SOLVED! Post 2853 Leaking Injectors, Dealer Techs Rock! Extended Cranking after Engine Swap 3.4L 5vz
Discussion in '1st Gen. Tacomas (1995-2004)' started by lovemytacolots, Dec 5, 2014.
Thread Status:
Not open for further replies.
  1. Feb 13, 2015 at 7:48 PM
    #1841
    lovemytacolots
    lovemytacolots [OP] Show your Taco some love every day!
    Jen
    Oregon
    98 3.4L V6 5vzfe 4wd TRD Off Road
    It starts correctly now, thanks to the best dealer tech ever.
    Don't want to jinx it, but it started pretty darn normally with the AFR gauge disconnected. Reset the timer for 30 min (~20-25 left now) to see if it's a fluke or what.
    Also, husband did the jumper wire thing with the timing belt again. He did it this weekend already, but this time he said he left it on there longer, and repeated it twice. And he's thinking (from talking to the dealer tech) that he may have been resetting the timing by doing that? Not sure, you guys might know. Anyway, he said this time the timing was PERFECT. The little tick marks/numbers range from 8 to 12, and he said both times it landed right at 10.
    So if what he did actually changed something, rather than just checking something, it's possible that decent 30 min start was from that, or from the AFR gauge being disconnected. Or it's possible it was a fluke. Not getting even remotely excited yet, we've been down this road enough times by now. We'll see how it starts in ~20 min, then MAYBE we'll get a little bit excited. Or go back to reading about TB & IAC valve cleaning/gasket replacement.
  2. Feb 13, 2015 at 7:52 PM
    #1842
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'll be excited for both of you. I won't be able to hear about results til Satuday Good luck.
    KO.
  3. Feb 13, 2015 at 7:54 PM
    #1843
    lovemytacolots
    Jen
    Oregon
    Thanks K! :) Have a great weekend, treat that lovely wife of your right!! :)
  4. Feb 13, 2015 at 8:49 PM
    #1844
    lovemytacolots
    Jen
    Oregon
    OK. 2nd decentish start at 30 min mark. Set the timer for 45 min this time, and there's 24 min left til next start right now. It's weird, these last two starts weren't normal and weren't awful either. They were in between. More than the typical normal 2 crank/revolution stuff, but not the 5-10 seconds of crank time either. More like 2-4 seconds. And the only variable that's different is disconnecting that AFR gauge. And whatever husband did with timing - still not sure if he actually changed something, or just checked something by doing that jumper wire thing. And I suppose, with the new TPS sensor we installed last night, then with all the driving I did today, and much of it being semi high speed (~40-60mph average on country roads for ~2 hours), maybe it's possible that sensor is starting to change something? Don't know. Had really hoped and felt determined to pinpoint whatever the fix was by doing ONE thing at a time, in hopes of others being helped by the thread, but of course my #1 goal is for the issue to be resolved! Trying REALLY hard to not allow myself to get excited right now.........we'll see in ~20 min how we do.
  5. Feb 13, 2015 at 9:38 PM
    #1845
    lovemytacolots
    Jen
    Oregon
    3rd nearly normal start. Not getting excited. Not getting excited. Not getting excited. Set timer for 1 hour this time, ~45 min left. Gonna scarf some dinner then head back out. Not getting excited. Not getting excited. Not gonna go there..........yet..........not gonna hope that all the main supporters log on ASAP, cuz probably nothing to get excited about........not getting excited............
    Here's one of my other top 5 Waylon faves in the meantime........it's kinda Valentine's-ish.........or maybe I've had too many Buffalo & gingerales? Nah, it's sweet, definitely.
    https://www.youtube.com/watch?v=3DNSzCYgLDQ
  6. Feb 13, 2015 at 9:46 PM
    #1846
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Been sick and not following last week or so, glad to see good news. Hopefully tomorrow yields more!
  7. Feb 13, 2015 at 9:50 PM
    #1847
    lovemytacolots
    Jen
    Oregon
    Feel better PeeRunner! Thanks for all of your positive comments throughout, they are much appreciated each and every time! :)
    37 minutes to next start......time to chow and NOT get excited or hopeful whatsoever..........
  8. Feb 13, 2015 at 10:00 PM
    #1848
    T4RFTMFW
    Thanks, haha. We're headed to bed but I miiiiiiight check back to see the update. Crossing my fingers for ya.
  9. Feb 13, 2015 at 10:27 PM
    #1849
    lovemytacolots
    Jen
    Oregon
    Here goes everybody..........if this one's good, we're declaring victory.......
  10. Feb 13, 2015 at 10:29 PM
    #1850
    T4RFTMFW
  11. Feb 13, 2015 at 10:49 PM
    #1851
    lovemytacolots
    Jen
    Oregon
    Holy shit. I think its fixed. Husband is plugging AFR gauge back in and we're restarting in 30 min to see if that makes the excessive crank come back. If it does, we know what it was. If it doesn't, it's gotta either be that he reset something with the timing when he did the jumper thing, or the new TPS followed by the driving I did today allowing the ECM to figure out that it was replaced.
    It's still not a completely normal start, it's just a tad bit excessive, but no where near the shit we've been having the past month. And I could see any of the 3 possible culprits simply being a matter of a bit more driving/time to fully correct, meaning if AFR was it, maybe the ECM needs some driving to realize it's gone now. Or if it was the timing, maybe needs some driving to recognize it was reset to perfect. Or if TPS, maybe the driving I did today got the ECM to mostly adjust to the new one, but didn't quite learn it 100% til more driving is done. We are going to do all that we can to figure out which of the 3, cuz after all this shit, we deserve to satisfy that curiosity that has kept us awake at night for soooooooooooo damn long. And you all deserve to know too.
    Still scared to fully celebrate after all we've been through but DAMN close to running down the street screaming and breaking open bottles of champagne in the bed of the Taco to start an all night PARTY. God, I am so f'ing scared to get excited. But that was 2 good 30 min starts, 1 good 45 min start, and 1 good 1 hour start. In a row. Hard to call ALL of that a fluke. Holy shit.
  12. Feb 13, 2015 at 11:26 PM
    #1852
    lovemytacolots
    Jen
    Oregon
    HOLY FUCKING SHIT.
    AFR gauge for sale.
    Taco is fixed. Closing summary post coming soon..........
  13. Feb 13, 2015 at 11:28 PM
    #1853
    lovemytacolots
    Jen
    Oregon
    :D Congrats K!
  14. Feb 13, 2015 at 11:35 PM
    #1854
    lovemytacolots
    Jen
    Oregon
    Post #989, January 26. If ONLY I'd followed my instincts way back then, good grief. Could have saved ourselves nearly 3 weeks of pure hell and I don't even want to know how many $$$$$. Wow. This is blowing my mind.
  15. Feb 13, 2015 at 11:47 PM
    #1855
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Couldn't sleep so had to check in.
    Congrats Jen. Hope it works like it should for you guys.
  16. Feb 14, 2015 at 12:51 AM
    #1856
    lovemytacolots
    Jen
    Oregon
    Thanks Mod!! Soooooooooooooo happy right now! Best possible outcome too - there wasn't a damn thing wrong with our Taco, she was just like, get this weird f'ing thing off me, I don't like it!!! Honestly, it's gotta be that they installed it wrong, cuz plenty of people have those and I doubt they're all having hot start issues.
    Hurray!! Taco lives on, woo hoo!! And lovemytacolots gets to have a nice long peaceful slumber for the first time in a long time!! Definitely gonna be a mimosa morn, was too late to crack the bubbly tonight! :D
    :taco::taco::taco::taco:
  17. Feb 14, 2015 at 3:02 AM
    #1857
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    X2!!^^^^^
    Wholly shit!? You've got to be kidding me? That stupid guage was it the whole time!?? Damn! Of course it would be something easy and miniscule and after it all you guys are the ones to get it figured out! Man...I sure hope its still good news when I check this novle of a thread in the morning.
  18. Feb 14, 2015 at 3:59 AM
    #1858
    koditten
    Kirk
    Central Michigan
    Well, I believe this is a face/palm moment. I am . Speechless.
  19. Feb 14, 2015 at 6:01 AM
    #1859
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I've got some followup questions...did you get the AFR box and manual when the first set of bozo's installed it? If not, it might have been a used one they had pulled off something else and had lying around. And if they installed it, on their suggestion, they ARE responsible.
    Glad to see it got fixed, amazed to find out the data acquisition tool was CAUSING the problem.
  20. Feb 14, 2015 at 7:13 AM
    #1860
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    OK fine.......The one with the vacuum hose.
    Yes it is.
Thread Status:
