some help with an arb deluxe bull bar wiring the fogs and turn signals.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stunt man hans, Jul 31, 2011.
  1. Jul 31, 2011 at 3:04 PM
    stunt man hans
    stunt man hans [OP] DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i now believe that i was given the wrong parts for my fogs and turn signals. everything is installed and now i just need to wire the fogs and indicators up and it will be done!
    i have a regular cab tacoma so my truck did not come with the factory fog lights and it appears the kit 4wp's supplied to me is for trucks that have a factory harness. already in place:facepalm::bananadead:
    i need to know if arb sells or even makes an honest to goodness harness for their fog lights / turn signals that will be a complete wiring solution for the lights? i have the switch and switch cover but the harness is incomplete at this point leading me to have no lights and or signals.
  2. Jul 31, 2011 at 3:10 PM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    I got this from trdparts4u.com in reguards to the arb bumper. Maybe it will help.
    For vehicles without factory fitted fog lights, parts # MD02, 180209 and 180215 are required.
  3. Jul 31, 2011 at 3:13 PM
    GreatBasinTaco
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    md02 is the wiring loom, 180209 is the switch base and 180215 is the switch cap
  4. Jul 31, 2011 at 6:53 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i have the switch and the switch cover those part numbers are correct, but 4wp's struck again they sent me the completely wrong parts even after i supplied them with the correct ones three times...
    lol this bumper was my "final compensation" as they put it. so i will try to call them on monday to see if they can send me the right parts so i can finish the install but, i'm not holding my breath.
  5. Aug 1, 2011 at 5:52 AM
    JimT
    JimT Active Member
    Jim
    Indiana
    2016 DCLB TRD Offroad
    I doubt any of it will be as neat and pretty as you would like. I had the factory foglamps, but the wiring that comes from ARB is not a direct connection. IIRC, the blinker and parking lamp had a real harness with a connector, then a mating connector that had wires coming out the back. Had to use those clip/splice things to hook into the truck lights. ARB foglamps just had a couple wires hanging out the back. I had to extend them then splice them into the factory foglamp harness. Oh, and the wiring information that came with the bumper was pretty pointless. I pretty much had to figure it out on my own. The truck wire colors did not match the provided wiring info.
  6. Aug 1, 2011 at 2:01 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    The short answer is no. ARB does have a foglight kit, but it is not one you can plug into something and it works perfect. The fogs will have to be tapped into some how, or you can cut the harness off and straight wire it. As for the turns and marker lights. I chose not to go that route. I did not see the huge benefit to have them if all the lights work on my truck. Plus the Tacoma is wired so odd you have to make your own ground to get it wired the best way possible. People have had issues when they try to hook the wires right into the factory marker/ turn lights harness. I spoke to ARB USA for about 45 minutes one day about all the questions I had. They are pretty cool about assisting you with your install or electrical questions and it is the correct answer as they are who design them and they know what the best way to go is. It is an easy call, and the guy was cool too he was a wheeler, good dude, helped clear it all up for me.
  7. Aug 2, 2011 at 12:56 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    alright i just recieved the wiring loom for the fogs part# MD02 and now my question is how do i wire the turn signals and can i get the dtrl function out of them?
    the fog wiring seems to be no different than any other stand alone auxilary light harness. you still have to tap into the headlight or parking lights for the fogs to work and stuff. both my vision-x leds and my hella lights i had to do the same thing how does this MD02 harness differ in this respect?
    so to clarify things i do not have any preexisting wiring for the fogs and i do not have factory dtrl's either.
    i want to hook all three up i want dtrl's to increase visibility and the fogs as well the turn signals are there so i want to hook them up as well.
    any tips or advice on the instal would really help me out here.
    i want to hook the fogs up to the low beam headlight wire so they function as they would from the factory and because i have nothing hooked into the low beam yet.
    my running light have the ccfl rings for my retrofit and the hella 1000 black magics going to them so i don't want to hook any thing else to them. and my high beams have the vision-x led's on them so i don't want to go hooking more stuff to them. the low beam is currently not being used to i need to know if anyone has an idea on what is the power wire on the drivers side low beam and also where to hook the turn signals to so i can make the dtrl feature and the signals work?
    sorry for the long post
  8. Aug 3, 2011 at 7:58 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    ok as of now the running lights and the turn signals are hooked up which was actually very easy...
    the retarded part is the MD02 harness i have sitting here. every connection is made and good to the fogs them selves and to the battery and the ground the inline fuse is seated properly as well.
    i was told however i would have an extra connector that i would not need and i should cut it off one wire going into it is black and one wire is red the connector as of now is cut. where and with what wire do i make an actual connection to my factory headlights?
    i need to know what to do with the wires i cut off? anyone with experience using arb's retarded wiring loom feel free to help as i'm ready to give up right at the end here.
  9. Aug 3, 2011 at 8:04 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
  10. Jan 22, 2012 at 6:24 AM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Anybody got any more detailed info on this part??
    Thanks
  11. Jan 22, 2012 at 7:43 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    There are 2 sections to the harness. One you splice into the factory harness and the other is already attached to the light. The 2 ends clip together (see pic). I hope this helps.
  12. Jan 22, 2012 at 10:31 AM
    huntark03
    Maumelle, AR
    Not sure I have that other part. Do most people splice into the side marker lights or DTRL/blinkers?
  13. Jan 22, 2012 at 11:05 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    My ARB has no fogs so that's out.
    For my blinkers I connected the white plug in to the other white plug in and then used one of these [​IMG] to tap into the factory wiring specified in the install instructions.
    Finally fit indicator/parker light
    loom extension to light and wire to
    vehicle main light loom using scotch
    locks as per table.
    FUNCTION. INDICATOR HARNESS. VEHICLE COMBINATION LAMP
    ------------------------------------------RIGHT---------------LEFT
    INDICATOR----- GREEN----------------GREEN / YELLOW---GREEN/BLACK
    EARTH-----------BLACK----------------WHITE/BLACK------WHITE/BLACK
    PARK LAMP------RED-------------------GREEN--------------GREEN
    If you have ARB fogs AND had factory find a way to tap into the stock wiring.
    If you have ARB fogs and no factory fogs/wiring run new wire to a relay and then a switch. Simple.
  14. Jan 22, 2012 at 11:17 AM
    huntark03
    Maumelle, AR
    I think I got some shoddy instructions...thanks for this man!
  15. Feb 28, 2012 at 4:45 PM
    N8iV Warrior
    N8iV Warrior Well-Known Member
    Johnny
    Indian Reservation Not by Choice
    07 Silver Dble Cab Trd Sport 6" fabtech lift
    6" Fabtech lift, 34" tires , AFE Cold air intake, Cobra wxst75 cb, Rocky Mountain Radar, L.e.d Headlights, L.e.d maplights,dome light, license plate lights, Tinted frnt windows 35% to match rear windows. ARB bumper with XD-9000 Warn Winch, Pro-Tech HeadAche rack with Pro-Tech Toolbox, Icon Front Coilovers for 6" Fabtech lift, Blacked out Taillights PIAA plasma ION 520 Lights, AFE CAI Pro Dry S Filter, 22" Led light bar, Yakima Mega Warrior basket
    i have the basic arb bumper i am trying to wire the blinkers up and i need help trying to figure it out need help please if any. any wiring diagrams if any break it down for me
