Some very basic suspension questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheBigKahuna, Oct 15, 2024.
  1. Oct 15, 2024 at 10:59 AM
    TheBigKahuna
    TheBigKahuna [OP] Well-Known Member
    I've got a 2013 AC 5 lug (not 4x4) with 111K miles.
    I got it in 2020 with 68K miles and I haven't changed anything on the suspension, front or rear, since I've had it. I doubt the previous owner did either. So I guess it's all original factory.
    Lately the ride has been getting harsher, more so the front than the rear.
    If I'm replacing the front strut should I replace the coil spring too?
    Besides the front strut/coil, is there anything else that could cause a rough ride I should check?
    I'm also going to change the rear shocks.
  2. Oct 15, 2024 at 11:09 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You might as well replace the front springs.
    You can buy it as an assembly.
    Monroe at the minimum.
    KYB would be better.
    Both can be bought at RockAuto.
  3. Oct 15, 2024 at 11:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    We have a 5 lug forum. This is useful because none of the 6 lug stuff works on our 5 lug units
    @memario1214 can assist from a vendor perspective
  4. Oct 15, 2024 at 11:53 AM
    TheBigKahuna
    I know and I've posted there too.
    This forum gets much more traffic.
  5. Oct 16, 2024 at 11:01 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    At a basic level, your coil springs themselves should be just fine. While they are technically a wear item, we find that they can last a very long time. Might not look pretty, but still work. The most likely scenario is that your OEM shocks are not providing much (if any) compression/rebound so you have nothing slowing the action of a harsh bump. Sure, the spring does some of that work, but it's the shock's job to slow down that transition of energy.
    When you say rough ride are you saying that the truck is just feeling chattery, like there's no suspension underneath?
  6. Oct 16, 2024 at 11:15 AM
    TheBigKahuna
    Not chattery, like skipping around.
    I feel more smaller bumps than I used to and the impact from all bumps seems harsher and sharper. A real jolt sometimes.
  7. Oct 16, 2024 at 11:17 AM
    memario1214
    Colton
    Missoula, MT
    Okay. My suspicion is that a refreshed shock absorbers all around is probably all you need to be happy as a clam.
    Clearwater Bill likes this.
