[Solved] Well I F'd up... any tips or pointers are appreciated
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BSFord, May 21, 2019.
  1. May 21, 2019 at 1:41 PM
    #41
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Mothers and dont look back.
    Nunya Bizness likes this.
  2. May 21, 2019 at 1:41 PM
    #42
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I would sand it and paint it black with high heat automotive paint. That's if you wouldn't mind it being black, obviously.
  3. May 21, 2019 at 1:42 PM
    #43
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    steel wool or scotch brite pad. then paint it with high temp black paint. problem solved.
    StayinStock likes this.
  4. May 21, 2019 at 1:42 PM
    #44
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Oh yeah? I see. Thanks for the info.
    I had been considering doing it the way @Sociopenguin had his set up. Chopped off after it jumps the rear axle, I believe?
    stun gun and tonered[QUOTED] like this.
  5. May 21, 2019 at 1:42 PM
    #45
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! I was hoping for a mandrel bend, but . . .
    I like the slight, extra rumble. It killed my thoughts of a cat back.
  6. May 21, 2019 at 1:43 PM
    #46
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    #46
  7. May 21, 2019 at 1:43 PM
    #47
    Nunya Bizness
    Or you could just hit the tip with some heat resistant flat black paint.
    It looks better than chrome imo
    shwokee, tcjacado, tonered and 3 others like this.
  8. May 21, 2019 at 1:45 PM
    #48
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  9. May 21, 2019 at 1:47 PM
    #49
    ResearchMonkee
    Derrick
    KCMO
  10. May 21, 2019 at 1:50 PM
    #50
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Get some mothers or never dull
    toku58 and Nunya Bizness like this.
  11. May 21, 2019 at 1:51 PM
    #51
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
    Looking back, I'm still in on the dump, as long as I have the spare stocker in the crawlspace.
    The alternative can be keeping the cut section and use a clamp on union and swap in a clamp on turn down tip. We cut up the original tail section trying to make an expanded tip. No go with the HF expander tool. The exhaust shop did have a laugh about it.
  12. May 21, 2019 at 1:52 PM
    #52
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Try a magic eraser , they worked for me when other stuff didn't .
    Jaggerbub likes this.
  13. May 21, 2019 at 1:57 PM
    #53
    wawuzit
    wawuzit Well-Known Member
    steve
    Clinton, Tennessee
    2019 gray 4dr Tacoma TRD
    none
    Motorcycle shops sell a paste chrome cleaner called Simichrome. I'd try that.
    https://www.amazon.com/Simichrome-3...chrome+polish&qid=1558472253&s=gateway&sr=8-3
    If that doesn't work you may have to sand and paint it flat or glossy black.
  14. May 21, 2019 at 2:07 PM
    #54
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    OP I have an OEM chrome tip for sale :boink:
  15. May 21, 2019 at 2:29 PM
    #55
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    tonered[QUOTED] likes this.
  16. May 21, 2019 at 2:31 PM
    #56
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. I got tired of seeing mine either covered in grime in the winter or covered in grime from the trails. Now, it all in good balance out back, not good crush it, and it rumbles nicely.
    stun gun[QUOTED] likes this.
  17. May 21, 2019 at 2:33 PM
    #57
    stun gun
    Aaronski
    Tacomas.
    I got tired of seeing it hang lower than an early bird special nutsack. Thing dropped like a foot.
    tcjacado and tonered[QUOTED] like this.
  18. May 21, 2019 at 2:35 PM
    #58
    stun gun
    Aaronski
    Tacomas.
    It’s like- if you’re sad about ruining the finish on your chrome tip, TURN THAT FROWN UPSIDE DOWN and AMPUTATE.
    tcjacado and tonered like this.
  19. May 21, 2019 at 2:37 PM
    #59
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I was admiring the thin bumper and high exhaust on a new Raptor raging by on the freeway. Nice clearence for a stock setup.
  20. May 21, 2019 at 2:40 PM
    #60
    BlueRidge19
    BlueRidge19 Well-Known Member
    '21 OR DCLB
    Spray/soak with oven cleaner and immediately wrap in tinfoil to hold oven cleaner to pipe. Let sit for 30 minutes. Remove foil and take fine brillo pad to it. It will clean right up. Did the same thing to chrome exhaust on Harley.
