Someone without the suspension TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Jul 3, 2008.
  1. Jul 3, 2008 at 1:34 PM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Somebody wanna do me a favor and go measure the height of their Taco?
    I need to know the height from the ground to the bottom of each fender.
    Thanks
  2. Jul 3, 2008 at 1:38 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    You mite want to try center of Hub to bottom of fender. More acurate than from ground.
  3. Jul 3, 2008 at 1:40 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    front to the wheel well centered over hub 34.75 and rear 37.25. Hope this is what you needed
  4. Jul 3, 2008 at 1:47 PM
    Khaos
    Bryant
    That is what I needed. Thanks!
  5. Jul 3, 2008 at 2:01 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I still have the pics posted in my gallery. Make sure it is the same size wheel as yours some of our trucks came with taller tires than the others.
  6. Jul 3, 2008 at 2:10 PM
    Khaos
    Bryant
    As long as those are stock numbers its good enough for my purposes.
  7. Jul 3, 2008 at 2:22 PM
    Rtrn2taco
    Philadelphia
    stock numbers
  8. Jul 3, 2008 at 2:25 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Some of our stock tires were diff. Mine were 245 and others were 265.
  9. Jul 3, 2008 at 2:27 PM
    Rtrn2taco
    Philadelphia
    measured with 245s
  10. Jul 4, 2008 at 7:47 AM
    rachunter
    rachunter Well-Known Member
    West Virginia
    08 TRD Off-Road
    XM Radio,Access Lorado Tonneau, Ventshades, Tinted Windows, Destination A/T's , Moto Metal wheels and lots of Liquid Glass
    Measured the same way "Rtrn2taco" measured his. My truck came with the 265/70R16 tires Off-Road Pkg.
    Front - 34 5/8
    Rear - 36 7/8
  11. Jul 4, 2008 at 8:13 AM
    Angus_NB
    Angus_NB Well-Known Member
    Riverview, NB, Canada
    '08 Tundra DC SR5 4x4
    The amount of gas in it will change the number in the rear.
    I'm beginning to think wind may be a factor. These springs are wimpy. :)
  12. Jul 4, 2008 at 9:44 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    :D:D:D:D Good one.
  13. Jul 4, 2008 at 4:41 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Correct, from center of wheel to bottom of fender takes out the varying tire size factor, and inflation pressures, and sometimes 2 tires with the exact same OD will have a differing rolling radius due to sidewall flex.
    My numbers by the "less correct method are: F 35-5/8", R 37-1/2", driver's side. Has currently 5/8ths tank of gas, front tires at 32, rear at 28, 265/70-17 tires on FJCruiser wheels, bed empty except bed mat, Amp Reasearch/Westin Bed X-Tender (+/- 5lbs) a Fluke meter in a Pelican box (2.5lbs?) and an old not yet thrown away 5/35 mFd capaciter (6-8oz's).
