Some thumb drives, others don't
Discussion in 'Audio & Video' started by normb, Dec 6, 2012.
  1. Dec 6, 2012 at 8:29 AM
    normb
    normb [OP] Member
    So Cal
    12 D/C TRD O/F
    I have two USB thumb drives. A Sony Media Vault 16 GB and a Lexar 4 GB. Both are formatted FAT32. Both are formatted with the same allocation block size of 4096 B. Both were programmed by the same laptop using Win7.
    The Sony stick returns USB ERROR or ERROR 5 or endless blinking LOADING depending on conditions. Start truck in USB mode yields different results than switching from RADIO to AUX (USB) both with Sony stick installed.
    The nice thing about the Sony Media Vault is that it is small. 1.25" x .75" sticks out.
    The Lexar stick works great, but is out of space. It is one of those drives that has the flip around cover and is 2.5 to 3 inches long. Hard to remove when the shifter is in park.
    I do not mind buying another stick. I just want to make sure I buy a stick that works.
    Thanks!
  2. Dec 6, 2012 at 8:38 AM
    SoCal77
    SoCal77 Well-Known Member
    SD
    09 MGM DCLB TRD Sport
    How about a USB extension?
  3. Dec 6, 2012 at 9:13 AM
    tractng
    tractng Well-Known Member
    I had a similar situation. I just got a different one and it works.
  4. Dec 8, 2012 at 9:30 PM
    normb
    normb [OP] Member
    So Cal
    12 D/C TRD O/F
    SoCal77 wrote: How about a USB extension?
    What do you mean by a "USB extension?" A USB extension cable?
    tractng said, " I just got a different one and it works."
    Which brand USB thumb drive did you get? Do you have a model number or name?How much FLASH memory? How big is it physically?
    Thanks,
    normb
  5. Dec 9, 2012 at 9:56 PM
    pinktaco808
    pinktaco808 Hot Steppa
    i have a problem with my dell comp with window 7 wont read my thumb drive help if any but work on my ride and other comps
  6. Dec 10, 2012 at 1:47 PM
    tractng
    I used a super talent 8 GB. It is about 2 inches long by 1/2". The ones that didn't work was the older 1 gb.
