Some water in my coolant.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Oct 29, 2024.
  1. Oct 29, 2024 at 4:22 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    Hey guys. I recently had my radiator damaged and in a pinch I fixed it and replaced with water.
    went to a shop and they fixed my radiator (replaced the side black plastic piece, it was cracked), and they flushed all the water out and replaced with Toyota pink.
    8 liters and it was filled up. Does that mean there’s still water in there? Is it ok if there’s still some water mixed with the coolant?
    what should I do? Thanks.
    p.s. I ordered a new radiator and plan on changing it.
  2. Oct 29, 2024 at 4:29 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I think it will be fine.
  3. Oct 29, 2024 at 4:29 AM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Coolant is always mixed with water. I think the stuff they put in was pre-diluted to a 50/50 ratio. You should be fine.
  4. Oct 29, 2024 at 4:29 AM
    jardoo
    Beirut, Lebanon
    what if it’s regular water and not distilled ?
    pltommyo likes this.
  5. Oct 29, 2024 at 4:31 AM
    fdbyrne
    Missouri
    You'll be ok. You said Toyota flushed it and I'm sure they did it right.
    oldtimertoyota likes this.
  6. Oct 29, 2024 at 4:33 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    It's fine. You can flush it again to get the warm and cozies back when you get the new radiator....
    If they swapped 8 liters, they got it all anyway. Not that they actually measured
    8.0 liters... lol
    SR-71A and jardoo[OP] like this.
  7. Oct 29, 2024 at 4:36 AM
    jardoo
    Beirut, Lebanon
    oh no it was a random shop. I live here in the Middle East, lebanon.
    they used an air compressor to get the fluid out.
  8. Oct 29, 2024 at 4:51 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    If they did it right, they put in a mixture of 50% Toyota pink coolant and 50% water (or something close to that). You don't run 100% coolant in a car engine, it's always a mix of coolant and water. Keep your head down brother!
    jardoo[OP] likes this.
  9. Oct 29, 2024 at 4:54 AM
    jmneill
    SE
    OEM Toyota pink is pre-diluted, IIRC.
    At least it has been each time I've purchased it..
    Barsoom and jardoo[OP] like this.
  10. Oct 29, 2024 at 4:57 AM
    Buck Henry
    OK, then I get the OPs question. But still, nothing to be concerned about unless we are talking a lot of water here.
    jardoo[OP] and jmneill[QUOTED] like this.
  11. Oct 29, 2024 at 5:30 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    When your freeze plugs pop out of the side of your engine block, you'll know it was too much water. :D
    (if we have freeze plugs with the 3rd Gen engine...)
    wilcam47 likes this.
  12. Oct 29, 2024 at 5:33 AM
    jmneill
    SE
    When we were kids, we wished we had some coolant to mix with our water...
    RIX TUX likes this.
  13. Oct 29, 2024 at 6:27 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    you had water? we had to put recycled beer in ours on the trails!
    Phlogiston and jmneill[QUOTED] like this.
  14. Oct 29, 2024 at 6:36 AM
    jmneill
    SE
    When you're young, poor, and breaking down everywhere you go, it's amazing how many substitutes you'll find for one fluid or another... lol
    Stuck in VT likes this.
  15. Oct 29, 2024 at 7:09 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    ReMember coolant protects both low temp and high temp. I imagine you’re fine, really worried buy a hygrometer and test the radiator fluid
    Barsoom likes this.
  16. Oct 29, 2024 at 8:08 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Engine coolant is primarily water mixed with some additives, e.g. ethylene glycol.
    The ethylene glycol prevents the water from freezing. It might have some other nice properties.
    Toyota pink is a mixture that can be used as is. There’s need to dilute it with more water.
    While distilled water is best, because it is less likely to form deposits when it evaporates, as long as most of it was flushed out, I think you are ok. Back in the day I used straight tap water.
  17. Oct 29, 2024 at 7:21 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Where I live, back yard wrencher have always just used 50% plain ol antifreeze (nothin fancy/contains ethylene glycol) and 50% tap water. When I say 50% I mean eyeball not precise measurement ha ha. Works on coldest days and gets to -40 here. No overthinking needed.
    MindlessCorpse likes this.
  18. Oct 29, 2024 at 8:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    In Beruit his odds should be really low on popping freeze plugs.
    MagicToolbox and SR-71A like this.
  19. Oct 29, 2024 at 8:16 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    to end all the doubt just get an antifreeze tester
    Tacorific likes this.
  20. Oct 29, 2024 at 8:32 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Unless you live within the Arctic Circle, or on the South Pole, you should be good. A 50/50 mix should cover you for about -20 degrees F.
