some questions about lifting my taco?
Discussion in 'Suspension' started by wolfgang123, Aug 24, 2009.
  1. Aug 24, 2009 at 7:23 AM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Ok so I have no idea what I am doing with this, I have done a lot of research on lifts kits (brand blocks, things like that but I don’t know how to mix and match) that being said I am just going to through all this out there and I was hoping you guys could help guide me in the right direction.
    that lift with the diff drop because I have a 4x4. then (look down)
    I would add those also to the rear. Is that possible? Now I would have a 3 inch total lift in the back (2 inch from the aal and 1 inch from those) right? Then (look down)
    I would add those this should give me a 4 inch front lift and 3 inch rear lift (just the “best seller” lift kit would give me 3 inches in the front and 2 inches in the rear)
    I know I don’t want to use blocks in the rear. I might add in 881 ome coils if I got the money left over, but for the sake of this post lets pretend I am not planning on it.
    would all that work together?
  2. Aug 24, 2009 at 7:27 AM
    lve2xlr8_mph
    lve2xlr8_mph Silver Machine
    Tyler
    Zebulon, NC
    2004 Tacoma 3.4 V6 Limited
    Bilstein 3" lift
    you first link is the same as your third link your not going to be able to put two spacers like that together. You can get larger spacer to get the disired hight
  3. Aug 24, 2009 at 9:28 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    well bein gyour 4x4 you cant go over a 3" lift in the front, bc it will destroy your cv's in the long run. Even with a diff. drop.
    I did the AAL and 1" block in the rear for 3" lift. But for the front a wouldnt go with spacers if you do any off roading. I had spacer's and they sucked super bad. Rode like shit. I would go with the OME coil lift or coilovers.
  4. Aug 24, 2009 at 1:52 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok thanks guys. the problem is i cant find spacers bigger than 3 inches i think i will go with 881 coils. i also totally forgot about the cv joints so i will just stick with 3 a 3 inch spacer. for the rear, can i do the shackle and the aal together.
    I also dont want blocks at all i have heard nothing but horrible things form block owners.
  5. Aug 24, 2009 at 6:26 PM
    ETaco23
    Evan
    PNW
    yeah, your ganna regret doing spacers up front man! the OME coil lift with new shocks will be a way better ride.
    The rear will be ok with AAL+1" shackles.
  6. Aug 25, 2009 at 5:41 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    well i was planning on the spacer and 881 OME coils, but where could i get the new shocks? i dont have 1000 dollars to spend on the suspension lift, if i did i would have gone with a 6 inch lift.
  7. Aug 25, 2009 at 9:49 AM
    ETaco23
    Evan
    PNW
    Toytec has them.
    These are the shocks you want for the 881's and top plate spacer. It will give a great ride. And I dont know if you know, But you will need longer rear shocks as well... I reccomend the Bilstein 5100's or the OME's. Hope this helps ya!
  8. Aug 25, 2009 at 9:53 AM
    ETaco23
    Evan
    PNW
    It will probably be cheaper to get this kit and then just add the 1" shackles.
  9. Aug 25, 2009 at 2:35 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok thanks guys well i guess i should start saving.. hehe
