Someone teach me how to zerk.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaPantsKey, May 26, 2014.
  1. May 27, 2014 at 4:50 PM
    #41
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    Sub...
    I am looking to do this for the first time myself. I bet it is some nasty shit in there since I have yet to do this since getting the truck. 5 fittings right? on the driveshaft? Are there any elsewhere that would need grease? Any reccomendations on grease and grease guns?
  2. May 27, 2014 at 4:56 PM
    #42
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Three on the main shaft, two on a secondary shaft near the driverside floor.
    Grease gun recommendations? Air powered. Lol! Any will do the job :)
  3. May 27, 2014 at 5:48 PM
    #43
    BRUIN8124
    Mark
    None on the chassis or other suspension parts? Or are the rest "non servicable"?
  4. May 27, 2014 at 6:37 PM
    #44
    KaPantsKey
    KaPantsKey [OP] Well-Known Member
    Kyle
    SC
    13 MGM DCSB TRD-OR
    I believe the amount of zerks depends on the truck. I have a 2013 Off Road 4x4; I have 5. Grease gun is nothing fancy. I think I dropped 20ish dollars on one. I chose Mobil 1 Synthetic Grease all the way around. Some say NLGI 1 for the front and NLGI 2 for the remaining. Mobil is NLGI 2 and I used it on the fronts and rears.
    As for any other grease ports, I am not really sure. I heard the ball joints could use a fillin', but I didn't find a zerk. Anyone have any insight on this?
  5. May 27, 2014 at 6:39 PM
    #45
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Pretty sure there are only zerks on the drive shaft, no suspension parts unless they are aftermarket.
  6. May 27, 2014 at 6:56 PM
    #46
    gearcruncher
    Canadain bumper technician
    Sealed ball joints , tie rod ends and universal joints are designed this way to keep the joints from contamination . They are designed for the life of the vehicle which most auto manuafacturers use 50,000 miles as lifetime . Some guys drill polypropelyne joints out and install a grease fitting to lube the polypropelyne joint which defeats the purpose of the sealed joint . If these joints make noise or become dry , change them out for a serviceable joint with a grease zerk ( NIPPLE ):D
  7. May 27, 2014 at 8:15 PM
    #47
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The old grease should be purged out. Water does get into the joint regardless of the seals. That is what causes the premature failure when they are not greased on a regular basis. Esp in wetter areas.
  8. May 27, 2014 at 8:30 PM
    #48
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    That was funny as hell
  9. May 27, 2014 at 8:33 PM
    #49
    taco terror
    USA
    I didn't hear them called zerks before I came to the forum though, before then I was greasing my nipples till I saw the ooze
  10. May 27, 2014 at 9:50 PM
    #50
    obzerver
    obzerver Well-Known Member
    Justin
    Surrey, BC
    09 SR5 TRD
    Grillcraft grill, 20" LED Light bar, 17" MB TKO wheels, 265/70R17 Cooper ATPs, Uniden PRO520XL CB, Pioneer AVH-P2400BT
    Thank you for threads like these! I finally went out and got a grease gun and grease. Seeing all that black goo ooze out made me feel sad for my truck. If I had known this was so easy I would've been doing it myself a long time ago.
    I think I'll also be on the lookout for a creeper. Sliding around my garage floor on a cardboard box wasn't as much fun as I thought it would be... :rofl:
  11. May 27, 2014 at 10:57 PM
    #51
    AR15xAR10
    A good Low profile creeper = worth EVERY f*cking penny. :thumbsup:
  12. May 28, 2014 at 5:30 AM
    #52
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    Looks like I need to purge my zerks until the ooze black goo. I will have to pump slowly until they do.
    4x4cajun likes this.
  13. May 28, 2014 at 6:51 AM
    #53
    dapetik
    dapetik Well-Known Member
    David
    Barboursville, Va
    2015 TRD Sport
    Magic bedcover, sweet ass floormats, rocket boosters, warp drive
    Not sure if it was mentioned but I know with farm machinery, if you put too much you can actually blow out the seals. I've always listened and felt carefully, you can usually tell when it's "full".
  14. May 28, 2014 at 4:14 PM
    #54
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    I'm 52 and they've been known as 'zerks' for as long as I can remember...
  15. May 28, 2014 at 5:25 PM
    #55
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
  16. May 28, 2014 at 6:18 PM
    #56
    welterbf123
    Columbus, OH
    2017 TRD Off Road
    Yea Yea!... LOL
  17. May 29, 2014 at 5:05 AM
    #57
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    :laughing:
  18. May 29, 2014 at 5:48 AM
    #58
    Ken b
    Ken b Well-Known Member
    Ken
    Surprise, Az
    14 offroad 4x4
    ARE shell, bedrug, TRD wheels
    +1
    This is the best advice on this entire thread.
    1. When you grease a fitting you need to get all the old grease out. Pump till you see clean new grease.
    2. Once you are done clean off the excess.
    Yes, it's messy but it's the best way to ensure all the dirt, water and old grease is out of the joint.
  19. May 29, 2014 at 1:03 PM
    #59
    wesplains
    wesplains Well-Known Member
    West
    Middle of USA
    Tacoma TRD Sport
    SnugTop, Aries Stealth Bull Bar, OEM Bed Mat, Wet Okole Seat Covers, Husky Floor Mats, OEM Cab Rack, Amp Bed Extender, VooDoo Bad Brackets with Cargo Basket. Yakima racks on cover. MagnaFlow Muffler, KC Running Lights, Console Vault, Dash Cam, Side Moldings, UltraGauge
    Ok, crawled under today, found one zerk up front, one in the middle and one in the rear. Took light and could neither see or feel any others. Where are the other two?
    2014DCSB
    The Zerk up front was super clean, no grease on outside on Zerk at all. After filling hose of gun took six pumps. I stopped once I felt the pressure on the handle.
    The Zerk in the middle and in the rear each had grease on them and took three pumps of grease.
  20. May 29, 2014 at 1:06 PM
    #60
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    They are at every U-Joint. Look/feel harder.
