Someone teach me how to zerk.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaPantsKey, May 26, 2014.
  1. Aug 30, 2015 at 5:00 PM
    #161
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    My 13 has 5 grease points.
  2. Aug 30, 2015 at 11:09 PM
    #162
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I also have zerk fittings on my 2012 Prerunner drive shafts. Three to be exact: One at the transmission, one after the center support bearing and one at the differential.
  3. Aug 30, 2015 at 11:12 PM
    #163
    Jimmyh
    SC
    2012 Prerunner SR5
    As per your information you have a 4X4 and you will have two more on the front drive shaft. So you missed two on the front shaft.
    Three on the rear drive shaft plus two on the front for a total of Five Zerk Fittings for a four wheel drive Tacoma.
    NotRed likes this.
  4. Aug 31, 2015 at 5:20 AM
    #164
    flyphish
    flyphish Member
    2013 DCSB TRD 4x4 off road
    Leer camper, 265/75/R16
    Looks like I am climbing back under this evening, thanks!
  5. Mar 29, 2019 at 6:58 PM
    #165
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Just did this on a 2002 and my own 2011.
    The 2002 stepside had 6 Zerks. It had NOO lube at all. Nothing but clean grease came oozing out. Crazy it was so dry.
    My 2011 has a Dana Spicer Driveline... And is not the same. Each joint only has 1 zerk, instead of multiple. I did the first 3. Then there are two more above the transfer. The forward 2 are inside the knuckles, not on the sides like the rear 3. And, the further back front zerk is hiding behind the rock guard.
    Hmm.
  6. Apr 6, 2019 at 6:31 PM
    #166
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    Before WWII. It's really old school. I asked my dad once when I was little (a long long time ago).
    AR15xAR10[QUOTED] likes this.
  7. Apr 6, 2019 at 6:39 PM
    #167
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I since learned myself.
    Its the grease fitting itself...not the ujoint. I was once so confused :rolleyes:
    Alexely999 likes this.
  8. Apr 6, 2019 at 7:19 PM
    #168
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
  9. Apr 6, 2019 at 9:30 PM
    #169
    HVAC Tech-oma
    HVAC Tech-oma Well-Known Member
    Danny
    San Diego
    2015 White TRD Tacoma 4x4
    ADS 2.5 Coilovers
    Overgreasing is the leading cause of failure in bearings in HVAC stuff...don’t know about automotive.
    :notsure:
  10. Apr 6, 2019 at 9:30 PM
    #170
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    This is an easy maintenance job I recommend everyone do. I can feel a big difference with daily driving
    JKU3000 likes this.
  11. Apr 6, 2019 at 9:37 PM
    #171
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah that’s not really comparable. These are designed so the new grease pushes the old crap out so if you overgrease all you do is be wasteful.
    Imho Toyota cheaped out by not putting a zerk on the slip yoke (4x4 models).
    It dries out and combined with the axle wrap can make for some super annoying clunking or lurching sensation.
    I drilled and tapped mine for another zerk when I replaced the carrier bearing
    HVAC Tech-oma[QUOTED] likes this.
  12. Apr 7, 2019 at 7:55 AM
    #172
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @hx989 pics of the zerk you installed...? I'm waiting on a carrier bearing and bellows clamps before I rebuild mine.
  13. Apr 7, 2019 at 6:43 PM
    #173
    Spicey Taco
    Spicey Taco Active Member
    2014 TRD Off Road QC
  14. May 15, 2020 at 5:21 PM
    #174
    kurts74
    kurts74 Well-Known Member
    Flagstaff, Arizona
    2nd Gen 4-door longbed
    ICON Mid travel set up with Hard candy shell
    Got some U-joints from Tacoma Parts Deal (man dealing with them was...still is painful). They sent joints (Spicer) without zerk fittings. I have a 2010 4x4 currently with zerks. Called local Toyota and they don't sell grease-able U-joints either. Not excited to put the new ones in, but taking the gamble on "OEM" non-grease-able vs aftermarket grease-able. Not sure why they would be moving a way from a grease-able U-joint.
