Some weird stuff?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oat, Jan 5, 2012.
  1. Jan 5, 2012 at 10:33 AM
    Oat
    Oat [OP] Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    Recently i've been noticing on my 2001 double cab that when i go to start it up in the aftertnoon (after its been in my garage for abour 18 hours) the brake pedal it very heavy like i cant push it down. Also when i do start it up the brake pedal is pretty heavy to push on the road.
    What is it you guys think?
  2. Jan 5, 2012 at 10:41 AM
    pyroskier
    pyroskier Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    I had a similar issue with mine, where it was hard to initially push down, but once I got it past the hard part, it went down normally. it was just really hard to get the pedal moving. it turned out to be my brake booster, which is not a cheap fix...
  3. Jan 5, 2012 at 10:50 AM
    Oat
    Florida
    2001 Prerunner
    Whats weird is -- the issue is almost like if your truck is off and you continually push down on the brake pedal it will eventually get so pumped it just locks. Well, my truck is like that if it sits for long periods of time. But when i leave it for 3-5 hours it is just fine???
  4. Jan 5, 2012 at 10:59 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    vacuum leak in brake booster...time to start looking for one is the salvage yards...
  5. Jan 5, 2012 at 11:09 AM
    Oat
    Florida
    2001 Prerunner
    Great, just after doing the timing belt fml.
    How much are they from stealership and then for service?
  6. Jan 5, 2012 at 11:32 AM
    hetkind
    Howard
    Johnson City
    Rock Auto shows them for about $200, should be an fairly easy install IF you don't have to remove brake lines or bleed the system:)
    Howard
  7. Jan 5, 2012 at 1:20 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    like mentioned , your booster is toast
  8. Jan 18, 2012 at 7:28 PM
    Oat
    Florida
    2001 Prerunner
    How necessary is it to replace? shits expensive.
  9. Jan 19, 2012 at 7:16 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    All the break booster does is makes it easyer to press the pedal. it is like powersteering for ur breaks.
