Some issues after installing my leaf springs.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpeedwayTaco160, Dec 1, 2017.
Thread Status:
Not open for further replies.
  1. Dec 1, 2017 at 3:38 PM
    SpeedwayTaco160
    SpeedwayTaco160 [OP] Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Hey guys
    I just installed some leaf springs on my 2010 tacoma. I have a short bed 4x4 and I have installed General Springs and lately I have heard some noises when rolling on uneven terrain or roads. Its sounds more like a clunk. Curious if anyone has experienced this. I will maybe loosen my leaf springs bolts. I went off the tq spec and to me it seems way to tight. I didnt Tq them to spec just because I felt like the bolts would break. If anyone has any info that could help me out Id appreciate it.
    Thanks Ray
    scottalot likes this.
  2. Dec 1, 2017 at 3:43 PM
    Pigpen
    Dan
    Northwest Montana
    spec should be around 75 foot pounds, I believe. The u bolts will handle way more than that.
  3. Dec 1, 2017 at 3:51 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Bolts stretch, if you haven't retorqued them you should.
  4. Dec 1, 2017 at 7:06 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    - I went off the tq spec and to me it seems way to tight. I didnt Tq them to spec just because I felt like the bolts would break.
    How did you determine this?
    - I will maybe loosen my leaf springs bolts.
    As stated above you have already under torqued them. What torque spec have you determined is loose enough?
    -If anyone has any info that could help me out Id appreciate it.
    Torque them to spec rather than making up your own. I would think your axle is shifting around and that is the clunk you're experiencing. Torque to spec, drive a few hundred miles, recheck for proper torque, enjoy.
    Kyitty likes this.
  5. Dec 1, 2017 at 8:24 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    If you have any reason to believe a bolt will not torque properly you should replace it.
  6. Dec 1, 2017 at 10:15 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    You said that you replaced your leaf springs. Right? Which way did you run your bolts on the back? Both bolts over the shackle and leaf spring should be installed with the nut outboard. If got don't, the bolt will bind and hit the frame.
    Toy4me likes this.
  7. Dec 2, 2017 at 7:40 AM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    Just torqued all attaching bolts to 73 fat lbs. all the nuts are facing outboard. Going to tq the U bolts and see if they are loose also
  8. Dec 2, 2017 at 7:41 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    EatSleepTacos likes this.
  9. Dec 2, 2017 at 8:17 AM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    Everything sounds good. Maybe I should invest in a decent tq wrench. This harbor freight tq wrench seem sketchy vs the snap on ones I use at work. My u bolts where not tq’d eithet. Torques everything to specs per the thread
  10. Dec 2, 2017 at 9:03 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When the truck is in the air, you should torque the front one to spec, as well as the bolt holding the shackle to the leafs.
    The third bolt connecting the shackle to the truck, should just be finger tight. Once the truck is on the ground, jump around on the bumper and then tighten the final bolt to spec. Not sure if that's your issue, but that's the proper way to install it.
    Justanotherhemi likes this.
  11. Dec 2, 2017 at 4:43 PM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    I need to loosen that one back up. I tq'd all three to that same tq
  12. Dec 2, 2017 at 4:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just loosen, jump around on the bumper and then tighten back up. Don't be driving around with a finger tight bolt!
  13. Dec 2, 2017 at 4:49 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    :facepalm:
Thread Status:
