SOLVED! Post 2853 Leaking Injectors, Dealer Techs Rock! Extended Cranking after Engine Swap 3.4L 5vz
Discussion in '1st Gen. Tacomas (1995-2004)' started by lovemytacolots, Dec 5, 2014.
Thread Status:
Not open for further replies.
  1. Aug 11, 2015 at 8:39 AM
    #4961
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I am just scared my friend is going to get trapped into another "damned if you do, damned if you don't" situation.
    most front end stuff is no big deal and you don't "have to" fix it until the wheels start wobbling causing vibrations when you drive it, but nothing is just going to "fall apart" on you.
    at this point if the boots are torn just add a little grease in there and wrap the shit out of em with duct tape, they are just a cover to keep dirt out so if you can seal it up, that's all it needs to be good.
  2. Aug 11, 2015 at 8:40 AM
    #4962
    lovemytacolots
    lovemytacolots [OP] Show your Taco some love every day!
    Jen
    Oregon
    98 3.4L V6 5vzfe 4wd TRD Off Road
    It starts correctly now, thanks to the best dealer tech ever.
    Thanks, this is the kind of advice I was looking for, trying to better understand in general what kind of danger this crap can cause.........
    BTW, sounds like we should be glad that you lived to tell the story on that one???!?!? :rofl:
  3. Aug 11, 2015 at 8:41 AM
    #4963
    lovemytacolots
    Jen
    Oregon
    Seriously?!??!?!? You can duct tape your torn boots?!??!?!?!? :yes::laughing:
  4. Aug 11, 2015 at 8:42 AM
    #4964
    lovemytacolots
    Jen
    Oregon
    That, my friend, is right up there with resolving a no start problem via a paper clip. :yes:
  5. Aug 11, 2015 at 8:42 AM
    #4965
    keakar
    karl
    louisiana
    I don't know, it depends if they fell apart or if it just split cleanly in two. if its a clean split, then yes duct tape will work, if its falling apart then no, there is nothing left to it to hold its shape and you have to replace it.
  6. Aug 11, 2015 at 8:43 AM
    #4966
    lovemytacolots
    Jen
    Oregon
    Maybe we should run a contest to see who can come up with the most hillbilly, half assed way to keep bandaiding the Civ back together. C'mon, she only needs to run a few more months guys. We can do this. I have lots of duct tape and rubber bands. :laughing:
  7. Aug 11, 2015 at 8:44 AM
    #4967
    lovemytacolots
    Jen
    Oregon
    Compliance bushings = rubber bands?
    :rofl:
  8. Aug 11, 2015 at 8:45 AM
    #4968
    lovemytacolots
    Jen
    Oregon
    Elmer's glue = torn boot repair? :laughing:
  9. Aug 11, 2015 at 8:45 AM
    #4969
    keakar
    karl
    louisiana
    well if you want to get real red neck then wrap it with a bread bag lol
    lovemytacolots[OP] likes this.
  10. Aug 11, 2015 at 8:45 AM
    #4970
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    No, duct tape will NOT work, maybe for a day or three, and yes, stranded on side of freeway after a rather loud and scary massively vibrating stop.....
  11. Aug 11, 2015 at 8:45 AM
    #4971
    lovemytacolots
    Jen
    Oregon
    Wait, what does that even mean??!?!? :laughing:
  12. Aug 11, 2015 at 8:46 AM
    #4972
    lovemytacolots
    Jen
    Oregon
    oh shit, that doesn't sound very funny...............:pout:
  13. Aug 11, 2015 at 8:46 AM
    #4973
    keakar
    karl
    louisiana
    take the plastic bag the bread comes in, remove bread, wrap boot, tie ends if bag together in knot :thumbsup:
  14. Aug 11, 2015 at 8:47 AM
    #4974
    lovemytacolots
    Jen
    Oregon
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Fuck's sakes, has it really come to THIS??????????????????? :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
  15. Aug 11, 2015 at 8:49 AM
    #4975
    lovemytacolots
    Jen
    Oregon
    Alright TW, gotta get some crap done. Have a good day and be sure to think of clever ways to rebuild the Civ front end for basically free, mmmmmkay everyone? :D
  16. Aug 11, 2015 at 8:53 AM
    #4976
    keakar
    karl
    louisiana
    hey you wanted cheapo fixes and that's as shade tree red neck as it gets lol.
    seriously though, I had duct tape on my steering boots for over a year and it never came off and it worked fine. but bldegle2 has a point in that the cv joint in there is like a u-joint spinning around so if you are going to tape it you need to be sure not to alter its shape because it needs the clearance so nothing gets caught up in the spinning u-joint. as long as you use good quality tape there should be no issues
  17. Aug 11, 2015 at 8:57 AM
    #4977
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    replacing the boots is fairly EZ, remove axle nut. turn wheel completely right or left depending on which side you are working on, yank axle out of hub assembly (axle will stay attached to transmission), take off old boot, regrease and install new boot, make sure the zip clips are tight, reinstall in reverse order...DO NOT turn tire and rim when the axle is out, not good for the bearings...your biggest problem is going to get the 185 ft lbs torque to clamp it down, or whatever Honda requires, this is what VW's torque specs are...it has to be fairly close, the bearings need the proper torque to keep them happy...
    Yes, duct tape will work on a steering rack, but not on a rotating, grease loaded CV cover...get real people, fix it right, the parts are not that expensive for this particular repair...
  18. Aug 11, 2015 at 9:19 AM
    #4978
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've broke 4 CV joints on front wheel drive cars over the years. Every one broke while backing up and turning very sharp right or left. I never had one break while just plain driving.
    My 1998 Tacoma lost a boot at 26000 miles. I drove it to 300000 miles with no grease. I knew they were most vulnerable while backing up and turning, so I did not do that.
    My vote is to just squish some grease in the thing and nothing more.
    They are easy money for most shops, so they always get mentioned to be repaired.
    Worry about something else with this car.
  19. Aug 11, 2015 at 9:26 AM
    #4979
    lovemytacolots
    Jen
    Oregon
    Thanks for the advice guys!!!
  20. Aug 11, 2015 at 9:32 AM
    #4980
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    koditten you got lucky, but as you said, you broke four CV's on front wheel drive vehicle over the years....it is far more expensive to replace a constant velocity joint or a whole axle...since they are headed down the minimal repair route, do the boots right, with their luck and the wet weather that abounds year round in the Pacific Northwest the water will leach the grease rather quickly...
    when mine went, it wasn't pretty, and all I was doing was driving straight down the freeway, fortunately, I had an extended warranty that covered the repairs, except for towing....
    a set of two boots, clips and two bags of grease will set them back about $30 from fleabay....for a little more, you can get split boots which do not require axle removal, around $40 or so for a set of two...
Thread Status:
