Some clarification please
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Mar 18, 2011.
  1. Mar 18, 2011 at 11:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hey guys, i have a 96 Taco and i am coming to find that aftermarket parts for my tuck are dang near impossible to find...is there really that big a difference between my truck and say a 98-04??
  2. Mar 19, 2011 at 10:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bump.
    No one know?
  3. Mar 19, 2011 at 10:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I don't think that is accurate.
  4. Mar 20, 2011 at 12:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Try finding aftermarket Leafs with out moddin the mounts
    Or head lights even. Bumpers and shocks arent a problems and all the motor stuff is usually the same sept that i cant SC with out havin some hicups because of ECU stuff.
  5. Mar 20, 2011 at 12:44 AM
    newskooler
    newskooler Well-Known Member
    Nick
    Mount Shasta, Ca
    1997 ext cab base, 2012 Base Access cab, 2018 trd OR
    Mall Crawler
    Give wheelers jingle before ordering to clarify. thats what I would do.
  6. Mar 20, 2011 at 8:12 AM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    i do know the 95.5 to 97 leaf springs are shorter then the 98-04 ones but i think pretty much everything else is the same
