[SOLVED] Serpentine / #2 idler pulley ticking - with audio/video
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GilbertOz, Mar 1, 2024.
  1. Mar 1, 2024 at 5:50 PM
    GilbertOz
    GilbertOz [OP] Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    2014 AC V6 / 6MT 4x4 TRD OR, ~77K on the odo.
    New, distinctive & repetitive ticking sound from front end, audio included below. No this is not "Tacoma Tick."
    -- EDIT, 2024-03-20 SOLVED this problem by replacing the bearing in the #2 idler pulley above the alternator. --
    Sound started within ~1 week or so of my driving at 30mph through 1 foot deep water for a few hundred feet, throwing up tons of water under/around, including covering the windshield completely for a couple of seconds. A flooded roadway, no deeper - this was not a deep stream fording attempt.
    Two audio clips follow, one raw/unprocessed with video to show location, the second clip is processed to isolate out the tick/chirp and also show the waveform.
    Raw video/audio:
    https://www.youtube.com/watch?v=EkEQta2cc9w
    Processed audio:
    https://www.youtube.com/watch?v=ZHvcPWUR65s
  2. Mar 1, 2024 at 6:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Give that fan/water pump a wiggle with the engine off and see how much play it has, that fan looked a little wonky with it running.
    TnShooter and BlkDakDave like this.
  3. Mar 1, 2024 at 6:30 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    Sounds like a bearing. Water probably introduced debris into it. Pull the belt off and spin the idler & tension pulleys. Examine the belt too....could be a small pebble in the rib.
    GilbertOz[OP] and BlkDakDave like this.
  4. Mar 2, 2024 at 7:42 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, do this^^^^^
  5. Mar 2, 2024 at 9:48 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Like Dm93 said, Start grabbing things and shaking.
    I too think the fan looked like it was "Unbalanced" in the video.
  6. Mar 2, 2024 at 10:18 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If nothing else run it for a short period with the belt removed. If the noise goes away you know it is one of the driven components.
    GilbertOz[OP] likes this.
  7. Mar 20, 2024 at 4:25 PM
    GilbertOz
    CA
    Follow-up:
    This noise was caused by the early failure phase of the bearing in the #2 idler pulley above the alternator going bad.
    Pressed out the old bearing destructively using a socket & soft-faced dead-blow hammer against the inner race. Pressed in a new bearing using a slightly-janky improvised pressing method, with a large tie-rod end puller tool.
    (I would not advise trying to use a hammer-and-socket method to set and press in a new bearing in this case. Too hard to drive it exactly straight into the pulley.)
    The puller arms left small dings on the pulley surface, just barely tactile to the fingernail. (See close-up photo.) Smoothed them out a bit with a brass wire bristle brush.
    Also changed serpentine belt.
    The replacement bearing is a knock-off, we'll see how it holds up.
    2024-03-20_15-07-59_1280px.jpg 2024-03-20_15-11-29_1280px.jpg 2024-03-20_15-10-15_1280px.jpg 2024-03-20_15-10-12_1280px.jpg 2024-03-20_15-10-25_1280px.jpg
  8. Mar 20, 2024 at 4:35 PM
    GilbertOz
    CA
    Just following up on this --
    That was caused by overlapped rolling-shutter effect from two different LED light sources. Overhead shop light & LED headlamp both have PWM drivers that, in combination w/ the phone camera shutter speed & rotation speed of the fan blades made it appear wonky. IRL it did / does spin true & straight.
