Something is Wet in my rear wheel.
Discussion in '1st Gen. Tacomas (1995-2004)' started by emglishe30, Sep 7, 2009.
  1. Sep 7, 2009 at 4:07 PM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    So I have been noticing lately that there is something leaking in my my rear drivers side wheel. I noticed it the other day and have no clue what it is. It is on the inside of the wheel right on the inner edge of the lip of the rim. Any ideas what it could be? Brake fluid perhaps?
  2. Sep 7, 2009 at 4:08 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    does it smell really bad?
  3. Sep 7, 2009 at 4:14 PM
    emglishe30
    NJ
    good question let me go finger it..brb
  4. Sep 7, 2009 at 4:17 PM
    emglishe30
    NJ
    little stinky...def oily whatever it is
  5. Sep 7, 2009 at 4:19 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    check your brake fliud could be a wheel cylinder.or could possibley your axle seal.and somtimes it's nothing at all just water or something
  6. Sep 7, 2009 at 4:19 PM
    johnw
    john
    orlando florida
    in my opinion it might be rear diff fluid. because i know it smells bad. what else i can say is go smell your brake fluid res and see if it smells the same if it does it is not rear diff fluid
  7. Sep 7, 2009 at 4:30 PM
    emglishe30
    NJ
    good advice there, I will check it out tomorrow when I get home from work. Thanks
  8. Sep 7, 2009 at 4:31 PM
    johnw
    john
    orlando florida
    Yup no problem. atleast i can help somehow
  9. Sep 7, 2009 at 4:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like a leaky brake cylinder, maybe get a buddy (or anyone else who can take direction & pump the brake pedal & hold it when told to !)have the buddy pump the brake pedal 8 or 10 times,hold it & carefully check for bubbling,weeping of fluid etc; Also make sure when you pump it up & hold the pedal down it keeps pressure without going down to the floorboard.:cool:
  10. Sep 8, 2009 at 4:55 AM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    Easiest thing to do is pull the drum off. If theres oil all over the place it's an axle seal. Happened to mine 2 weeks ago. 30 min fix and a can of brake cleaner and your good to go.
    If it is this then I also recommend changing your diff breather.
  11. Sep 8, 2009 at 5:07 AM
    Selwyn Boom
    Selwyn Boom Selwyn Boom
    Boom!!!
    US Virgin Islands
    02 Tacoma Burgundy
    22's and a DVD sound system.
    I think it is the rear seal that is leaking. The only other thing is brake fluid. So you can check that for sure.
  12. Sep 8, 2009 at 1:22 PM
    emglishe30
    NJ
    def think its an axle seal. Brake fluid is to the max.. whats the labor involved? I might be able to do the job. Other question is how much should it run to have a shop do it?
  13. Sep 8, 2009 at 3:30 PM
    jfr02
    it shouldn't be to hard i' never done on on a yota.you should have to pull the axle out.not sure how you do that on the third member style rearend like i said never done it on a yota i've done gm jeep and ford it only took half hour to forty five mins.a shop shouldn't be to much but doing it yourself will be much cheaper. i'm sure someone on hear can give you a better idea of what is involved
  14. Sep 8, 2009 at 3:37 PM
    jfr02
  15. Sep 8, 2009 at 6:41 PM
    Selwyn Boom
    Boom!!!
    US Virgin Islands
    02 Tacoma Burgundy
    I am not sure how much it cost but i think you need a press so be very careful you dont damage the seal putting it back in.
  16. Sep 8, 2009 at 6:50 PM
    jfr02
    you will not need a press
  17. Sep 9, 2009 at 5:54 AM
    Ktaco
    **EDIT** I didn't notice the link above with the write-up. It seems to have everything covered
    It's very easy to do.
    1. Loosen lug nuts on wheel that the seal is bad in.
    2. Jack truck.
    3. Remove wheel. Remove brake drum. Disconnect the hand brake cable to that wheel (remove pin), disconnect brake line, and unplug abs wheel sensor wire ( if you have abs).
    4. Remove the 4 nuts holding on the axle. Once they are off slowly pull out the axle. You may loose a little oil.
    5. Looking into the axle housing you will see the oil seal about 2 inches in or so. This old seal can be a PITA to remove. If you don't have a seal puller then you just need to pry it out. Screw drivers, pry bars, etc. Even a chisel can come in handy to break it apart.
    6. Once you get it out use a fine grit sandpaper to remove any build up where the old seal was. Now you can install the new seal. (if you have abs I found it easier to remove the wheel sensor as well as the magnet on it makes it difficult to line up the seal in order to put it it).
    7. Get a socket or anything that you can use that only hits on the outside of the seal. Very carefully tap the seal in. When in, the rubber ring on the inside should not be disfigured and should look like when the seal came right out of the box.
    8. Carefully insert axle (may need to twist it a bit to get it fully into place).
    9. Install all you nuts (with loctight), cables, brake line, etc. Use brake cleaner on the drum and brake components. Lightly sand the brake pads to ensure oil is off. Once everything is back on you can top up your diff oil a pinch if you wish.
    This is a run down just from the top of my head. I'm sure there is a write-up out there with pics. It's a pretty clean job with not a lot of tools required. First one might take you an hour taking your time. I would replace the diff breather even if the old one looks alright, or do the diff breather mod.
    Good luck :)
  18. Sep 9, 2009 at 10:45 AM
    emglishe30
    NJ
    I'm in the process of moving and its going to be at least a week or maybe two before I or a shop can get to this. Anything I should worry about with waiting that long?
  19. Sep 9, 2009 at 3:03 PM
    jfr02
    you may have to replace your rear brake shoes.check the diff breather and fluid level.
  20. Sep 10, 2009 at 6:33 AM
    Ktaco
    I know if you brought it to Toyota for this problem they would want to replace every brake component that came in contact with the oil. I've seen them do it to people at our dealership. This can be a costly visit. Just be sure you know what the garage intends to change before bringing it.
