Solved: thanks everyone! My suspension sways me round right round like a record baby
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rastopher, Jun 1, 2021.
  1. Jul 19, 2021 at 8:59 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    :gossip: Be sure to let us know if the new springs did not get rid of all of the side-to-side sway...
  2. Jul 21, 2021 at 1:33 PM
    Rastopher
    Rastopher [OP] Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Checked this morning, looks like 34psi all around. Tires are sailun terramax ht. 265/70/r16. Does that help?
  3. Aug 4, 2021 at 11:56 AM
    Rastopher
    Ras
    Sacramento, Ca
    Issues pretty much solved, thanks to everyone for your input and patience. Final update:
    conclusion: People make mistakes, but the original shop should have caught the issue between the two times I brought it in asking them to check the suspension and steering. The steering rack was barely hanging onto the frame, bolts were finger tight at best. Scary. Being loose was the root cause of my issues, along with worn out sway bushings. The alignment i got after the shock install didn’t take because the rack was still moving all around.
    I tightened the rack to spec myself, replaced sway bar bushings, then went to a local alignment shop for alignment. my toe was way off. After alignment, life is good. Springs are still old as hell and should be replaced but my truck is 1000% better than before.
    Still pretty bitter at that first shop though. I’m not going back to that damn “mechanic” shop again, which is a shame because their communication was great, just not the service.
    Steves104x4 likes this.
  4. Aug 4, 2021 at 12:00 PM
    Rastopher
    Ras
    Sacramento, Ca
    My body roll issues were drastically reduced by replacing my original sway bar bushings. Not even end links, just the main ones. Used moog, it was ~$15 and an hour of time.
  5. Aug 4, 2021 at 12:04 PM
    Rastopher
    Ras
    Sacramento, Ca
    Any update? And try replacing sway bar bushings. Easy, cheap, made a drastic difference for me.
  6. Aug 4, 2021 at 12:06 PM
    Rastopher
    Ras
    Sacramento, Ca
    I can say with confidence that you’re correct, but after fixing sway bar, rack torque, and alignment it isn’t a huge deal…. Yet.
  7. Aug 16, 2021 at 9:39 AM
    cjaz
    cjaz Well-Known Member
    chris
    philly
    I replaced all this stuff and the truck feels like crap on the road. Like the shocks and springs are doing nothing. I'm wondering if there is something wrong with the body of the truck that I just can't see. There are no strange noises though. Just got back from the dealer and none of their most experienced mechanics could understand why it's the way it is, unless there is something wrong with the parts.
    Upper control Arms (complete arms with new bushings) (48630-35030 and 35050)
    Lower control Arm bushings (48061-35040 and 35050)
    Springs ( 48131 AD010 and AD040)
    Shocks (48510-A9050)
    Upper strut supports (48609-35010)
    Upper Ball Joints (43310-39016)
    Lower Ball Joints (43310-39016 and 43330-39556)
    Sway bar links (48820-35040 and 48810-35020)
    Sway bar bushings (48815-35090)
    Gear assembly insulator (45517-35010)
    All new Cam bolts (4840935050 and 4845235020)
    New mount bolts (9008011283)
    New upper control arm Bolts and nuts (90105-14105 and 90179-14062)
    New passenger side CV Boot kit (04438-04021)
  8. Aug 16, 2021 at 3:27 PM
    Rastopher
    Ras
    Sacramento, Ca
    Chris, are you saying it’s stiff? Or soft?
  9. Aug 16, 2021 at 4:09 PM
    cjaz
    chris
    philly
    extremely soft, like the shocks are providing zero dampening.
  10. Aug 18, 2021 at 6:00 AM
    skeezix
    Colorado
    1998 Limited
  11. Sep 6, 2021 at 7:50 AM
    cjaz
    chris
    philly
    Problem appears to be solved by switching out the new OEM shocks and springs with Bilstein 6112's. The 6112's are much heavier duty shocks with a 600lb spring. There is significant difference in effort it takes to manually compress the 6112 shocks vs OEM. The OEM shocks look more like something you would see on a mountain bike. They are really skinny.
