SOLVED! Post 2853 Leaking Injectors, Dealer Techs Rock! Extended Cranking after Engine Swap 3.4L 5vz
Discussion in '1st Gen. Tacomas (1995-2004)' started by lovemytacolots, Dec 5, 2014.
Thread Status:
Not open for further replies.
  1. Apr 25, 2015 at 5:41 PM
    #2741
    lovemytacolots
    lovemytacolots [OP] Show your Taco some love every day!
    Jen
    Oregon
    98 3.4L V6 5vzfe 4wd TRD Off Road
    It starts correctly now, thanks to the best dealer tech ever.
    Sweet, I am relieved to hear that! I wondered and was a little worried about that......didn't you realize when you were post #2 that there are no breaks allowed from this thread, vacation or not? :D
    Hell yeah, definitely, post away with the pics!! But you realize I'll have to use the cute little thread jack emoticon since I rarely get to use that one :DWe'd love to see what ya catch! :) Have a blast man!
    EDIT: Realized I had a perfect opp to use it now - [​IMG]
    EDIT #2: I gotta say, TW has the best little guys like that of all the forums. Wow, that was a highly intelligent, critically important observation :rolleyes:
  2. Apr 25, 2015 at 6:01 PM
    #2742
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Duly noted. Will make special efforts to use correct vernacular.
  3. Apr 25, 2015 at 6:24 PM
    #2743
    lovemytacolots
    Jen
    Oregon
    Oak Kitchen Cabinets, refinished by yours truly....
    This is less than half of the cabinet doors. And let me tell you the fun it was taping plastic sheeting to block off the kitchen then sanding the actual cabinets. Good times. I never want to pick up another sander or poly brush again. :D
    This also happens to be the shed we contemplated rebuilding the old engine in. Kinda wish we would have done that, considering all we wound up teaching ourselves anyway! :rolleyes: It actually almost sounds fun to me now! :eek:
  4. Apr 25, 2015 at 6:51 PM
    #2744
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I ran this down and i don't think it would cause it. About the only thing would be if they got to aggressive putting the lines together on top of that, or installing the pump, and pinched/cracked the bonded feed and vent tubes on top of the plate. I guess a inspection mirror could be used to take a peek up there and see.
    It's a straight forward installation inside the tank. So long as a modicum of intelligence was used to install it. (knock on poly coated cabinet doors!) Knock Knock, Knock!
  5. Apr 25, 2015 at 7:31 PM
    #2745
    lovemytacolots
    Jen
    Oregon
    Thanks for looking into it Mod :)
    Just tried adding a new sig....let's see if it works......
    Good thing I didn't try to make it a mirror decoration : )
  6. Apr 25, 2015 at 7:36 PM
    #2746
    koditten
    Kirk
    Central Michigan
    It works, but kind of depressing. Not fitting to you guys personality. please try something else. And yes, I know what it is, regardless if it the start of this thread.
  7. Apr 25, 2015 at 7:37 PM
    #2747
    40950
    CR, WA
    stock
    Kinda looks like a armour piercing bullet punched a hole thru that thing (Waylon and Hank Jr knows what I am talking about),,lol.
  8. Apr 25, 2015 at 7:45 PM
    #2748
    koditten
    Kirk
    Central Michigan
    That's why it looks so familiar! It looks exactly like a full, metal jacket punching through plate steel. .223 rounds especially.
  9. Apr 25, 2015 at 8:00 PM
    #2749
    lovemytacolots
    Jen
    Oregon
    OK, I thought about changing it when I read K's 1st comment, but now it seems like you guys are having fun with this : )
  10. Apr 25, 2015 at 8:06 PM
    #2750
    koditten
    Kirk
    Central Michigan
    It's your thread. I'm all for variation. I'm partial to doggies, Toyota's and home improvement projects. Any thing works. I change mine all the time. Go nuts!
  11. Apr 25, 2015 at 8:10 PM
    #2751
    lovemytacolots
    Jen
    Oregon
    OK, I will! : )
  12. Apr 25, 2015 at 8:12 PM
    #2752
    lovemytacolots
    Jen
    Oregon
    Southeastern Oregon is the prettiest place!! Taco was a champ on all those crazy roads. Definitely going back to that area again someday. We saw two bighorn sheep, just hanging out, next to where we hiked. I could stare at that scenery 24/7.....
  13. Apr 25, 2015 at 8:19 PM
    #2753
    koditten
    Kirk
    Central Michigan
    Nice! No wonder we want to retire to left coast.
  14. Apr 25, 2015 at 8:23 PM
    #2754
    lovemytacolots
    Jen
    Oregon
    Hell yeah! You guys HAVE to. We say that all the time.......Koditten and his wife gotta move out here! You'll love it! And we can help each other with Taco repairs! :D
  15. Apr 25, 2015 at 8:31 PM
    #2755
    koditten
    Kirk
    Central Michigan
    Give us 8 years. Who knows if we can really retire. So much weird shit going on with economy, you really can't plan that far ahead. The only thing I know is now:)
  16. Apr 25, 2015 at 8:56 PM
    #2756
    BamaToy1997
    Bill
    Navarre, FL
    If memory serves correctly, the 1st gen Tacoma does not actually apply power to the fuel pump until the engine starts cranking. Turning the key on doesn't energize the fuel pump.
  17. Apr 25, 2015 at 9:05 PM
    #2757
    trx125
    trx125 Well-Known Member
    Correct, the computer turns on the pump after it receives feed back from the crank, cam and maf sensors that the engine in turning over(safety feature I think). Turns off the pump it no engine rotation is detected. You can jumper the pump to test if it works with engine off.
  18. Apr 25, 2015 at 9:09 PM
    #2758
    trx125
    I have you tested both fuel pump relays after it has been warmed up to see if both are working correctly?
  19. Apr 26, 2015 at 6:13 AM
    #2759
    koditten
    Kirk
    Central Michigan
    Great. How do I post pics from phone with this new format?
  20. Apr 26, 2015 at 6:17 AM
    #2760
    keakar
    keakar Well-Known Member
    karl
    louisiana
Thread Status:
