(SOLVED) Subtle “thud” when coming to a stop, then accelerating.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Andrew.arw, Jul 14, 2023.
  1. Jul 14, 2023 at 7:53 AM
    Andrew.arw
    Andrew.arw [OP] Chief Beer Officer
    South Carolina
    2018 Toyota Tacoma TRD OR 3.5 V6
    *** Current Setup - 2/27/24 *** - Wheels // Method 316, 17” - Tires // 275/70/R17 // Falken WildPeak A/T4W - Suspension // 2.5” lift // Eibach’s Pro lift, Stage One - front & rear // Eibach Pro Springs // Icon AAL // TC UCA’s - Lights // Rigid Industries Dual Pod’s [Grille] // Rigid Industries Dual Pod’s [Rear Bumper] // Rigid Industries 40” LED Bar [Roof Rack] // XenonPro Hi/Lo Beam // LASFIT Switchback Fogs - Auxiliary // Switch-Pro controller, SP-9100 Series - Audio // Rockford Fosgate R500X1D Amplifier // Dual Rockford Fosgate P1 10" Subs - Accessories // TRD Pro Grille // Prinsu Roof Rack // Rough Country Soft Tri-Fold Tonneau - Armor // Body Armor Rear Bumper, 4x4 Desert series // TRD Pro Skid Plate - Misc Mods // ECGS Bushing // Cali Raised AC Drip relocate // CMC
    Hey y’all.
    So, for a bit now, I’ve noticed something of a “thud” when coming to a stop (at the very point of stopping) and again when I take off.
    I have suspicions that it may be related to a u-joint or driveshaft. However, my local mechanic said “everything looks good” but.. you know how that goes.
    anyway, anyone have any thoughts? I swear it feels more in my front end, but again, they say everything looks normal.
    I’ve also noticed more of a “rough” ride. Like.. something is out of balance.
    While I cannot cite this, I did have my needle bearing swapped a while back, I’m hoping something didn’t shave off and make its way in my front dif :p
    Looking for any thoughts, ideas, or starting points! Thank you.
  2. Jul 14, 2023 at 7:58 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Check the ball joints, lca and body cab bushings as well as your engine mounts.
    TacoGeeloor likes this.
  3. Jul 14, 2023 at 8:02 AM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    I’d say get the truck on jack stands and start shaking suspension, brakes, and drive line related items. Things will move but shouldn’t be sloppy. For the drivelines I’d just check them yourself again for peace of mind.
    Gunshot-6A likes this.
  4. Jul 14, 2023 at 9:05 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    FWIW I went through this recently and after retorquing all my suspension components, greasing my SPC UCA and getting an alignment, it was actually just my RCI skid plates. Thin nylon washers at the metal-on-metal mounting points solved it.
    Gunshot-6A, LeakyAC and TacoGeeloor like this.
  5. Jul 14, 2023 at 9:09 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Could be your front suspension bushings where the lower bolt goes thru starting to go bad. Or LCA and/or UCA bushings too.
  6. Jul 14, 2023 at 9:09 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pretty sure what you are describing is just axle wrap, which gets worse or more pronounced with a lift/bigger tires
    cgs2k2, whatstcp, 12TRDTacoma and 2 others like this.
  7. Jul 14, 2023 at 9:18 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Its really hard to check u joints unless you pull the driveshaft and inspect each joint for abnormal play. Even the slightest amount of play can translate into an audible clunk.
  8. Jul 14, 2023 at 9:28 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I check u joints by crawling underneath and shaking the piss out off the driveshaft.
    A thud at start and stop could also be broken motor mount.
    My 2 cents.
  9. Jul 14, 2023 at 10:13 AM
    newbbewb
    newbbewb Active Member
    D
    14 sport Doublecab
    I had a 2nd gen 4wd that was stock come into the shop with upper control arm bushings making a slightly thump noise at stop and go speeds. Also, in my 3rd gen I’ve noticed when I’m above 1/2 tank of gas that there’s a bit of noise from the gas moving around
    Taco22trdor likes this.
  10. Jul 14, 2023 at 11:35 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    you might include specs, if you have a lift, suspension mods, tire size etc
    Clearwater Bill likes this.
  11. Jul 14, 2023 at 11:38 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Trying lubing up the Slip-Joint on your rear axle. It takes a teflon based lube for it. What happens is it dries out and the the splines are not allowed to slide back and forth freely and it catches and releases then.
    cryptolime, fxntime and scocar like this.
  12. Jul 14, 2023 at 11:40 AM
    scocar
    scocar Patron of the Farts
    Can't remember if 3rd gen have a slide yoke on the drive shaft. If so, gve it 3 pumps of grease.
  13. Jul 14, 2023 at 11:40 AM
    scocar
    damn beat me by a minute
  14. Jul 14, 2023 at 11:43 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    This.
  15. Jul 14, 2023 at 11:43 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds exactly like what is axle wrap.
    Of course it would help if the OP stated whether it was coming from the front or the back to help with the follow up replies to help him.
    cgs2k2 likes this.
  16. Jul 14, 2023 at 11:44 AM
    JFriday1
    Jesse
    Lakewood, CO
    HA!
    No zerk there though. Have to take the axle out, mark everything when removing so that it goes back together in the same place.
  17. Jul 14, 2023 at 11:57 AM
    scocar
    wtf. How much is the omission of a zero saving.them.
    cryptolime likes this.
  18. Jul 14, 2023 at 11:58 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You beat me to it. Hah!
    The suitcase shaped gear case behind my rear seat goes thud when I stop and thud when I go. One of these days I will rearrange things to make it stop.
    Also I think if a person trusts this forum than their mechanic, they need a new mechanic.
  19. Jul 14, 2023 at 12:20 PM
    JFriday1
    Jesse
    Lakewood, CO
    I agree, I hear of people having to do this 1-2 a year. I wonder if you can just drill and tap a zerk in their so long as you can clean up the inside splines?...........
  20. Jul 14, 2023 at 12:49 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Does it sound like a rolling bowling ball just before the thud?
