Something Burning Smell Whever i get out of truck.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JEA86, Dec 27, 2010.
  1. Dec 27, 2010 at 7:17 AM
    JEA86
    JEA86 [OP] Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    There is a smell whenever i get out of the truck it smells like something is getting hot, I poped the hood smells like its coming from there not sure what it could be as nothing looks burnt!
    Only Mods i have on the Truck is TRD suspension and TRD wheels and TRD Skid Plate
    its a 2010 Tacoma Regular Cab 4 Cyl. 5 Speed
    any ideas?
  2. Dec 27, 2010 at 7:28 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Take it to the dealer. Is it possible you have a plastic bag that got stuck to something when you were driving?
  3. Dec 27, 2010 at 7:33 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    could be the clutch. a bunch of us with the 4 cylinder, 5 spd are having issues where it seems like the clutch is wearing. Dealer couldn't comfirm it for mine. Every once in a while when I get out of the truck, I smell it. Not a matter of not being able to drive a stick cause most of us have driven stick for a long time before this truck.
  4. Dec 27, 2010 at 7:34 AM
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    well i notice it mainly after i have used 4wd. i never go over 55 MPH in 4wd so idk its just started since this winter weather has hit
  5. Dec 27, 2010 at 7:35 AM
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    see thats what it "kinda" smells like, but i was like Nah no way i have been driving a clutch for years and i dont ride the clutch or anything
    truck has 13k miles
  6. Dec 27, 2010 at 7:46 AM
    90YotaPU
    Union County, NJ
    Yea that was my first thought (I've been driving tractor-trailers since I was 18, my normal rig has a 10 speed trans). Mine has 6,200 miles on it. It's something to do with the pressure plate failing. If you do a quick search on it, you'll find some posts about it. I understand one member had his clutch fully replaced. I know of at least another member in NJ that's having the same problem as me and just trying to get the dealer to confirm the problem exists. Because mines not slipping, the dealer says it's fine. My concern is that when I get up to 30k miles, it's gonna be fried and then they'll say it's a wear and tear item. I would take it to them and tell them you smell the clutch burning. At least get it on record that you brought the problem to their attention. Also, don't let them try and swindle you for a diagnostic fee. I rose holy hell when they tried that with me and they waived it and gave me a loaner car for free.
  7. Dec 27, 2010 at 7:51 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    X2,,no fees,,under warranty still.
  8. Dec 27, 2010 at 10:06 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    My first thought based on where you live is that you're running it in 4wd in the snow. If it's after this that you're smelling a "burnt rubber" smell, then it's completely normal for all 4wd vehicles in the snow regardless of make. Mine finally quit smelling after about 5 winters. BTW, google it and you'll see threads going back for years on all makes/models that are 4wd. No one has ever come up with a good explanation, but those of us living/driving in snow over the years know it's normal.
    Now if you're not driving in 4wd in the snow and it smells, then get it checked. Or if you're still not sure, get it checked since it won't cost you anything.
  9. Dec 27, 2010 at 10:13 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ^^^^ this . I have experienced the same thing OP .
  10. Dec 27, 2010 at 10:45 AM
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    yeah the smell started just this winter and whenever it snows!
    so i guess its just not me
  11. Dec 27, 2010 at 12:56 PM
    claw
    claw Well-Known Member
    Cam
    Bozeman MT
    2010 Access Cab, 4 Banger
    Tonneau cover, bed lights, fog lights, VHF radio
    I was wondering if it happened to be the traction control doing braking on wheels as necessary. Don't know if that is correct but it was just my thought...
  12. Dec 27, 2010 at 1:25 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    +1
  13. Dec 27, 2010 at 1:46 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    My guess is grease from the u joints on the 4wd drive shaft is flinging onto the exhaust . Thats why u only smell it after using 4wd.
  14. Dec 27, 2010 at 3:40 PM
    UrbanAngler
    UrbanAngler Member
    BOSTON
    05 D-CAB
    Last winter when using 4WD to get up to the ski slopes, I smelled the burning rubber thing. I continued to smell it every time I used 4WD. Last winter the dealer confirmed that nothing was wrong with the truck.
    This winter, I smelled the burnin rubber just last week while usiing 4WD going to the slopes, It was the first time I smelled it since last winter.
    After reading some of these replies, I guess it is normal, Thanks, for the peace of mind next time I go Snowboarding.
  15. Dec 28, 2010 at 6:51 AM
    Pat 13
    Pat 13 Hillbilly 4X4
    Harpers Ferry, WV
    11 Tacoma V6 DC 4X4 TX Pro
    Thanks for the info, I had had the same smell a couple times but had not looked into it yet. Just starting using 4X4 in the snow recently.
  16. Dec 28, 2010 at 8:11 AM
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    yeah only in the snow && hey Pat-13 i see your from WV too how is the weather up north?
  17. Dec 28, 2010 at 11:34 AM
    Pat 13
    Harpers Ferry, WV
    Cold and windy...no snow :(
  18. Dec 28, 2010 at 11:39 AM
    40950
    CR, WA
    stock
    Maybe backing up against a heavy drift or pile,,and forcing the mudflap onto the tire as you move backwards. (rubbing)
    A wild shot in the dark.
  19. Feb 27, 2011 at 2:52 PM
    10taco
    10taco Well-Known Member
    Massachusetts
    '23 4X4 DCSB V6 AT SR5/SX MGM
    I have the same issue on my '10 Tacoma 4WD reg cab 4 CYL man trans. I had the same thing on my '95 4WD reg cab 4 CYL man trans. Grease from the driveshaft(s) are 'flinging' onto hot exhaust components and you smell it burning upon exiting the truck after a drive. Not to worry! :)
  20. Feb 5, 2014 at 5:32 PM
    kool
    kool Member
    ny
    2013 Tacoma
    i have a 2013 (6-speed manual) that makes that burning/rancid smell when backing up in 4x4 :eek:
    i'm glad to see that i'm not the only one with this issue :mad:
    :cool:kool
