[SOLVED!!!] What's the strangest reason your truck wouldn't start? (Yes, I need help)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gabronius, Apr 19, 2021.
  1. Jun 12, 2021 at 12:08 PM
    #101
    Gabronius
    Gabronius [OP] Well-Known Member
    Gabriel
    1985 SR5 Reg Cab
    1996 Tacoma 3RZFE, Halogens, 4” lift
    Thanks for the suggestion. The relay is good; the fuel pump turns on and gets fuel to the rail (verified by smell and by cracking the banjo bolt). The problem (in my opinion) is the signal that temporarily grounds the fuel injector, allowing it to spray fuel into the cylinder and the subsequent signal to the ECU telling it there is fuel in the cylinder, and the follow-on signal to the distributor to fire the coils and send spark to the plugs. For some unknown reason, I get no injector impulse and therefor no spark at the plugs. I’m leaning towards crank position sensor, because from my understanding this is where that initial signal comes from. The resistance on the OEM plug and the replacement (Bosch/Duralast) part both check out according to the FSM. However, as people have stated before, Denso to be sure...so maybe I’ll order another OEM crank sensor.
  2. Jun 12, 2021 at 2:06 PM
    #102
    Lefthook
    Lefthook Well-Known Member
    New jersey
    2014 DCLB
    Tonneau cover
    As I stated earlier in your diagnosis - is the distributor shaft turning when you crank the engine? Seeing the rotor turn while cranking the engine should show you this. If it doesn't spin, you will not trigger the computer for the pulse needed to fire the engine up. Just a thought.
    Gabronius[OP] likes this.
  3. Jun 12, 2021 at 11:52 PM
    #103
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    You've got this backwards. The ECU receives the crank/cam position signal and determines when to spark each cylinder. The ECU sends the signal to the igniter which sends the signal to the coil. When the coil fires it sends an electrical pulse back to the igniter, and finally the igniter sends a signal back to the ECU to verify the coil fired. If the ECU doesn't receive this for a few consecutive spark cycles, the ECU will stop grounding the fuel injectors, thus cutting the fuel to the cylinders.
    The tachometer uses the IG- signal to determine RPM. In older cars this was the ignition coil negative. On these trucks the IG- is generated by the igniter based on when the coil is fired. If your tachometer isn't showing any RPMs when cranking then it's not getting that IG-. Someone else might verify that the tachometer actually moves while cranking because I'm not sure that the RPMs are high enough to register on the tach.
    Seems like you need to verify the proper voltages at various spots. In particular the distributor.
    A repair manual might explain how to test for the spark signal coming out of the ECU. You want to divide and conquer to find out what is causing it to not spark.
    Gabronius[QUOTED][OP] likes this.
  4. Jun 26, 2021 at 2:48 PM
    #104
    Gabronius
    Gabriel
    1985 SR5 Reg Cab
    [SOLVED!!!]
    Thanks to everyone here who helped me sort through all of the potential causes of my no fuel/no spark issue with my 1985 4x4/1995 Tacoma 3RZ swap. As some of you suggested, the crank position sensor was the culprit. It wasn't the distributor, the ORS wiring harness, grounds, igniter, etc. I had already replaced the CPS once, and really didn't think that was the issue but it was. Today I replaced it [AGAIN] despite never thinking that could have been it since I already replaced it once and the original bench-tested within specs according to the FSM. So, two crank position sensors, within Toyota factory service manual specifications were actually bad. That tells me that the resistance test on the CPS is completely unreliable. I won't ever forget that in the future!
    I've got some things to sort through still, such as a high idle (~1100 RPM), difficulty shifting into 1st or Reverse (probably synchros), and some rough steering (maybe need to bleed the power steering or just add more fluid). Then I can FINALLY get to making her roadworthy again. On the list right now is an exhaust system, cab stripping and lining/soundproofing/carpeting, wheels and tires, upgraded lift (hi-steer probably), and finally either paint or Line-X on the exterior. I've been waiting on these to see if I could get her running first. It's been a long road that started last October. Thanks to you all for your troubleshooting suggestions and help. I tried every one of them, and some of them more than once. But in the end, it was just a faulty crank position sensor that I first changed out months ago.
    Since starting this project to get my Dad's 1985 4x4 upgraded and back on the road, he has lost most of his memory, recognition skills, and cognition to dementia. He won't ever remember this truck or selling it to me just a few years ago, but I will always know that it used to be his, and I'm keeping it alive so that the memory of him driving it won't ever die.
    Thanks again.
    Gabe
    Rastopher, SLAPS 65, DrZ and 5 others like this.
  5. Jun 26, 2021 at 6:20 PM
    #105
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I knew it!!!
    Congrats on getting it running. :woot:
  6. Jun 27, 2021 at 3:30 AM
    #106
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    105 Pages......I read most of them, and really got scared right along with you. Was the Crank Position Sensor new.
  7. Jun 27, 2021 at 10:01 PM
    #107
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    Congrats on getting it running! I’ve been following this thread hoping for this outcome. Way to stick with it!
    Sorry to hear about your dad, I’m going through something similar and it’s hard to say the least.
  8. Aug 14, 2021 at 8:47 AM
    #108
    Gabronius
    Gabriel
    1985 SR5 Reg Cab
    Yes, it was. But it was not OEM.
  9. Aug 16, 2021 at 4:32 PM
    #109
    Gabronius
    Gabriel
    1985 SR5 Reg Cab
    For anyone interested, my rundown on the 3RZ swap is posted on Pirate 4x4. Here is the link. Also, I just finished cleaning out my throttle body and IAC valve. She's idling around 750-800rpm instead of the 1200-1400 when I got it started. What a difference! Hopefully, this will help my gas mileage too. Thanks again to all who stuck with me through the troubleshooting.
    DrZ and tacofish like this.
  10. Apr 6, 2024 at 3:42 PM
    #110
    Conner2510
    Conner2510 New Member
    Conner
    Red Toyota Tacoma 95 2.7
    None
    Having same problem as you. But I change the crankshaft sensor already and still got a no start.
  11. Apr 6, 2024 at 3:44 PM
    #111
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Does the horn work?
