someone knowledgable on wheel specs HELP!!!!!!!
Discussion in 'Wheels & Tires' started by Detective_Dan, Jan 2, 2011.
  1. Jan 2, 2011 at 6:37 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i am looking at getting some eagle alloy 185's in 16x8. i know the bolt pattern is 6x5.5 but the offset of these wheels is -11mm. am i gonna have issues with fitment?
  2. Jan 2, 2011 at 6:40 PM
    Detective_Dan
    Colorado Springs
  3. Jan 2, 2011 at 6:48 PM
    Detective_Dan
    Colorado Springs
  4. Jan 2, 2011 at 6:53 PM
    bgbdwlf
    bgbdwlf Well-Known Member
    surprise,az
    08 PreRunner Off Road
    bone stock for now
    i am no expert but i would think it depends on tire size and if there will be wheel and caliper rubbing issues.
  5. Jan 2, 2011 at 7:08 PM
    Detective_Dan
    Colorado Springs
    pretty much what i need is someone to look at the link above (my 2nd post in this thread) and tell me if the backspacing and offset are acceptable on tacomas. the tire size im getting is 265/70/16 goodyear wrangler duratracs
  6. Jan 2, 2011 at 7:12 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    A 9" wide wheel with -11 offset is approx 4.5" backspacing. With that wheel you can run 265's on stock suspension or 285's with a lift.
  7. Jan 2, 2011 at 7:29 PM
    17quint
    17quint Member
    orange/rockland,ny
    tacoma 4x4
    i put a 3" level kit from rough country,put a bull bar w/fog lights,n-f-b step bars bug deflector window guards kuhmo tires 265/70/17 with mickey thompson classic2 wheels
    hi dan i have the same problem i put a 3" lift & now i need to know will i have any problems putting 16x8 6 5-5 mickey thompson classic 2 on 265/75/r16 duratrac's will there be any rubbing or anything like that
  8. Jan 2, 2011 at 7:33 PM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    x2. You should have no problem running this wheel and tire combo. If you have any more questions, feel free to PM me. I will be more than happy to answer any question you might have.
  9. Jan 2, 2011 at 7:36 PM
    TexasTacoma37
    Need to know the backspacing in order to be sure. As long as it's between 4.5 and 5.5" you will be good to go with that tire size.
  10. Jan 2, 2011 at 7:41 PM
    Archangel
    Charlotte, NC
    '04 T4R SR5 4x4
    The -11 offset is the same as about a 4.6" of backspacing. Is there a particular reason you want to go with a 9" wide wheel on a 10.5" wide tire? Are you planning a lift and wider tires in the future? Looking at your OP, you say 9" wide, but the link says 8" wide.. Can you confirm width for me?
  11. Jan 2, 2011 at 7:44 PM
    Detective_Dan
    Colorado Springs
    in the link above in my 2nd post, it says offset of -11 and a backspacing of 4.00
  12. Jan 2, 2011 at 7:55 PM
    Archangel
    Charlotte, NC
    '04 T4R SR5 4x4
    umm... his quote says 9" wheel, your link says 8" wheel. That's why the backspacing is different.
  13. Jan 2, 2011 at 7:58 PM
    Detective_Dan
    Colorado Springs
    ahh lol i didnt catch that. ok so a 16x8 with 4.00" backspace and -11 offset is just fine right?
  14. Jan 2, 2011 at 8:03 PM
    Archangel
    Charlotte, NC
    '04 T4R SR5 4x4
    You might have some rub issues on stock ride height. Be prepared to have a utility knife ready, or extra money for a lift.
  15. Jan 2, 2011 at 8:05 PM
    Detective_Dan
    Colorado Springs
    im puttin 5100's up front and setting them at 2.5 when i get the wheels and tires. im gonna order all at once. the 5100's should be suffecient right?
  16. Jan 2, 2011 at 8:10 PM
    Archangel
    Charlotte, NC
    '04 T4R SR5 4x4
    You should be fine.
  17. Jan 2, 2011 at 8:29 PM
    Detective_Dan
    Colorado Springs
    alright, thanks for the help matt. are you stationed in NC or retired?
  18. Jan 4, 2011 at 5:17 AM
    Archangel
    Charlotte, NC
    '04 T4R SR5 4x4
    7th generation soldier. Former.
  19. Jan 4, 2011 at 9:57 AM
    Detective_Dan
    Colorado Springs
  20. Jan 5, 2011 at 11:21 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Those wheels should work just fine. I have 16x8's with 4.5" backspace and i'm not even close to rubbing with stock size tires.
