Solving trans flares...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbs1, Nov 20, 2017.
  1. Nov 20, 2017 at 11:12 PM
    dbs1
    dbs1 [OP] 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    I've had my 2015 TRD sc equipped taco showing 9.5 afr just prior to shifting and have concluded it's doing so due to the transmission slipping just before the shift. Wondering if there is a somewhat affordable way to solve this?
  2. Nov 21, 2017 at 5:06 AM
    Pigpen
    Dan
    Northwest Montana
    Auto or manual?
  3. Nov 21, 2017 at 6:05 AM
    dbs1
    Dan
    Auto.
  4. Nov 21, 2017 at 6:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    How did you reach that conclusion?
    Does a data logger show a correlating RPM spike or something?
  5. Nov 21, 2017 at 6:39 AM
    dbs1
    Dan
    I'm not saying I know it for sure, but when watching the afr gauge at wot it will show 10.5, then just a split second before the shift I'll see 9.5, then I'm getting a backfire, then the shift, which I'm supposing is a wash down of fuel being ignited and having noticed the trans with that slightly long shift and flare with raised rpm I'm putting the two together.
    Having had a GM product that did this prior to losing some gears in the auto trans then the trans all together has me thinking this is the same thing?
