Something is Wrong With My Toytec Coilovers...Please Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Jul 3, 2010.
  1. Jul 3, 2010 at 5:45 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    A week ago I put the Toytec Ultimate kit on my taco. You may remember this thread...
    http://www.tacomaworld.com/forum/2n...y-setup-new-lift-lots-pictures-need-help.html
    Somehow I got like 5 inches of lift from the front coilovers. I decided to give it a week to settle then adjust per Chris4x4's instruction. So today I retorqued everything and adjusted the coilovers. I adjusted them down about 1/2 an inch which should have resulted in a 1" lowering of the front of my taco. It didn't make any difference so I adjusted another 1/2" on each side but believe it or not it still made no difference. :eek:
    Is something wrong with my coilovers? I'm kinda worried now that I have adjusted them down over 1" which should have resulted in at least 2" height reduction but it did nothing. I'm adjusting them clockwise...is that right? I only have about 1.5" of thread below the adjuster ring left and I still have a 4" lift in the front.
    Please help....Thanks! :D
  2. Jul 3, 2010 at 6:01 PM
    jmed99
    SC
    Here's a pic of the coilover as it is now...
  3. Jul 3, 2010 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You need to turn the adjuster counter clock wise (IIRC). The threaded adjusters may be on the wrong setting on the shocks, so you may have to adjust more. If there was alot of pre load on the spring, you may have to take more than an inch before any difference in height is seen.
  4. Jul 3, 2010 at 6:35 PM
    jmed99
    SC
    Counter clockwise would move the adjuster ring up on the threads....you sure that's right? Seems like i would turn the adjuster clockwise thus moving the adjuster down on the threads and lowering it. The directions say to turn clockwise....what am I missing...I feel like a dumb ass!
    Thanks for your help!
  5. Jul 3, 2010 at 7:24 PM
    jmed99
    SC
    So the thread adjusters may be on the wrong setting? That doesn't sound good. Should I return the coilovers for new ones? Just seems like something has been wrong from the beginning. I mean Toytec says the maximum lift you can get after you adjust them is 3.5 inches and somehow I got 5" with the ability to adjust up from there. When I adjust down nothing happens.
    This all seems real weird and possibly dangerous. Thoughts?
  6. Jul 3, 2010 at 8:19 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    I would call Toytec and see what they say. For my Icon coilovers, you would have to make 4 turns to get about 1/2" of lift or drop.
  7. Jul 3, 2010 at 8:23 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    how did you measure the 5"? did you add on new tires at the same time?
    Something is not right here....
  8. Jul 3, 2010 at 9:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your right...Clockwise to lower.....Long day in the sun :eek: Keep lowering them until the correct height is achieved.
  9. Jul 3, 2010 at 10:06 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Don't mind me but I gotta ask. Are you driving it around the block after you adjust them? You gotta let the suspension settle. If the tires don't roll after you adjust it, it will stay the same!
  10. Jul 4, 2010 at 12:26 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Otherwise did you get the incorrect springs sent?
  11. Jul 4, 2010 at 8:54 AM
    jmed99
    SC
    I drove it around the block and adjusted it a couple more times and got it. One side is now at 39" and the other is at 39-1/4". I'm going to check the tire pressure and make one more adjustment to the drivers side to get the 2 sides to be even and she'll be good to go.
    Thanks everyone!
  12. Jul 4, 2010 at 10:05 AM
    DWreck
    Derek
    Las Vegas, NV
    Your welcome! Glad it's ganna work out for ya.
  13. Jul 4, 2010 at 1:25 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Don't you need an alignment if you adjust the coil height?
  14. Jul 4, 2010 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  15. Jul 4, 2010 at 4:51 PM
    SCFirefighter
    Stephan
    Cary, NC
    Just making sure. Thanks. (although it really sucks that you need one lol)
