Something interesting
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, Oct 16, 2014.
  1. Oct 16, 2014 at 5:33 PM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I filled out some paperwork to get my truck repaired next week. The guy ran my vin and printed me out an estimate, that also showed the features and options on the truck. One of the features was cruise contol, however I don't have cruise control. All I have is a loose connector on the passenger side of the engine bay which I assume is for the cruise control. If the PO took it off, I'd slap him upside the head. So, how much would it be to install cruise control?
  2. Oct 16, 2014 at 6:13 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    that would be the actuator box under the hood and it should have two big throttle looking cables there as well, one runs into the firewall by the steering to hook to gas pedal and the other goes to the throttle body.
    the actual CC control module is behind the passenger side kick panel by your feet. if yours is missing then you find the part number of yours (based on your vin) and you can get one off of ebay for around $50 or buy a new one from the dealer for around $300. it sounds like all trucks come set up for it and it just depends on your options if it was installed or not so I wouldn't rely on the vin to tell you things other then part numbers, weather yours had this or that is likely beyond its record keeping and it just lists all available stuff for it.
    if your truck had cruise it should have a small CC arm (2-3" long) on the right side of steering wheel with your cruise control settings.
    not all vehicles came with it but I suppose it could have been removed and sold but I doubt it.
  3. Oct 16, 2014 at 6:36 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I'll post a pic tomorrow of the engine bay. And my steering wheel doesnt have anything on it. Maybe he changed out the wheel?
  4. Oct 16, 2014 at 7:14 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It was most likely pre-wired as an option. Mine has lots of "extra" plugs under the hood.
