Something is wrong here (3.4l v6 4wd)
Discussion in '1st Gen. Tacomas (1995-2004)' started by snaxr, Oct 14, 2020.
  1. Oct 15, 2020 at 5:02 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    84533CDF-2D61-44E6-A304-8AA9F548CF08.jpg Idk what the heck that thing is on yours, but I definitely don’t have that. I do have the cable that would plug into it, but it has what looks like a factory plug-cap on it.
  2. Oct 15, 2020 at 5:14 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That would be the VSV allowing vacuum modulation of the fuel pressure regulator, ECM controlled.
    Most V6 engines did not have it. Exactly which ones did is vague. Seems to be the earlier years and/or EGR engines.
    96BlueTacos likes this.
  3. Oct 15, 2020 at 5:16 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Interesting. My 96 is early and has(had) EGR... weird
  4. Oct 15, 2020 at 5:27 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    It's also been suggested that Ca emissions had something to do with it.
    The thing is next to useless and many ditch it.
    Funny thing is the FSM kept referencing "testing" it till the end of 1st gen production, long after it was retired.
  5. Oct 15, 2020 at 5:29 PM
    snaxr
    snaxr [OP] Well-Known Member
    Im blind lol. Ok so I have a line missing from PWM-Vacuum switching valve, and the line that is supposed to go to it from near throttle body just dives down and hits another switching valve and then splits off into two, down somewhere deep. Guessing Brakes/brake booster? I need to cap off the other throttle body nipple, and then figure out how to get that hose to the aftermarket/K&N airfilter. Not sure what the 'with A/C' dotted line means though, what model doesnt have A/C or am I missing something?
    96BlueTacos and Dalandser like this.
  6. Oct 15, 2020 at 5:33 PM
    snaxr
    Also
  7. Oct 15, 2020 at 5:33 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Ac was optional. I dont have ac. It sucks but I also dont have any drip rust issues
  8. Oct 15, 2020 at 5:38 PM
    snaxr
    But you still have a hose there, which aids my confusion. Is anything not showing in diagram that is A/C related in between the front nippe and the airbox? My ac hasnt been checked with gauges yet but isnt really working well.
  9. Oct 15, 2020 at 5:42 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    AC was not "standard equipment" on every model.
    The "with AC" bit is a stand alone system known as "idle up". Similar in theory to the power steering "idle up".
    When the AC compressor is running the VSV allows a tad more air into the intake slightly boosting idle speed. Later years did this electronically via the ECM.
  10. Oct 15, 2020 at 7:07 PM
    snaxr
    Ah ok, I'll assume that just means everything is already wired up to A/C and theres no extra hoses besides those shown. I am curious about why the PWM hose splits off differently from the diagram, hits a switch and then two hoses go down under the engine somewhere.
  11. May 10, 2023 at 10:21 AM
    TaylorWarwas
    TaylorWarwas New Member
    1994 SR5 Tacoma
    Yo kinda random and this is an old thread.... could you potentially shoot me the part # on the valve that everyone is talking about in this thread? it broke on mine and the print wore off. Thanks man.
