SOLVED! Post 2853 Leaking Injectors, Dealer Techs Rock! Extended Cranking after Engine Swap 3.4L 5vz
Discussion in '1st Gen. Tacomas (1995-2004)' started by lovemytacolots, Dec 5, 2014.
Thread Status:
Not open for further replies.
  1. Jan 20, 2015 at 2:55 PM
    #701
    lovemytacolots
    lovemytacolots [OP] Show your Taco some love every day!
    Jen
    Oregon
    98 3.4L V6 5vzfe 4wd TRD Off Road
    It starts correctly now, thanks to the best dealer tech ever.
    Thanks guys. Yep it's very frustrating....
    And you're right Kigmob, it's not like we'd return it, and at least we won't have to question it's function. Yet assuming our new guy confirms 100% that it's the pump, it would then seem pretty darn likely that the pressure test done by the previous mechanic was somehow done incorrectly, right? I don't know. I know a bunch of you are going to rip on me now for ripping on the mechanic, but there's a line there of what's fair, and I feel we were left on the side of the road with our diagnostic issues once we paid $6k for the engine. And that's not right, even if they were honest mistakes, like we all make. There should have at least been more concern/assistance in guiding us on the right path to get it resolved, and there wasn't.
  2. Jan 20, 2015 at 2:56 PM
    #702
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    Post #341 by me:)
  3. Jan 20, 2015 at 2:57 PM
    #703
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  4. Jan 20, 2015 at 3:10 PM
    #704
    lovemytacolots
    Jen
    Oregon
    So true Knuckle, this is your moment, shine away buddy! You called it specifically very early on, great job man!
  5. Jan 20, 2015 at 3:11 PM
    #705
    lovemytacolots
    Jen
    Oregon
    Thanks K!:)
  6. Jan 20, 2015 at 3:11 PM
    #706
    lovemytacolots
    Jen
    Oregon
    OK, guy just called. Listen up, he gave me lots of info.....
  7. Jan 20, 2015 at 3:13 PM
    #707
    lovemytacolots
    Jen
    Oregon
    He checked for codes, with a tool that I'm sure gives more info than SG - no codes.
    He is repeating the fuel test one more time still to be 100% certain (I LOVE THIS GUY!) but he is absolutely certain it's a fuel issue. Said he tested for spark, it was good. Tested for compression, it was good. Thinks wiring harness & ECU are fine, being as how they seem to be reporting the appropriate info/making the appropriate adjustments - said we're not running too lean or too rich.
    More coming..
  8. Jan 20, 2015 at 3:14 PM
    #708
    koditten
    Kirk
    Central Michigan
  9. Jan 20, 2015 at 3:15 PM
    #709
    lovemytacolots
    Jen
    Oregon
    With the stripped thing, he said your supposed to use a line wrench to remove the bolt at the fuel rail to connect the gauge, but SOMEONE used something else and stripped it, so he had to break it free w/vice grips. He realized somewhere into that that he was opening a new can of worms and stopped and tightened it back up. He assured me he looked at it closely and it's not leaking there.
    More.....
  10. Jan 20, 2015 at 3:16 PM
    #710
    knuckleduster271
    ohio
    98 sr5 xtra cab
    Pretty confident you and hubby could diy the fuel pump easily lifting the bed, it takes more time imo this way but it saves you from dropping the tank and if theres a couple people doing the job together it should go really smooth.
    Takes no special tools and is very straight fwd.
    Truck is drivable now- order the pump from rock and save $ doing the install yourself.
  11. Jan 20, 2015 at 3:17 PM
    #711
    lovemytacolots
    Jen
    Oregon
    He tapped in by the filter. He said his in line gauge has a "shut off" on it, so he closed the valve while starting it at the 1/2 hour mark and it started right up, so this is why he thinks it's the pump....
  12. Jan 20, 2015 at 3:18 PM
    #712
    lovemytacolots
    Jen
    Oregon
    I asked if there's any chance we also have leaky injectors, he said when he closed his gauge it would have been a slow drop in pressure if they were leaky, plus we'd see black smoke when starting, so he's pretty certain no leaky injectors....
    more....
  13. Jan 20, 2015 at 3:19 PM
    #713
    lovemytacolots
    Jen
    Oregon
    I asked about concern over fuel going places where it shouldn't, like the new bearing oil, he said he will double check all that, but he doesn't think that's an issue......he said w/new engines, alot of times you'll have a funny oil smell from the special oil....told him husband thought it was an oil odor, not a fuel odor, and he agreed, he thought it smelled like oil too.....
    more...
  14. Jan 20, 2015 at 3:20 PM
    #714
    lovemytacolots
    Jen
    Oregon
    The best part.........this guy is saying so far all we owe him is $50!!!!!!!!!!!!!!! I LOVE THIS GUY!!!!!!!!!!!! FINALLY FOUND A NEW MECHANIC THAT WE CAN TRUST AND HE'S ONLY A FEW MILES FROM HOME!!!!!!!!!
  15. Jan 20, 2015 at 3:29 PM
    #715
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Glad every things working out! It seems obvious that the other mechanic did not check the fuel pressure every which way (like he said).... unless he was not doing it correctly.
  16. Jan 20, 2015 at 3:32 PM
    #716
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    You gunna tell the old mechanic that it was the pump/fuel issue??
  17. Jan 20, 2015 at 3:36 PM
    #717
    lovemytacolots
    Jen
    Oregon
    OK, our NEW AND FABULOUS mechanic just called - he used to be a freaking Master Mechanic at TOYOTA!!!!!!! Talk about a happy ending!!!!!!
    more....
  18. Jan 20, 2015 at 3:37 PM
    #718
    lovemytacolots
    Jen
    Oregon
    He said he's going to repeat the test again and if it starts right up when he has the gauge closed, he'll know it's the pump....
    more..
  19. Jan 20, 2015 at 3:38 PM
    #719
    lovemytacolots
    Jen
    Oregon
    He said I ASKED A VERY GOOD QUESTION about why good cold starts if fuel pump is the culprit...
    (my moment of basking and gloating)......
    more.....
  20. Jan 20, 2015 at 3:39 PM
    #720
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Framed! I call recount. a 3 min vote between posts?,,sheeshh. I had like a 2 paragraph going, explaining the wet check system,,,scratched it and typed wet check,,and the voting booth slammed shut? You have gone interweb nutty!.:D I even had little bits and pieces about where to place said fuel check gauge,,and I scratched it away. shit!
    Send mine to DP!, because he doesn't make that shit up. New sig DP. Glad you found the golden knight mech,,who got shit done in a hurry.
Thread Status:
