Someone drilled a hole in my gas tank
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Electrify135, Nov 29, 2022.
  1. Nov 30, 2022 at 8:45 AM
    #61
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    That jb weld is good epoxy on aluminum cases. Got me through a tough enduro when i put a crack in my cagiva's engine's case leaking transmission oil and couldn't get the parts the next week.
  2. Nov 30, 2022 at 4:06 PM
    #62
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Okay so I talked to my boss (boat mechanic) he said he’d try tapping the hole and then threading the appropriate sized screw/bolt in and using a washer with a rubber gasket to seal it.
    He said there are washers with a rubber gasket glued to one side that would seal it well enough while you wait for a new tank.
  3. Nov 30, 2022 at 5:21 PM
    #63
    Captains1911
    Captains1911 Well-Known Member
    2023 Tacoma TRD OR 4x4 AT DCSB
    I’m so grateful I live on the other side of the country. Stolen tailgates, holes drilled in gas tanks, etc. only seem to be thing on the left coast.
  4. Nov 30, 2022 at 6:38 PM
    #64
    d0ugh0ck
    d0ugh0ck Well-Known Member
    NJ
    This is the second post in the last few days where a hole was drilled into the gas tank. WTF
  5. Nov 30, 2022 at 6:51 PM
    #65
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    That’s messed up
  6. Nov 30, 2022 at 7:02 PM
    #66
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    dam that’s crazy
  7. Nov 30, 2022 at 7:03 PM
    #67
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Bubble gum would have fixed you right up
  8. Nov 30, 2022 at 7:08 PM
    #68
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Flex tape?
  9. Nov 30, 2022 at 7:54 PM
    #69
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    I fixed this for you. Luckily I knew what you really meant :thumbsup:
    Laxtoy[QUOTED] likes this.
  10. Nov 30, 2022 at 7:58 PM
    #70
    Laxtoy
    Maltby, WA
    cammerv8 likes this.
  11. Dec 1, 2022 at 4:38 PM
    #71
    Dxnos
    Dxnos New Member
    2022 Tacoma SR V6 4 x 4
    My brand new 22 tacoma with less than 700 miles was drilled yesterday. The tow truck guy says they drill near the top of the tank So they come back over and over taking a couple gallons at a time. I ony found out because I filled the tank all the way. The dealer will replace the tank costing me a $250 deductible. I'm waiting to see what the dealership is charging the insurance.
    I don't see any aftermarket protection for the side of the gas tank in front of the rear passenger wheel where it's so easy to drill. Any ideas or suggestions are appreciated..
  12. Dec 1, 2022 at 4:56 PM
    #72
    NCCarlsbad
    NCCarlsbad Member
    2008 Regular Cab 4x2
    JB Weld has worked for me in the past. I had split radiators on my motorcycle as a kid. I put JB Weld on them, and they held for months. I think the formula is even better now. The stuff hardens very well. Just make sure the hole is dry, and overlap it over the outside of the tank. Should certainly work for a trip back home.
  13. Dec 1, 2022 at 5:39 PM
    #73
    Electrify135
    Electrify135 [OP] Trd offroad
    Tony
    2020 trd off road
    mid you take off the battery leads for about 10 min it resets the computer.
    so with a proper fix, no codes
  14. Dec 1, 2022 at 5:40 PM
    #74
    saint277
    saint277 Vigilo Confido
    Did you get a fix? Or just waiting on a repair.
    Electrify135[OP] likes this.
  15. Dec 1, 2022 at 5:42 PM
    #75
    saint277
    As long as the EVAP system holds pressure the codes will self clear in few miles.
  16. Dec 1, 2022 at 5:44 PM
    #76
    Electrify135
    Tony
    2020 trd off road
    For future reference,
    If anyone’s in the same predicament.
    I had a lot of factors i had to deal with because I’m stuck here in Portland.
    it was dumping rain all day and night,
    And was sub 40 degrees.
    So initially i was gonna use good old fashioned jb weld but i was concerned about temp and how humid it is.
    Also having to do this upside down while the tank is still using jb weld was a bit of a concern.
    i ended up going with the JB WATERWELD epoxy putty on the plastic tank.
    made a little well vented enclosure of cardboard boxes and put a small little heater in the area just in case.
    after about 6 hours of curing it’s holding up great filled the tank half way up been driving around all day to make sure before i make the big drive home and just keeping an eye on it.
    Until i can get my hands on a new tank I’ll update how it goes
  17. Dec 1, 2022 at 5:49 PM
    #77
    Just_A_Guy
    On the hunt
    A truck
    Ridiculous that you had to make such a fix, but nice macgyver skills. Hope you make it home safely.
  18. Dec 1, 2022 at 6:46 PM
    #78
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    If I was paying the bill I wouldn't bother because it might just happen again.
    I mean if its possible for lighting to strike twice, well. I'd just keep a few different sized self tapping bolts and some sealer to patch it long enough to get back home if it happens again.
    Best of luck
  19. Dec 1, 2022 at 6:54 PM
    #79
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I live in Portland and I tell everyone and their moms if you drive through Portland, keep driving. Don't ever stop because you're more than likely be missing a catalytic converter or gas by the time you get back to your vehicle.
    Chew likes this.
  20. Dec 2, 2022 at 4:31 AM
    #80
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    This whole thing makes me wants to figure out the electric the fence mod.
