and time
    elw00d[QUOTED] and Kevins60 like this.
