something happened
Discussion in 'Audio & Video' started by Chunk, Feb 8, 2011.
  1. Feb 8, 2011 at 3:16 PM
    Chunk
    Chunk [OP] Member
    all of a sudden my sub is not working,when i go to check everything i feel the
    woofer and it is dead,I pushed slightly on it and it kicked on and seems to
    have a small popping sound when played at low volume but still sounds good
    at high volume..is there a way to check out both the amp output and the
    speaker with a voltmeter.the speaker goes in and out of working and i need
    to narrow down if its the amp or the speaker. the amp is a 5 channel amp
    pushing 1 10" sub.Thanks for any help....
    a little more info ...the amp is a jl xd 700/5 pushing 1 10 " IDQ woofer ,the amp is turned up 3/4 on the woofer and i never maxed it out all the way
  2. Feb 8, 2011 at 3:34 PM
    mrmumbels
    mrmumbels Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    check your wires inside the box. Check the wires from the sub terminals to the vc. Put an ohm meter on the sub and push the sub in slowly to see if the resistance suddenly drops. The resistance will fluctuate while you move the sub slowly but it shouldn't drop suddenly.
