Something hit the underside of my truck in high water.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crobran, May 3, 2024.
  1. May 8, 2024 at 7:22 AM
    #81
    lastcall190
    lastcall190 Well-Known Member
    NJ
    2023 Silver DCSB TRDOR
  2. May 8, 2024 at 10:23 AM
    #82
    Crobran
    Crobran [OP] Well-Known Member
    Texas
    `21 DCSB 2.7L Silver Sky
    Trifecta 2.0, Ionic Nerf Bars, Tailgate anti theft device from @christian06, Husky Weatherbeaters, Bed lights, OEM bed mat, Derped badges and grille bezel
    I KNEW I should have cleaned that black spot off of my truck!
    Mully[QUOTED] likes this.
  3. May 8, 2024 at 10:24 AM
    #83
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    OP, did you figure it out? Any damage? Any leaks? Did you talk to your truck to make sure it wasn't just a shiver?
  4. May 8, 2024 at 10:25 AM
    #84
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Gator tail give your truck a slap?
  5. May 8, 2024 at 10:26 AM
    #85
    Crobran
    Texas
    There isn't any visible damage, and no other weirdness that would make me think anything got into the transmission or differential. I did pat him on the head and tell him he was a good boy and I was proud of him, so maybe that helped. I need to take it in for an oil change so maybe I'll ask them to give it a look over just to be sure.
    lastcall190 likes this.
  6. May 8, 2024 at 10:33 AM
    #86
    saajanpatel1
    Saaj
    MA
    2022 Tacoma Limited
    None
    Remember, when you give him an oil change, tickle the oil pan, it will help remove all the oil
  7. May 8, 2024 at 3:00 PM
    #87
    JHP
    JHP Well-Known Member
    Heart of the South
    2022 Whilte Tacoma SR 2.7 DCSB
    Towing Package, Bed Mat, Roll-up Tonneau Cover
    Probably the monster from Tremors. I hear they have adapted to the water now.
    Mully likes this.
  8. May 8, 2024 at 3:53 PM
    #88
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    OP, it sounds like you had a minor “collision” with something under the water or floating on the water. Don’t sweat it. I drive through water that deep a few times a year and hit crap many times a year even with no water involved. The worst damage I have consists of gouges and small dents in the frame, skid plate, rock sliders, etc. If there is no visible damage, it’s likely you hit a piece of floating wood or some such.
    Also realize that even if you got water into your diff, it doesn’t cause any immediate damage or noise. A small amount of water in the gear oil does not dramatically reduce the lubricating properties of the oil leading to immediate damage.
    The largest water egress risk by far is into your engine air intake which is much higher than 1 foot off the ground. Significant water getting into the intake can lead to a very bad day. Water is not compressible and can lead to a major engine failure if enough of it gets into a cylinder.
    Crobran[OP] likes this.
  9. May 8, 2024 at 3:57 PM
    #89
    leftright
    leftright Well-Known Member
    charlie
    south Texas
    2023 tacoma SR5 DCSB celestial silver Technology package black out package tinted windows
    Clazzio seat cover Vled tail light conversion
    I have an Impala I heard banging from the trunk one time I decided to ignore it best decision ever:devil:
    kent50 and Crobran[OP] like this.
  10. May 8, 2024 at 3:57 PM
    #90
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    we don't call them slow anymore...we say "neurodivergent" smh
    Phlogiston and leftright like this.
  11. May 8, 2024 at 3:59 PM
    #91
    leftright
    charlie
    south Texas
    Damn i'm old we just called em tards
    kent50, Phlogiston and TacoTyusday like this.
  12. May 8, 2024 at 3:59 PM
    #92
    TacoTyusday
    Zac
    San Diego
    In my house, we still do...
    Phlogiston and leftright[QUOTED] like this.
