something like coil overs for rear 2009
Discussion in 'Suspension' started by chad68, Apr 14, 2009.
  1. Apr 14, 2009 at 4:05 PM
    chad68
    chad68 [OP] Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    I know they don't make coilovers for the rear because it's leaf springs and a shock setup but what is an affordable way to lift the rear 1.0-1.5"' and have the ability to keep the rear at that height when the leaf springs eventually start to sag/settle?
    Wheelers has a few options for the rear that say that they are for 0-2" of lift but I don't know if they lift the rear or are meant to be used with up to a 2" leaf pack or block set, so they make use off the extra travel from the blocks or leaf pack.
    I want to lift the rear 1-1.5" and be able to keep it at that level by fine tuning as needed. I'm getting 2.5" Camburgs up front but want to be able to adjust the rear height the same way as needed.
  2. Apr 14, 2009 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Get an 1.5" AAL. Odds are, it will give just a bit more lift, so if it sags to 1.5" your still good.
  3. Apr 14, 2009 at 4:09 PM
    chad68
    Chad
    Wow that was fast. That's what I was thinking too but I want to be able to dial out the imfamous Taco lean down the road as well.
  4. Apr 14, 2009 at 4:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When you get the AAL, take it to a spring shop and have them put in 1/4" to 1/3" more arch in the driver side leaf. That should set you pretty close to level.
  5. Apr 14, 2009 at 5:11 PM
    chad68
    Chad
    I was also thinking about just getting AAL and when the drivers side sags to 1/4" more than the passenger side, just put a shim in it's place assuming there is enough left over threads on the U bolts.
    But is there such a thing that allows you to fine tune the height?
  6. Apr 14, 2009 at 5:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not in the rear.
  7. Apr 15, 2009 at 3:38 PM
    chad68
    Chad
    Well I ordered the 2.5 Camburgs last night. I got my 265/75/16 Kumho adventure KL71's installed today. These tires look pretty wide for a 265 which was perfect. 33's in this size would be massive. Going to look sick with my 4.0" backspacing
