Someone teach me how to zerk.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaPantsKey, May 26, 2014.
  1. Aug 1, 2014 at 9:55 AM
    #141
    SAXD Taco
    SAXD Taco Well-Known Member
    Justin
    Atlanta
    2013 DCLB, 4X4, MGM
    N-Fab Steps, BakFlip F1, TRD Accessory Skid Plate, Toyota Bed Mat, Husky Liner Floormats
    That's the exact one that I purchased from Advance Auto. It works great however, the Mobil1 grease that is loaded in there tends to separate and leak out of the grease gun (maybe a table spoon of thinner liquid grease). Not sure if the issue is the grease or the gun, but it still works great. I just keep grease gun in a plastic bag to prevent making a mess on the garage floor. For the $20.00 i spent on it I'm pretty happy.
  2. Aug 1, 2014 at 10:04 AM
    #142
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    2011 Tacoma TRD OR 4x4 & 2021 Tundra SR5 DC 4x4
    AVS in-channel window visors Husky Mud Guards Husky Liners X-act Contour Floor Liners Cooper Discoverer AT3 LT- 265/75/16 C Toyota 16" Black TRD Trail Team Edition Wheels Truxedo Lo Pro Tonneau Cover OEM Bed mat OEM Running Boards Marathon custom fit seat covers Front window tint Rear Leaf Spring 4 Pack - TSB Front - 5100's with stock springs set at .85" Rear - 4600's
    I also get a tiny bit of leakage from the breather valve (also with Mobil One). I just store it on a rag as it doesn't accumulate very much at all. I did put some thread sealant on all the part before I assembled....that seems to have prevented any leaks from the actual threads.
    That flexible tip is really handy for those hard to reach zerks on the front drive shaft.
  3. Aug 2, 2014 at 10:42 AM
    #143
    jaymoussy
    jaymoussy Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    I went for my brake actuator recall work, and asked to have the driveshaft u-joints greased and it was done at no charge. My first time at dealership with the (used) truck.
    Other: I managed to get a complain in writing about the damn leaf springs... I feel better now!
  4. Aug 22, 2014 at 5:45 PM
    #144
    guitar2323
    guitar2323 Well-Known Member
    clint
    saratoga springs new york
    2013 access cab TX Pro
    That one is a pita. I made an extension with a bend on the end to get to it.
  5. Aug 24, 2014 at 6:54 PM
    #145
    NavyGuyAN
    NavyGuyAN Well-Known Member
    Virginia Beach, VA
    2010 Silver Taco 4x4
    Wet Okole Seat covers, Weathertech Floor mats, Blistein 5100's all-around, BFG KO2’s Fumoto Drain valve
    Is there anyway you can post a pic of where they are at. I might start doing this aswell because i have a feeling the stealership never does mine and say they do or just check off the box.
    Not sure if there in the same location for the 2010 4x4 v6.
  6. Feb 8, 2015 at 7:27 PM
    #146
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    I just purchased this exact grease gun last night at O'Reilley's. Today I jacked up my truck, crawled under it and spent a decent amount of time cleaning off all 8 zerks on my front and rear driveshafts/u-joints. Had them looking all nice. So then I went to actually put some grease in them, and I absolutely cant figure out how the HELL this grease gun fits my zerks.
    Maybe im just dumb? I've greased this truck before (its been a few years....I know that sounds really bad, but that's why I wanna do it ASAP and keep up with it). But I have done it before and never had a problem so I dunno what the hell is wrong. The zerks are all the standard zerk fittings you find on any vehicle. No matter how hard I push this grease gun fitting on to the zerk, it will not go on. When it does seem like its on there, I start pumping and the grease just oozes out from between the gun fitting and the zerk.......any help on how to solve this would be highly appreciated!!:eek:
  7. Feb 8, 2015 at 9:34 PM
    #147
    SolarNut
    SolarNut Thin Wallet (TW) member
    2014 Toyota Tacome TRD Off Road
    he can definitely have more than one truck. LOL Mods are at $10084 and going ...
  8. Feb 8, 2015 at 11:58 PM
    #148
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes that will work just fine. Just pump enough into each joint to purge out all the old grease. It will be messy so get some rags on hand.
  9. Feb 9, 2015 at 7:16 AM
    #149
    Sig45
    Mark
    Maine
    I don't know....the fitting connected nicely to the zerk with just a little pressure. There's a slight snap sound when it's seated properly.
  10. Feb 9, 2015 at 5:39 PM
    #150
    CodyH.
    Cody
    Arizona
    I wish mine did that...I literally just bought it and tried to use it the next day with zero luck. I don't see how or why it wont go onto the zerk fitting
  11. Feb 9, 2015 at 5:41 PM
    #151
    CodyH.
    Cody
    Arizona
    I will look a bit closer at the coupler but this thing is brand new right outta the box so nothing should be broken yet I would hope. It seems to be the right size because if I completely unscrew the end coupler off of the hose, it goes on the zerk just fine. When its connected to the hose on the gun, it does not go onto the zerk. Very strange
  12. Feb 9, 2015 at 6:37 PM
    #152
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Cody, I had a similar issue with that grease gun. Some advise would be to release pressure from the flex hose prior to connecting it to your grease fitting by pressing the button next to the breather valve. I also sometimes have to squeeze the retention clip to release the plunger in order to feed grease into the flex hose. You could prime the flex hose also, if you wish, before you connect it to your zerk fittings. Keep squeezing the trigger until a small bead of grease flows from the end of the flex hose. Bleed pressure as stated above and get a strong grip and apply suitable force straight onto the zerk. Try to avoid a side to a side rocking motion as you don't want to break the zerk fitting. You are correct, it doesn't want to go on easy but as you wear the gun in, it should get easier.
    -J
  13. Feb 9, 2015 at 7:30 PM
    #153
    CodyH.
    Cody
    Arizona
    Thanks for the advice! Ill have to try it tomorrow after work. I want to give it a try tonight but its already dark and I have a bunch of stuff to do before I go to bed. I really wanna fix this stupid problem!
  14. Aug 30, 2015 at 7:49 AM
    #154
    flyphish
    flyphish Member
    2013 DCSB TRD 4x4 off road
    Leer camper, 265/75/R16
    bumping this old thread. Can anyone confirm that there are only 3 zirks on a 2013 TRD? I have searched and searched.
  15. Aug 30, 2015 at 7:57 AM
    #155
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I have a 10 2wd Trd sport and have yet to find any zerks on driveshafts. They must be on 4x4 only?
  16. Aug 30, 2015 at 8:14 AM
    #156
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Do all Tacomas have grease fittings on the driveshaft?
  17. Aug 30, 2015 at 8:46 AM
    #157
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    I have zerks on my 14 2wd
  18. Aug 30, 2015 at 3:05 PM
    #158
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    Hope this isn't a stupid question, but should you grease the zerks on a new truck? I have already seen a few things on my truck that tell me the workers weren't paying attention to details. I would hate to get to 15K miles only to find out that there hasn't been sufficient grease there for some time.
  19. Aug 30, 2015 at 4:39 PM
    #159
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I grease my u-joints every 5000 miles, or every oil change. Better to grease them and help flush out dirt and not let them dry out.
  20. Aug 30, 2015 at 4:43 PM
    #160
    flyphish
    flyphish Member
    I found 3, very easy to get to. Front, middle, rear. I was thinking maybe Toyota consolidated and made them easier to get to starting with the '13? I just want to make sure I am not missing any? I had the infamous tacoma thud at stops and accelerating. Greasing those 3 fixed it! I just would love confirmation that those are the only 3.
